How to import Daz3D characters with facial expressions into CC4? [Tutorial]
Posted By Fionn (RL) 4 Years Ago
How to import Daz3D characters with facial expressions into CC4?...
Fionn (RL)
Fionn (RL)
Posts: 87, Visits: 614
Thanks for the many feedbacks and suggestions from our users. We think now’s a good time to elaborate on this easy workflow for the community: please follow the steps below to import your Daz3D characters into CC4 without losing data.
Step 1. Before exporting characters from Daz3D
1-1 Please copy the Reallusion folder toC:\Users\Public\Documents\My DAZ 3D Library\data\DAZ 3D\Genesis 8\Male\Morphs, because we need this morph data in Daz3D when we convert the facial keys.
1-2 To open Daz Studio, drag "Genesis8_Male_RL_FaceKey.duf" to the character that you want to export. It will create a facekey in DAZ, and then you can export FBX to Character Creator 4 (CC4) or 3DXchange.
Step 2Export characters from Daz3D
2-1We take the model 'Genesis 3 Male’ as an example. Before you export this model from Daz Studio, make sure you tick the Show Sub Items checkbox at the right panel.
https://forum.reallusion.com/uploads/images/15b7cd56-5622-42f1-9943-6801.png
2-2 Go to the toolbar, click File > Export > DazExport, find the ‘G3Male’ folder and save this model as an FBX file.
https://forum.reallusion.com/uploads/images/16540cb4-fd29-426a-90d9-26eb.png
2-3 After saving the FBX file, choose the desired content on the FBX Export Options window, then click the Edit Morph Export Rules…button.
https://forum.reallusion.com/uploads/images/a0b2251d-1ac8-4594-a84f-2507.png
2-4 Once the Rule, Match, Action export rules are confirmed, click the Accept button.
https://forum.reallusion.com/uploads/images/f38bb746-32f4-4473-b193-9b92.png
Step 3Import characters to Character Creator 4
3-1 Open Character Creator 4 and go to the toolbar, click File > Import > DazExport, find the file “G3Male.fbx” and click Open.
https://forum.reallusion.com/uploads/images/69cdbd96-b346-490d-8fac-d739.png
3-2 Since this model is not a prop, choose Character.
https://forum.reallusion.com/uploads/images/05117213-4ad4-4ba2-a544-d748.png
As it’s not a CC Avatar created in Character Creator, choose the Humanoid option for Non-Standard character
https://forum.reallusion.com/uploads/images/7ffec4c3-4455-463f-9bb4-985a.png
3-3 As CC4 supports various character types from the industry, ranging from Maya, 3ds Max, Blender to Daz3D, CC4 will automatically detect this Daz model and convert it to Humanoid.
https://www.reallusion.com/character-creator/animate-any-character.html#feature-nav-Humanoid
https://forum.reallusion.com/uploads/images/469ac96a-c411-48d2-bd3f-9d59.png
Step 4Using Daz3D Facial keys in Character Creator 4
4-1 After successfully importing the Daz model into CC4, go to Local Disk( C: ) > Program Files > Reallusion > Character Creator 4 >  Program > Assets https://forum.reallusion.com/uploads/images/d4e7da3e-0ad9-4b78-a89a-9cf0.png
4-2 Continue the path, Assets > ExternalFiles > DazResource > FacialProfile >Genesis3_Male, and find the “Genesis3_Male.ccFacialProfile” file.
https://forum.reallusion.com/uploads/images/43e1d67d-71a4-4353-a41d-629c.png
Directly drag
this file to your character in the viewport.
https://forum.reallusion.com/uploads/images/0219371a-47e0-41a4-a8bd-78d6.png
A popup window will show the Facial Profile you can apply to this Daz character;
click Apply.
https://forum.reallusion.com/uploads/images/ffb87cee-f076-4c24-9e93-7789.png
4-3 Click Edit Expressions in the Facial Profile Editor panel on the left side, then you can easily customise this model’s facial expressions with the Standard (60+ blendshapes) or Extended Expression Profile (140+ blendshapes) in CC4.
https://forum.reallusion.com/uploads/images/02f4b4bc-b7d3-47a9-9079-1b51.png
4-4 After successfully importing your Daz character in CC4,  you can use the Facial Expression Template to demo its expression data by clicking Edit Facial in the Modify panel.
https://forum.reallusion.com/uploads/images/41440369-4ede-4ff8-a1f9-e401.png
Directly drag the desired facial profiles onto your character in the viewport and see the result.
https://forum.reallusion.com/uploads/images/c7cdc2c4-cd3f-43de-9e8d-4036.png
4-5 In addition, you can apply Facial Motion (Facial Rig) to the Daz characters for further calibration.
https://forum.reallusion.com/uploads/images/0067a4b9-1fcd-4526-917e-d834.png
Learn more about custom facial expressions in CC4.
https://www.reallusion.com/character-creator/facial-expression.html
Threaded View
Threaded View
Forum Post How to import Daz3D characters with facial expressions into CC4?... By Fionn (RL) ( 4 Years Ago )
Forum Post Just wanted to check this, but I fail at the first sentence: 1-1... By toystorylab ( 4 Years Ago )
Forum Post [quote][b]toystorylab (7/29/2022)[/b][hr]Just wanted to check this,... By wires ( 4 Years Ago )
Forum Post [quote][b]toystorylab (7/29/2022)[/b][hr]Just wanted to check this,... By animatedbeing ( 4 Years Ago )
Forum Post Yo, could be, thanx! Will test... :crazy: By toystorylab ( 4 Years Ago )
Forum Post [quote][b]toystorylab (7/29/2022)[/b][hr]Yo, could be, thanx! Will... By wires ( 4 Years Ago )
Forum Post Hm, first test was not very lucky... The export process takes aeons,... By toystorylab ( 4 Years Ago )
Forum Post @animatedbeing OK, so Folder thing was not correct, did now as you... By toystorylab ( 4 Years Ago )
Forum Post Hint for faster export from DAZ. Change the FPS to 1 By animatedbeing ( 4 Years Ago )
Forum Post [quote][b]animatedbeing (7/29/2022)[/b][hr]Hint for faster export from... By toystorylab ( 4 Years Ago )
Forum Post Export "animation" is still so slow, again aborted. No fun! Though my... By toystorylab ( 4 Years Ago )
Forum Post And I assume I have to leave the range 0-90 to get this working... It... By toystorylab ( 4 Years Ago )
Forum Post Hm, I set range from 0 to 1... Went way faster though stuck at the... By toystorylab ( 4 Years Ago )
Forum Post But this workflow is good for creatures or non human stuff. By StyleMarshal ( 4 Years Ago )
Forum Post [quote][b]Bassline303 (7/29/2022)[/b][hr]But this workflow is good for... By toystorylab ( 4 Years Ago )
Forum Post I have not followed this particular one, but previously it never took... By 4u2ges ( 4 Years Ago )
Forum Post Rampa did a great tutorial too :... By StyleMarshal ( 4 Years Ago )
Forum Post In this thread’s first post, in section 4-4, in the video entitled... By TonyDPrime ( 4 Years Ago )
Forum Post Did the copy which folder to where get sorted out to everyone's... By wires ( 4 Years Ago )
