Amper Sand
Amper Sand
Visits: 5.2K
I just observed that Hub (ver 4.1.822.1) is listing the "iClone 3DXchange 7" as a Not Installed product, even I have 3DXChange 7 Pro (ver 7.81.5515.1) already installed and working as usual.
______________________________________________________________________________ Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend In progress: Black Mamba AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
Posts: 5.7K,
I personally wouldn't worry about it as long as everything is working as expected. I have the Hub disabled on my PC and only enable it when I need to update anything, so I haven't a clue what it thinks about the status of any and all installed software. :)
Amper Sand
Amper Sand
Visits: 5.2K
wires (8/25/2022) I personally wouldn't worry about it as long as everything is working as expected. I have the Hub disabled on my PC and only enable it when I need to update anything, so I haven't a clue what it thinks about the status of any and all installed software. :)I agree with this, Gerry, but ironically was the same reason I posted this issue here: if Hub does not recognize it, then will not notify me any new available update.
Posts: 5.7K,
RL are never going to update anything connected with iClone 7 and CC3, just make sure that you have copies of the last available full installers saved somewhere safe.
Posts: 15.8K,
Visits: 31.4K
So this is bizarre. I checked my Hub and 3DXchange was listed as installed...:w00t: Then there was a message that the Hub had a major update, so I let it update. After that, 3DXchange is now listed as NOT installed...:crazy:
Amper Sand
Amper Sand
Visits: 5.2K
Thanks, @animagic, I'm almost sure this is/was my case too.
facr73
facr73
Visits: 23.8K
Same here. It says Not Installed
Posts: 23.1K,
Visits: 36.6K
Thanks you all for reporting this issue. I have passed it on for further investigation. I will update again when more is known.
Posts: 23.1K,
Visits: 36.6K
UPDATE: We have found the problem and a new version of the Hub will be available in the coming days to correct the issue. Thanks again for the quick notification.
wendyluvscatz
wendyluvscatz
Last Active: 12 days ago
Posts: 2.5K,
Visits: 19.4K
I started a thread about iC6 etc before I saw thus just adding as nobody likely to look there I hope authentication continues to work as I would be most upset if my software and assets stopped working
