Undesired added spring effect to static bone
Posted By melkione 4 Years Ago
melkione
melkione
New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)
Posts: 3, Visits: 32
Hi all,
i'm a new Iclone and 3DExchange user.  And I have an issue with my first 3DExchange usage.
I exported an animation from my Unreal project :
https://forum.reallusion.com/uploads/images/22262305-f0ef-4d36-8477-e352.gif
It is just a cycling animation. Both hands are fixed so has to keep in place with my handbar.
But when I import the animation in 3DExchange both hands spring and bounce and I don't know how to solve it.  I saw something about adding a key with spring effect at OFF but it does not change anything :
https://forum.reallusion.com/uploads/images/113b40e8-59b5-4a64-b9a9-3527.gif
I'm sure it is just a small issue but I do not find any solution .
Someone of you have an idea ??
Thanks a lot in advance :)
lianchiu
lianchiu
Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)
Posts: 214, Visits: 1.5K
melkione (3/10/2021)
Hi all,
Could you show what is look like in 3DX?
melkione
melkione
HI,
Yes it already bounce in 3DExchange as you can see :
https://forum.reallusion.com/uploads/images/ee6318e9-8b6a-4c90-9a62-dbbc.gif
I just tried to add Reach Target as I saw in a Reallusion youtube video.
https://forum.reallusion.com/uploads/images/07c63fe6-5bc9-4e4b-9715-1438.gif
Thanks for your help.
melkione
melkione
Hi all, I succeded to fix hands on handbar by parent the hands reach dummys under the BMX element.
Now both hands do not move.
But I still have the issue when I try to export FBX animation so as to use it in unreal. After export hands still bounce like in 3DX.
Any idea so as to solve it in a different way or may be to export it so as to keep hands fixed in place after fbx export?
Thank you :)
