helielfilmz
helielfilmz
Visits: 383
Nevermind i got it to work. I saved both earrings and they went to the accessory folder, i selected them for another character and they both are in the same place on the ear. Thanks for your help
What you know today will be obsolete tomorrow
helielfilmz
helielfilmz
Visits: 383
4u2ges (5/10/2022) Glad it worked out. You have to save it as an avatar Accessory in iClone or Character Creator (in iClone just make sure to select the root of the earrings - very top layer before saving). Then, when you apply it to another character, earring would stay close to respective ear. Minor tweaking of the root position might require for different characters.
I tried saving it as a accessory, but it always go to the props folder instead for some reason i don't know why that is. What is the root i have no idea as for the earrings
Posts: 5.3K,
Visits: 16.8K
helielfilmz
helielfilmz
Visits: 383
4u2ges (5/9/2022) Check the reply above. In other word, an extra piece not used in P2P connector is acting like a collision shape and breaking the chain apart.
Thank you it worked! Now one more thing how do i save the earrings to be on my models ears like yours without having to manually align them each time i select them?
helielfilmz
helielfilmz
Visits: 383
How do i merge the two together?
Posts: 5.3K,
Visits: 16.8K
helielfilmz
helielfilmz
Visits: 383
helielfilmz (5/9/2022)
4u2ges (5/8/2022) Just in case, a quick video:
I did everything you shown in this video. As i stated before my earrings "Floats like a butterfly" away from the hook/hinge in mid air. I have the SV Trendsetter Big Hoops earrings from Daz could you make a video from beginning to end using these earring? This is a very frustrating matter that i am trying to resolve and move on to finishing so that i could add to a scene  This is what i'm talking about https://www.youtube.com/watch?v=hmPnCXumWI0
Posts: 5.3K,
Visits: 16.8K
Point-to-Point connects 2 props, but you have a chain of 3 and all 3 are physics enabled. Earring is pretty simply and you probably do not need all 3 pieces. You can always merge Hinge and Hook into a single prop.
helielfilmz
helielfilmz
Visits: 383
helielfilmz
helielfilmz
Visits: 383
Thanx man for responding i am going to look at your video while doing this right now
