iC8 to UE5 Hair Issues
Posted By lightbearer 3 Years Ago
lightbearer
lightbearer
Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)Veteran Member (859 reputation)
Posts: 88, Visits: 529
Rendering a character in UE5.03 and I am experiencing issues with the hair. I'm rendering in Lumen, but I experience the same issue with the deprecated raytracer. A screenshot is attached (Lumen render). The hair renders with "holes" or "dots" in areas with this being most noticeable on the mustache and side of the hair. The hair is from Hair Builder.
Has anyone seen anything like this? Is there a solution? By the way, I am using Auto Setup 1.5.
https://forum.reallusion.com/uploads/images/36ef2e7d-1860-4e55-8e5e-7798.jpg
Threaded View
Threaded View
Forum Post iC8 to UE5 Hair Issues By lightbearer ( 3 Years Ago )
Forum Post Would you mind posting a straight on image as we can't really tell... By GIM ( 3 Years Ago )
Forum Post Here's a close up of what's happening. By lightbearer ( 3 Years Ago )
Forum Post Only behind the window of that car or general? And only in render? Can... By toystorylab ( 3 Years Ago )
Forum Post It's more noticeable in the renders but is also apparent in the... By lightbearer ( 3 Years Ago )
Forum Post This is a screenshot of the character from the "Mesh" editor. Also... By lightbearer ( 3 Years Ago )
Forum Post It has something to do with the Post Process Volume, though for the... By lightbearer ( 3 Years Ago )
Forum Post Last one for the night. Calling it quits. No Post Process Volume and... By lightbearer ( 3 Years Ago )
Forum Post Hm, no idea what causes this, thought it might be transparency... By toystorylab ( 3 Years Ago )
Forum Post I'm having the same problem. By tomelissaconway ( 3 Years Ago )
Forum Post @Melissa Oops... Maybe GPU issue? Driver up to date? By toystorylab ( 3 Years Ago )
Forum Post [quote][b]toystorylab (10/15/2022)[/b][hr]@Melissa Oops... Maybe GPU... By tomelissaconway ( 3 Years Ago )
Forum Post Is this happening with all hair cards ? Raytracing on or off? By StyleMarshal ( 3 Years Ago )
Forum Post It's happening with hair cards from the Hair Builder pack. Happens... By lightbearer ( 3 Years Ago )
Forum Post Using the latest studio driver from Nvidia. By lightbearer ( 3 Years Ago )
Forum Post Yes, that is exactly what is happening to my renders/viewport. Makes... By lightbearer ( 3 Years Ago )
Forum Post The good news is that it works for you. So there is hope. It does make... By lightbearer ( 3 Years Ago )
Forum Post I used an addon in Blender called Facial Hair Tool; modified the... By lightbearer ( 3 Years Ago )
Forum Post I am having the same issue :@ ANY ONE FOUND THE CAUSE AND SOLUTION?... By new-own ( 3 Years Ago )
Forum Post My current understanding is that the CC Unreal hair shader needs an... By pxlpshr42 ( 3 Years Ago )
Forum Post [quote][b]pxlpshr42 (10/26/2022)[/b][hr]My current understanding is... By new-own ( 3 Years Ago )
Forum Post [quote][b]pxlpshr42 (10/26/2022)[/b][hr]My current understanding is... By lightbearer ( 3 Years Ago )
Forum Post [quote][b]lightbearer (10/26/2022)[/b][hr] It's unfortunate really,... By pxlpshr42 ( 3 Years Ago )
Forum Post [quote] Unfortunately I haven't found a large collection of good... By lightbearer ( 3 Years Ago )
Forum Post Have you tried playing around with the "alpha power" in Unreal... By Kalex ( 3 Years Ago )
Forum Post [quote][b]Kalex (11/5/2022)[/b][hr]Have you tried playing around with... By lightbearer ( 3 Years Ago )
Forum Post you weren't satisfied with the results though ? By Kalex ( 3 Years Ago )
Forum Post I'm still trying to figure out what's wrong. In UE5, this is a screen... By tomelissaconway ( 3 Years Ago )
Forum Post [quote][b]tomelissaconway (11/11/2022)[/b][hr]I'm still trying to... By lightbearer ( 3 Years Ago )
Forum Post Did you figure out which lighting and/or engine scalability settings... By tomelissaconway ( 3 Years Ago )
Forum Post [quote][b]tomelissaconway (11/11/2022)[/b][hr]Did you figure out which... By lightbearer ( 3 Years Ago )
Forum Post [quote][b]lightbearer (11/7/2022)[/b][hr][quote][b]Kalex... By lightbearer ( 3 Years Ago )
Forum Post Here's what I found: https://www.youtube.com/watch?v=6AiUrL9Pa0s By Kalex ( 3 Years Ago )
Forum Post [quote][b]Kalex (11/15/2022)[/b][hr]Here's what I found:... By lightbearer ( 3 Years Ago )
Forum Post Yeah , I am having the same issue with smart hair : By StyleMarshal ( 3 Years Ago )
