Flip Element normals?
Posted By jerome.dipietro 5 Years Ago
jerome.dipietro
jerome.dipietro
Posts: 91, Visits: 1.1K
"transfer weight paint by selecting  the same saved cloth item with weight paint in Transfer Weight Paint applet"
Genius! I'd never spotted that applet. That's got to be the best option. Thanks again
Unity Virtual Reality Developer
Posts: 5.3K, Visits: 16.8K
Oh, and one more (I keep forgetting about this one :)). You can bring back cloth only as an accessory and then transfer weight paint by selecting  the same saved cloth item with weight paint in Transfer Weight Paint applet.
@Rampa
You can do this in CC too (almost). But unfortunately with object only. Yes 3DX has an option to select a mesh, but not individual faces, where sometimes only a few faces are imported flipped for the object/mesh as a result of developer or others negligence.
Posts: 8.2K, Visits: 62.6K
3DXchange has individual normal flipping. See here:
https://manual.reallusion.com/3DXchange_7/ENU/Default.htm#3DXchange_7/Pipeline_7.0/04_Modify_Page/Normal_Section/The_Concept_Of_Normal.htm%3FTocPath%3DSection%2520Details%2520in%2520Modify%2520Page%7CNormal%2520Section%7C_____1
https://manual.reallusion.com/3DXchange_7/ENU/Default.htm#3DXchange_7/Pipeline_7.0/04_Modify_Page/Normal_Section/Flipping_The_Normal.htm%3FTocPath%3DSection%2520Details%2520in%2520Modify%2520Page%7CNormal%2520Section%7C_____3
jerome.dipietro
jerome.dipietro
Will try that. Second option seems the simplest :)
Thanks again. Much appreciated
Ahh, yeah. Game base is only for the export.
There maybe another way. You may transfer weight paint data between same cloth items attached to different avatars (if that can help in any way) in Blender.
Select cloth on the destination avatar (the one you can bring back to CC), Shift + select cloth on Source Avatar (game base I suppose), Ctrl+L > Object Data
Or you can simply save cloth, attach to different avatar, round trip to Blender and Save/attach cloth the game base.
jerome.dipietro
jerome.dipietro
Thanks 4u2ges. Really appreciate all your help with this.
So yes I have the Pipeline version, and no definitely no FBXKey is being generated but I now know why, although it's a bit of a pain...
I'm exporting a GameBase character and I'd decimated the clothes using InstaLOD. Seems that either or both of these means that no FBX key is generated on export, which means apparently no way to bring things back in from Blender.  When working from the original highpoly CC3+ and Cloth items, then everything works as you describe.
What a shame!
You mean you go to the export folder in Windows Explorer and do not see the key?
I just created it exporting with the same setting as you have tried.
https://forum.reallusion.com/uploads/images/8419933a-8dac-4a35-9eaa-23ed.jpg
One more thing, which I am not sure whether it would stop generating the key or not. That is, do you have a Pipeline version?
jerome.dipietro
jerome.dipietro
It's already unchecked :ermm:
Scroll down the FBX applet and see if you have Delete Hidden Faces Checked. If you do, export would not create a key. You need to uncheck it.
jerome.dipietro
jerome.dipietro
Sorry, but I'm stuck with regards to the FBXKey.
I've tried exporting the FBX (Blender Preset, mesh only) with both Embed textures, and without, and both times I only get the FBX, no sign of an FBXKey file being generated.
Then when I try to reimport (after working in Blender) using "Create Cloth, Hair, Acc (with FbxKey)" I get 'FBXKey file path is empty' as an error and can't proceed. It obviously wants the Decrypt Key File but none is being generated. I'm on CC3.4 Pipeline.
Is there some additional setting I need to tick?
https://forum.reallusion.com/uploads/images/bb3cdd8f-c17f-4d7f-a463-7a82.png
