Victor.Soupday
Victor.Soupday
Visits: 9.0K
See if 1.5.8.1 fixes it? Version 1.5.8.1: Github: Github Project Page - Releases Changelog: 1.5.8.1
- Fixes:
- Fix to empty transforms or deleted objects in export.
- Fix to transfer vertex weights leaving working copies behind.
- Some object management UI corrections.
Victor.Soupday
Victor.Soupday
Visits: 9.0K
jeff.davies
jeff.davies
Visits: 1.5K
ThanksVictor. I did have empties in the model because in Blender I need to animate the hair like snakes on a medua head. I did upgrade to 1.5.8.1 just now and when I try to export I get the error message shoown in the screenshot below. I think I'm good to go though because I can do the humanoid part of the animations in iC8 and then retarget that part to my Blender rig. I can then animate the "hair" seperately in Blender.
- Jeff The Adventures of Capt Sanchez Cybernautic Studios
Victor.Soupday
Victor.Soupday
Visits: 9.0K
jeff.davies (4/18/2023) ThanksVictor. I did have empties in the model because in Blender I need to animate the hair like snakes on a medua head. I did upgrade to 1.5.8.1 just now and when I try to export I get the error message shoown in the screenshot below. I think I'm good to go though because I can do the humanoid part of the animations in iC8 and then retarget that part to my Blender rig. I can then animate the "hair" seperately in Blender.
Found the problem. Used the wrong path variable for baking material textures for materials added after converting from generic. Try 1.5.8.2: https://github.com/soupday/cc_blender_tools/releases/tag/1_5_8_2
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
Victor.Soupday (4/18/2023)
Hi Victor, Thanks for the tutorial,👍👍👍 I've tried it a bit, it's a pity that it takes so long to bake. Will continue tomorrow. I guess I need a new PC. May I ask what kind of PC system you have.? Greetings Robert
Victor.Soupday
Victor.Soupday
Visits: 9.0K
rosuckmedia (4/19/2023)Hi Victor, Thanks for the tutorial,👍👍👍 I've tried it a bit, it's a pity that it takes so long to bake. Will continue tomorrow. I guess I need a new PC. May I ask what kind of PC system you have.? Greetings Robert I don't have that powerful a system compared to some. Ryzen 5600X and a 3060. The baking takes a long time. In the video the bake took about 7 minutes for that 14 second clip. Mostly because of the subdivision in the cloth. Without the subdivision it takes around 2 minutes. The subdivision is only needed because the meshes I was using were quite low poly. If your cloth meshes are already high resolution, don't subdivide. Each subdivision level effectively quadruples the bake time. Edit: Also Blender 3.5 bakes physics a lot faster than previous versions, so upgrade to that if you haven't already.
jeff.davies
jeff.davies
Visits: 1.5K
Victor.Soupday (4/19/2023)
3.5 bakes physics a lot faster than previous versions, so upgrade to that if you haven't already. Awesome to know! Thanks Victor!
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
rosuckmedia (4/19/2023)Hi Victor, Thanks for the tutorial,👍👍👍 I've tried it a bit, it's a pity that it takes so long to bake. Will continue tomorrow. I guess I need a new PC. May I ask what kind of PC system you have.? Greetings Robert Edit: Also Blender 3.5 bakes physics a lot faster than previous versions, so upgrade to that if you haven't already. Hello Victor, Thanks for the information. I tried it with Blender 3.5. Here's a little test. Greetings Robert
Victor.Soupday
Victor.Soupday
Visits: 9.0K
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
That looks awesome , Victor 👍
