Flip Element normals?
Posted By jerome.dipietro 5 Years Ago
jerome.dipietro
jerome.dipietro
Posts: 91, Visits: 1.1K
Is there any way to flip Element normals (I know there's an 'Edit Normals' menu that allows you to flip an entire object but I have DAZ clothes that have just parts of an item flipped.
I'm a bit too far down the rabbit hole to go back to the original DAZ FBX. Would there be an easy way to go into Blender and then straight back into CC3 without having to redo all my skin weights and mesh conforming?
Unity Virtual Reality Developer
Last Active: 21 minutes ago
Posts: 5.3K, Visits: 16.8K
Blender is a way to go. General workflow:
Save all materials for cloth which you need to amend. Save Project.
Export to FBX with Blender option, as Mesh only, uncheck "Embed Texture". This would create an FBX key so you can bring avatar back to CC.
Import to Blender, do what you need to do with piece of cloth fixing the problem.
Export out of Blender overriding original import (just easier to have FBX key loaded automatically). All default setting except uncheck "Add Leaf Bones" in Armature section.
Import back to CC with "Create Cloth, Hair, Acc (with FbxKey)". Make sure to select the same layer number for amended cloth at the prompt.
Save amended cloth.
Load original project.
Apply amended cloth (overriding existed).
Reapply saved materials to the amended cloth.
Done!
jerome.dipietro
jerome.dipietro
Such clear and useful information . Thank you!
jerome.dipietro
jerome.dipietro
Sorry, but I'm stuck with regards to the FBXKey.
I've tried exporting the FBX (Blender Preset, mesh only) with both Embed textures, and without, and both times I only get the FBX, no sign of an FBXKey file being generated.
Then when I try to reimport (after working in Blender) using "Create Cloth, Hair, Acc (with FbxKey)" I get 'FBXKey file path is empty' as an error and can't proceed. It obviously wants the Decrypt Key File but none is being generated. I'm on CC3.4 Pipeline.
Is there some additional setting I need to tick?
https://forum.reallusion.com/uploads/images/bb3cdd8f-c17f-4d7f-a463-7a82.png
Scroll down the FBX applet and see if you have Delete Hidden Faces Checked. If you do, export would not create a key. You need to uncheck it.
jerome.dipietro
jerome.dipietro
It's already unchecked :ermm:
You mean you go to the export folder in Windows Explorer and do not see the key?
I just created it exporting with the same setting as you have tried.
https://forum.reallusion.com/uploads/images/8419933a-8dac-4a35-9eaa-23ed.jpg
One more thing, which I am not sure whether it would stop generating the key or not. That is, do you have a Pipeline version?
jerome.dipietro
jerome.dipietro
Thanks 4u2ges. Really appreciate all your help with this.
So yes I have the Pipeline version, and no definitely no FBXKey is being generated but I now know why, although it's a bit of a pain...
I'm exporting a GameBase character and I'd decimated the clothes using InstaLOD. Seems that either or both of these means that no FBX key is generated on export, which means apparently no way to bring things back in from Blender.  When working from the original highpoly CC3+ and Cloth items, then everything works as you describe.
What a shame!
Ahh, yeah. Game base is only for the export.
There maybe another way. You may transfer weight paint data between same cloth items attached to different avatars (if that can help in any way) in Blender.
Select cloth on the destination avatar (the one you can bring back to CC), Shift + select cloth on Source Avatar (game base I suppose), Ctrl+L > Object Data
Or you can simply save cloth, attach to different avatar, round trip to Blender and Save/attach cloth the game base.
jerome.dipietro
jerome.dipietro
Will try that. Second option seems the simplest :)
Thanks again. Much appreciated
