Hub doesn't recognize already installed 3DXChange 7
https://forum.reallusion.com/Topic522552.aspx
Print Topic | Close Window
By Amper Sand - 4 Years Ago
I just observed that Hub (ver 4.1.822.1) is listing the "iClone 3DXchange 7" as a Not Installed product, even I have 3DXChange 7 Pro (ver 7.81.5515.1) already installed and working as usual.
By wires - 4 Years Ago
I personally wouldn't worry about it as long as everything is working as expected. I have the Hub disabled on my PC and only enable it when I need to update anything, so I haven't a clue what it thinks about the status of any and all installed software. :)
wires (8/25/2022)
I agree with this, Gerry, but ironically was the same reason I posted this issue here: if Hub does not recognize it, then will not notify me any new available update.
RL are never going to update anything connected with iClone 7 and CC3, just make sure that you have copies of the last available full installers saved somewhere safe.
By animagic - 4 Years Ago
So this is bizarre. I checked my Hub and 3DXchange was listed as installed...:w00t:
Then there was a message that the Hub had a major update, so I let it update.
After that, 3DXchange is now listed as NOT installed...:crazy:
Thanks, @animagic, I'm almost sure this is/was my case too.
By facr73 - 4 Years Ago
Same here. It says Not Installed
By Peter (RL) - 4 Years Ago
Thanks you all for reporting this issue. I have passed it on for further investigation. I will update again when more is known.
UPDATE: We have found the problem and a new version of the Hub will be available in the coming days to correct the issue. Thanks again for the quick notification.
By wendyluvscatz - 4 Years Ago
I started a thread about iC6 etc before I saw thus
just adding as nobody likely to look there
I hope authentication continues to work as I would be most upset if my software and assets stopped working
Peter (RL) (8/27/2022)
Being once again overwhelmed by your superior lightning responses to our daily woes I will await the arrival of the promised solution with the excitement and expatiations due such an event before consenting to an update. ;):):Whistling:
Got today the latest Hub update (4.1.6830.1), the 3DXchange is back on installed section.
Thanks!
Amper Sand (8/31/2022)
Thanks!
Thanks for letting us know. :)
