Undesired added spring effect to static bone
https://forum.reallusion.com/Topic475535.aspx
Print Topic | Close Window
By melkione - 5 Years Ago
Hi all,
i'm a new Iclone and 3DExchange user.  And I have an issue with my first 3DExchange usage.
I exported an animation from my Unreal project :
https://forum.reallusion.com/uploads/images/22262305-f0ef-4d36-8477-e352.gif
It is just a cycling animation. Both hands are fixed so has to keep in place with my handbar.
But when I import the animation in 3DExchange both hands spring and bounce and I don't know how to solve it.  I saw something about adding a key with spring effect at OFF but it does not change anything :
https://forum.reallusion.com/uploads/images/113b40e8-59b5-4a64-b9a9-3527.gif
I'm sure it is just a small issue but I do not find any solution .
Someone of you have an idea ??
Thanks a lot in advance :)
By lianchiu - 5 Years Ago
melkione (3/10/2021)
Hi all,
Could you show what is look like in 3DX?
HI,
Yes it already bounce in 3DExchange as you can see :
https://forum.reallusion.com/uploads/images/ee6318e9-8b6a-4c90-9a62-dbbc.gif
I just tried to add Reach Target as I saw in a Reallusion youtube video.
https://forum.reallusion.com/uploads/images/07c63fe6-5bc9-4e4b-9715-1438.gif
Thanks for your help.
Hi all, I succeded to fix hands on handbar by parent the hands reach dummys under the BMX element.
Now both hands do not move.
But I still have the issue when I try to export FBX animation so as to use it in unreal. After export hands still bounce like in 3DX.
Any idea so as to solve it in a different way or may be to export it so as to keep hands fixed in place after fbx export?
Thank you :)
