Posted By Victor.Soupday 5 Years Ago
Rated 4.8 stars based on 17 votes.
Victor.Soupday
Victor.Soupday
Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)
Posts: 569, Visits: 9.0K
CC/iC Blender Tools 2.1.11
Github:
Online Documentation:
Blender Auto Setup Add-on:
CC/iC Blender Pipeline Plug-in:
Product Page
Documentation
Release Version
CC4 / iC8 Version
CC3 Version
Release Notes
Changelog:
2.1.11
  • Character Management functions - CCiC Create > Character Management:
    • Transfer weights supports split body meshes.
    • Voxel head diffuse skinning (if installed) button for selected character meshes.
    • Clean Empty Data: Removes empty shape keys and empty vertex groups from the character meshes.
    • Blend Body Weights: Blends body vertex weights with existing vertex weights on selected objects based on distance from the surface of the body, to correct vertex weighting for clothing items that don't conform correctly to the body, e.g. from Voxel Heat Diffusion weights or from Daz original weights.
  • New scene presets added:
    • Scene view transform and world background strength controls added.
2.1.10
  • Sets up Rigidbody physics when appending a character from another library blend file via the Append button in the import panel.
    • Note: Rigidbody physics does not work with linked character overrides.
  • Export non-standard character fix.
  • Support for split meshes when exporting, rebuilding materials, physics & rigging:
    • Any mesh separated or duplicated from a source character mesh will be considered part of the character and an extension of that object.
    • For split body meshes, the mesh with the head will be used as the source for facial expression drivers and wrinkle map drivers.
    • Note: Split body meshes will not import back into CC4 as standard CC3+ characters.
  • Added buttons to rebuild and to remove just the expression and bone drivers to the Character Build Settings panel.
2.1.9
  • Maintain operator context for scene operations.
  • Align to view distance fix.
2.1.8
  • Fixes to view 3d shading context in 4.2.
  • Imported objects, materials, images and actions detection no longer uses tags.
  • Added more checks to skip null material slots.
2.1.7
  • Sync lights includes Scene IBL from CC/iC visual settings.
  • Export to CC3/4 button fixed.
  • Added extra checks for AccuRig / ActorScan when unknown humanoids detected.
2.1.6
  • Import supports multiple file selection.
    • To import multiple objects from a folder, press shift + select the FBX files in the importer file selection window.
  • Fixes for blender version before 4.0:
    • Replace mesh OBJ export.
    • Rigging bone layer assignment.
    • Property collection clear.
    • Rigging widget control scale.
2.1.5
  • Proportion edit should work on all character types (except Rigified)
  • Sync lights and send pose should work in all modes and keeps the active mode.
  • Lighting brightness adjust slider.
  • Some GameBase detection fixes.
  • GameBase skin roughness tweaks.
  • Fix for vertex color sampling when json data is missing.
2.1.4
  • Datalink receive Update / Replace function, to replace whole characters or selected parts.
  • Fix to character validation and clean-up.
2.1.3
  • Motion Set UI errors fixed.
  • Eevee-Next SSR Eyes fixes.
  • Iris brightness render settings for Eevee & Cycles.
  • Bake fixes for Blender 4.2 refractive eyes.
  • Export-Bake warnings when not build for Eevee.
  • Lighting tweaks.
2.1.2
  • Blender 4.2 lighting settings fixes and adjustments.
    • Eevee-Next Raytracing, shadows and shadow jitter enabled on render settings and lights.
    • Blender 4.0+ lighting presets use AgX.
  • Eevee & Cycles global material options.
    • Control of SSS weights, roughnes power and normals for various material types.
2.1.1
  • Fix UDIM flattening on proportion editing and sculpt base mesh transfer.
  • Lighting sync area correction.
  • Datalink plugin version compatibility check.
2.1.0
  • Motion Sets:
    • Action name remapping and retargetting overhaul.
    • Motion set functions: Load/Push/Clear/Select/Rename/Delete
    • Motion prefix and use fake user option added for all animation retargeting and import.
    • Motion set filter and motion set info function.
  • NLA Tools:
    • NLA Bake functions moved to NLA editor panel.
    • Motion set panel in rigging and NLA editor and Datalink.
    • NLA strip alignment and sizing utility functions.
  • Fixes:
    • Duplicating character no longer duplicates actions.
    • Store object state checks objects/materials exist.
    • Positioning fixes with rigify
2.0.9
  • Datalink:
    • Datalink main loop stability improvements.
    • Live sequence back to CC4/iClone takes facial expression bone rotations into account.
    • Live Sequence stop button.
    • Replace mesh function: Quickly send (non topology changing) mesh alterations back to CC4.
    • Update material & texture function: Send selected material data and textures back to CC4.
    • Sync lighting recalculations.
  • Export:
    • Restores armature and object states after export.
    • Fix to baking custom Diffuse Map channel.
  • Fix to Blender 3.4-3.6 Eevee subsurface color.
  • Material Parameter controls disabled for linked characters (unless library override).
2.0.8
  • Import/Export:
    • Fix to Update Unity Project being greyed out after saving as Blend file.
    • Fix to export non-standard character.
    • Fix to export non-standard ARP rigged character.
    • (Blender 4.0+) Fix to reverting object and material name changes on export and other force name changes.
    • Generic character/prop import expanded to support USD/USDZ.
    •  Rigify export now have choice of naming system:
      • Metarig names (without Root bone) for exporting animations back into CC/iC.
      • CC Base names (with Root bone) for exporting to Unity Auto-setup.
    • Rigified characters/motion exports now generate custom HIK profile which can be used to import/convert Rigified motion exports into CC/iC.
    • Datalink Rigified characters (optionally) disable tweak bones as they are not compatible with CC/iC animation.
  • Scene tools:
    • Scene lighting presets overhauled.
    • Added function to align any object to view location and orientation (useful for placing lights and cameras).
    • Added function to add a camera at current view location and orientation.
    • Added function to setup a main face tracking camera centered on character's head.
    • Added function to convert current view studio lighting into world lighting node setup.
  • Rigify:
    • Fix to GameBase detection.
    • Fix to AccuRig generation code not being recognized as valid Rigify target.
    • Fix to support Mixamorigs with suffix numbers in retargeting.
    • Auto-retarget toggle added to automatically retarget any animation on character when using Quick Rigify.
  • Shaders:
    • Skin, eye and hair shaders updated to use Blender 4.0+ Random Walk (Skin) Subsurface Scattering.
    • Displacement map (if present) will be used on skin materials for bump and mesh displacement.
    • Cycles subsurface calculations and parameters tweaked.
    • Separate cycles modifiers for Blender 3.4-3.6 and 4.0+.
    • Eye Sclera color tint added.
    • Cycles Tearline shader reworked.
    • Character edit function added.
    • Character duplicate function added (duplicates character objects and meta-data so can be used and configured independently).
    • Character tools (select/rigify/convert/delete/duplicate), also sub-panel in Datalink.
    • Convert to accessory fix.
  • Datalink:
    • Added Receiving prop posing and animation live sequence.
    • Added custom prop rig control bones when sending through datalink.
    • Added Direct Motion Transfer from CC/iC (automatic motion export->import).
    • Added "Go iC" button to send (just props for now) back to iClone.
2.0.7
  • Attempts to restore datalink when reloading linked blend file.
  • All returning datalink operators will attempt to first reconnect if not connected.
  • Facial expressions included in datalink send pose and sequence. (But not visemes)
    • Currently certain expression bone movements are conflicting with existing bone movements.
    • You may wish to avoid the Head_Turn expressions as a consequence.
  • Character Proportion editing mode added to CC/iC Create panels.
  • Spring bone hair binding will add an armature modifier for the hair object if absent, to allow binding for newly created hair mashes.
  • Scale body weights now acts on the normalized existing hair weights.
2.0.6
  • Restored Rigify retarget limb correction utilities.
  • Fix to Blender 4.1 import crash caused by 4.1 removing auto-smoothed normals.
2.0.5
  • Fix to converting generic objects to props.
  • Fix to baking value textures back to CC4 when exporting converted props and humanoids.
  • Datalink data send rate synchronization improvements.
  • Rigify retarget and NLA bake options to bake to FK/IK/Both.
    • Rig FK/IK mode set appropriately, unchanged when baking to 'Both'.
  • Quick FK/IK switch button added to rigify mini-panel.
  • Send Rigified pose or sequence fix.
  • Rigify Jaw alignment changed to -Z.
2.0.4
  • Linking/Appending:
    • Added linking/append functions to auto-link to characters in blend files with full character data and functionality.
    • Added connect function to re-build character data for linked/appended characters.
    • Added custom properties to armatures/meshes and materials to aid re-connection of character data.
    • Rebuilding materials will add this custom data to existing characters.
    • Auto-linked/Re-connected characters can use full add-on functionality i.e. rigging, retargeting, exporting, rebuilding materials, etc...
  • Rigify:
    • Datalink pose retargeting teeth position fix.
    • Eye bone and jaw bone alignments corrected.
    • Face rig jaw constraints adjusted for less lip deformation.
  • Parallax eye shader AO fix.
  • Basic materials SSS fixes.
  • Importing a bad or incompatible mesh should fail more gracefully.
2.0.2
  • Datalink:
    • Lighting and Camera sync.
    • Send Character (Go-CC) back to CC4.
    • Facial expressions and Visemes transferred in the pose and animation sequencing.
    • Animation sequence now writes to rig and shape-key action tracks directly using low level fast keyframing, all at once at the end. Which is much faster, for both native rig and Rigify rig.
    • Sequence rate matching so CC4 doesn't get too far ahead of itself.
    • Supports Morph editing and mesh updating for sending back morph OBJ for automatic morph slider creation in CC4.
  • Subsurface Recalculations (you may need to reset the preferences in the add-on prefs)
  • Export of Hue, Sat, Brightness params to CC4.
  • Fixed SSS material detection.
  • Fixed ActorBuild generation detection and export.
  • HIK and facial profiles copied with character export (if generated by CC4)
  • OBJ import/export fix for Blender 4.0.
  • OBJ import now supports full materials.
  • Fixed T-pose orientation when exporting Rigified animation.
2.0.2
  • Correction to malformed json texture paths when exporting character from CC4 directly to the root of a drive.
  • Disabled image search on FBX importer, should import a little faster now.
2.0.1
  • VRM import fixes.
    • VRM to CC4 export generates HIK profile for auto characterization.
  • Rigify fixes:
    • Face bone roll axis corrections.
    • Tongue bone meta-rig positioning corrections.
    • Teeth bone retargeting corrections.
2.0.0
  • Blender 4.0 support.
  • WIP Experimental Data Link added:
    • Currently in alpha stages, more a proof of concept at the moment.
  • Bake add-on updated and merged into this project.
Original Post
Setting up the materials in Blender was becoming quite time consuming and it's way to easy to make mistakes so a few weeks ago I thought I would try and speed it up with some python scripting as I'd written a few python scripts for Blender years ago and they weren't too terrible.
Over time I got entirely too carried away with it and my little helper script grew into a full blown add-on with a UI and import/export functions and such. As I have a tendency to keep building and building and never really finishing with these types of projects they usually never see the light of day and end up collecting dust in some darkened corner of my hard drive, so I'm releasing it now and if anyone is interested they can try it out and see if it's any use to them.
For the moment this is mostly for setting up materials, but I've made a start at importing / exporting for character morphs and accessories which works(ish), but needs specific export settings from CC3, which are outlined in the readme.
I must stress this is very much an alpha version and still work in progress. It's Blender and it's running my janky code so expect bugs. It works they way I use it, so far, and with the character exports I have tested it with, but any expected conditions could cause it to go wrong.
This is for Blender 2.83+. Tested in 2.83 and 2.92, 3.0, 3.0.1 and 3.1
And I've made a quick demo video of installing and testing the add-on with some cheesy music:
Threaded View
Threaded View
Forum Post Blender Auto Setup By Victor.Soupday ( 5 Years Ago )
Forum Post Rendering A quick rendering test video using the add-on to quickly... By Victor.Soupday ( 5 Years Ago )
Forum Post This is simply amazing! Your plugin is probably a prototype of what... By 4u2ges ( 5 Years Ago )
Forum Post This is indeed great for those that are not Blender experts (like me)... By animagic ( 5 Years Ago )
Forum Post Wow! Thanks a lot for great addon! By Anna Mironova ( 5 Years Ago )
Forum Post @Victor.Suopday Wow :) :) that's great Many Thanks My first Test.... By rosuckmedia ( 5 Years Ago )
Forum Post This is truly amazing!! Although it only partially works with Daz... By AutoDidact ( 5 Years Ago )
Forum Post I'll have a play with Daz conversion, see what it's doing differently... By Victor.Soupday ( 5 Years Ago )
Forum Post Hi ,just FYI I only used texures converted from the earlier versions... By AutoDidact ( 5 Years Ago )
Forum Post wow, this is great, I've been just testing it a little bit and it... By oonabe ( 5 Years Ago )
Forum Post The add-on is meant to used as a sort of staging area for working on... By Victor.Soupday ( 5 Years Ago )
Forum Post This is really nice, I missed that setting with the automatic... By oonabe ( 5 Years Ago )
Forum Post @Victor, thanks for the tip on disabling auto lighting as I... By AutoDidact ( 5 Years Ago )
Forum Post Hi Just a quick update to correct my hasty assertion that there was... By AutoDidact ( 5 Years Ago )
Forum Post This is GREAT, can't wait to try it. Thanks so much. :) By Pollux ( 5 Years Ago )
Forum Post Just want to say "WOW" !!! damn this is rly good. I... By snatolukas32 ( 5 Years Ago )
Forum Post Free & working with 2.92 By AutoDidact ( 5 Years Ago )
Forum Post I only have basic knowledge of Blender. It's fun to test with this... By rosuckmedia ( 5 Years Ago )
Forum Post 1. You should take money for that... By snatolukas32 ( 5 Years Ago )
Forum Post Maybe, when it's more stable and more finished, I might put it on... By Victor.Soupday ( 5 Years Ago )
Forum Post You can allways create some patreon or anything like this or some more... By snatolukas32 ( 5 Years Ago )
Forum Post [quote]I'm currently working on using the PhysX weight maps to... By 4u2ges ( 5 Years Ago )
Forum Post One extremely important thing to remember with Blender cloth... By AutoDidact ( 5 Years Ago )
Forum Post [quote] I tired Blender physx on CC characters and it was OK but not... By Victor.Soupday ( 5 Years Ago )
Forum Post Great info Victor!!👍👍👍 By AutoDidact ( 5 Years Ago )
Forum Post +1 Thanks. Great stuff. Modifier then. Never knew. :) By 4u2ges ( 5 Years Ago )
Forum Post Putting it all together, here is a test animation using the cloth... By Victor.Soupday ( 5 Years Ago )
Forum Post @Victor Soupday Your Blender addon is great, :) :) It would be... By rosuckmedia ( 5 Years Ago )
Forum Post short body motion Render: Eevee time for frame: 4 secs. any Physcis:... By snatolukas32 ( 5 Years Ago )
Forum Post [quote]So actually we are able right now tu use PhysX for clothing... By Victor.Soupday ( 5 Years Ago )
Forum Post I just installed this in Blender, and it looks great! I'm new to both... By hkhaneveer ( 5 Years Ago )
Forum Post [quote][b]hkhaneveer (3/17/2021)[/b][hr]I just installed this in... By 4u2ges ( 5 Years Ago )
Forum Post [quote] 2. This is most likely the cause. You might need to reapply... By Victor.Soupday ( 5 Years Ago )
Forum Post For some cloth items you have to do it more than once :Whistling: Do... By 4u2ges ( 5 Years Ago )
Forum Post Ok, it's not a bug, I know what it is now. Some clothing items... By Victor.Soupday ( 5 Years Ago )
Forum Post Thanks, you two. Only now I have more issues.... First, the CC3... By hkhaneveer ( 5 Years Ago )
Forum Post I think you could try autorig, which is an add-on that does a lot of... By oonabe ( 5 Years Ago )
Forum Post [quote]First, the CC3 figure's bones don't seem to operate properly in... By Victor.Soupday ( 5 Years Ago )
Forum Post Thank you, M. Soupday. I will try ctrl-P and just applying a Rigify... By hkhaneveer ( 5 Years Ago )
Forum Post acutally if you are talking abt Rigging CC3 character.... (im absolute... By snatolukas32 ( 5 Years Ago )
Forum Post Here is a great Reallusion tutorial on using Blenders Autorig pro... By AutoDidact ( 5 Years Ago )
Forum Post Hey. I can promise (in the future) ill do fully working tutorial... By snatolukas32 ( 5 Years Ago )
Forum Post That's really useful for me. Firstly: The reason the sliders stop... By Victor.Soupday ( 5 Years Ago )
Forum Post @ Victor I agree that the keeping the CC3 bones would be the... By AutoDidact ( 5 Years Ago )
Forum Post [quote][b]Victor.Soupday (3/18/2021)[/b][hr]That's really useful for... By hkhaneveer ( 5 Years Ago )
Forum Post I don't want to get ahead of myself and promise things I can't deliver... By Victor.Soupday ( 5 Years Ago )
Forum Post On a related note- I'm working with quite a few characters, and many... By hkhaneveer ( 5 Years Ago )
Forum Post so yeah its actually working - Eyes movment, Tongue movement, lips... By snatolukas32 ( 5 Years Ago )
Forum Post That's got real potential, you could make custom facial expressions... By Victor.Soupday ( 5 Years Ago )
Forum Post thats the point. I think the posibilites are Limitless when can... By snatolukas32 ( 5 Years Ago )
Forum Post I am wondering the mouth is slightly open when I import to Blender,... By lianchiu ( 5 Years Ago )
Forum Post I know what's happening there: it's to do with negative morphs:... By Victor.Soupday ( 5 Years Ago )
Forum Post So I think version 0.2.2 is just about ready... (in that it hasn't... By Victor.Soupday ( 5 Years Ago )
Forum Post Thumbs up @Victor.Soupday You are the man! Actually im working(TRYING... By snatolukas32 ( 5 Years Ago )
Forum Post I'm mostly concerned with setting up the rig. But if there's a... By Victor.Soupday ( 5 Years Ago )
Forum Post And here's a demo of using the add-on with iClone animation and cloth... By Victor.Soupday ( 5 Years Ago )
Forum Post I have tried those other "retargeters" for Blender and quickly... By AutoDidact ( 5 Years Ago )
Forum Post Yo. Im not quite sure you correctly understand Us AutoDidact - the... By snatolukas32 ( 5 Years Ago )
Forum Post I understand ... your preference is for using rigify rigs and... By AutoDidact ( 5 Years Ago )
Forum Post The whole point of Blender is that there is more than one way of doing... By Victor.Soupday ( 5 Years Ago )
Forum Post Victor, Since I'm not an iClone user, I'm not clear on what exactly it... By hkhaneveer ( 5 Years Ago )
Forum Post To get characters back into CC3 you can't make any changes to the... By Victor.Soupday ( 5 Years Ago )
Forum Post [quote][b]Victor.Soupday (3/22/2021)[/b][hr]To get characters back... By hkhaneveer ( 5 Years Ago )
Forum Post Thank you very much sharing this auto-setup addon for Blender! This is... By Smit_R ( 5 Years Ago )
Forum Post Eyes, Lungs, Pancreas. So many snacks, so little time.... I actually... By snatolukas32 ( 5 Years Ago )
Forum Post I like the fact that the tools envision different workflows, thus... By animagic ( 5 Years Ago )
Forum Post This is so cool and can't wait to try it out. Having an easy way to... By e1_scheer ( 5 Years Ago )
Forum Post [quote][b]animagic (3/23/2021)[/b][hr]I like the fact that the tools... By AutoDidact ( 5 Years Ago )
Forum Post Victor we need update :) i tryed New Hair system, export Character... By snatolukas32 ( 5 Years Ago )
Forum Post I know I'm being greedy, but iis it possible using this plugin to... By e1_scheer ( 5 Years Ago )
Forum Post [quote][b]e1_scheer (3/25/2021)[/b][hr]I know I'm being greedy, but... By Victor.Soupday ( 5 Years Ago )
Forum Post That worked a treat and makes the whole process to blender and back a... By e1_scheer ( 5 Years Ago )
Forum Post That's really good to know, e1_scheer. I kind of prefer the autorig... By hkhaneveer ( 5 Years Ago )
Forum Post [quote][b]snatolukas32 (3/24/2021)[/b][hr]Victor we need update :) i... By Victor.Soupday ( 5 Years Ago )
Forum Post Damn nice one , with your new update, Even beauty CC3 hairs/brows... By snatolukas32 ( 5 Years Ago )
Forum Post New Release Version 0.4.1 Version 0.4.1 at Github Changelog: Hair... By Victor.Soupday ( 5 Years Ago )
Forum Post Render time Here are some of my characters rendered with the new... By Victor.Soupday ( 5 Years Ago )
Forum Post Very well done Victor. Thumbs up! By 4u2ges ( 5 Years Ago )
Forum Post great as always, going to test it right now :) By oonabe ( 5 Years Ago )
Forum Post This is really good Victor. I'll try the new version this weekend.... By Pollux ( 5 Years Ago )
Forum Post Thank you again for this victor..truly a pipeline enhancer😊 By AutoDidact ( 5 Years Ago )
Forum Post New version: 0.5.2 -... By Victor.Soupday ( 5 Years Ago )
Forum Post This is the Biggest One in 2021 ! great job as allways ! <3 ps.... By snatolukas32 ( 5 Years Ago )
Forum Post This is like a dream come true. Thanks. By tcheng00 ( 5 Years Ago )
Forum Post Hi. I downloaded and installed the latest version of your plugin, and... By Colonel_Klink ( 5 Years Ago )
Forum Post [quote] Hi. I downloaded and installed the latest version of your... By Victor.Soupday ( 5 Years Ago )
Forum Post Gah!... Got it sorted. Seems I was importing the files wrong into... By Colonel_Klink ( 5 Years Ago )
Forum Post Greetings Victor.Soupday and everyone, This is a great add-on, thank... By Mythcons ( 5 Years Ago )
Forum Post create your accessories in blender and using blenders .obj exporter.... By AutoDidact ( 5 Years Ago )
Forum Post The 'export as accessory' doesn't do anything special, it just invokes... By Victor.Soupday ( 5 Years Ago )
Forum Post [quote][b]Victor.Soupday (6/8/2021)[/b][hr]The 'export as accessory'... By Mythcons ( 5 Years Ago )
Forum Post I think I figured out the issue. When the plugin triggers the... By Mythcons ( 5 Years Ago )
Forum Post That's a big whups on my part. It uses the same extention as the... By Victor.Soupday ( 5 Years Ago )
Forum Post [quote][b]Victor.Soupday (6/9/2021)[/b][hr]That's a big whups on my... By Mythcons ( 5 Years Ago )
Forum Post Does this not suport cycles? I'm getting strange bugs when I use... By dizzidiz ( 5 Years Ago )
Forum Post Try turning off the Smart hair, Eevee highlights and fake bump in the... By Victor.Soupday ( 5 Years Ago )
Forum Post Nice, some very well deserved recognition in here:... By oonabe ( 5 Years Ago )
Forum Post Indeed! By AutoDidact ( 5 Years Ago )
Forum Post I may need a drink. :) Or two. By Victor.Soupday ( 5 Years Ago )
Forum Post I tryed to import a character to blender with this and copied all... By habban ( 5 Years Ago )
Forum Post [quote][b]habban (6/23/2021)[/b][hr]I tryed to import a character to... By animagic ( 5 Years Ago )
Forum Post [quote][b]habban (6/23/2021)[/b][hr]I tryed to import a character to... By Victor.Soupday ( 5 Years Ago )
Forum Post @Victor Soupday, Hello, The Addon is great,you are a master. Many... By rosuckmedia ( 5 Years Ago )
Forum Post "What are you trying to achieve by doing that? The Digital Human Skin... By habban ( 5 Years Ago )
Forum Post [quote][b]habban (6/24/2021)[/b][hr]"What are you trying to achieve by... By oonabe ( 5 Years Ago )
Forum Post [quote][b]oonabe (6/27/2021)[/b][hr][quote][b]habban... By habban ( 5 Years Ago )
Forum Post [quote][b]habban (6/24/2021)[/b][hr] Thanks for the information! I... By oonabe ( 5 Years Ago )
Forum Post [quote][b]Victor.Soupday (6/24/2021)[/b][hr] Importing characters back... By 4u2ges ( 5 Years Ago )
Forum Post [quote][b]4u2ges (7/15/2021)[/b][hr][quote][b]Victor.Soupday... By Victor.Soupday ( 5 Years Ago )
Forum Post I am curious and interested about this! So as we know the export from... By regulusfen ( 5 Years Ago )
Forum Post Watch the videos Install the plugin and examine the nodes. By AutoDidact ( 5 Years Ago )
Forum Post Okay, so right out of the box, this addon works and it works really... By regulusfen ( 5 Years Ago )
Forum Post This looks amazing! I simply cant wait to try it out, Im a new CC3... By togu3d ( 5 Years Ago )
Forum Post Hello, Did anyone facing this error in blender 2.93 and 2.92 ?!!... By ExaRoll Studio ( 5 Years Ago )
Forum Post Going by that traceback, Blender's own FBX importer is crashing. If... By Victor.Soupday ( 5 Years Ago )
Forum Post I haven't been active for a bit, but when I saw the promo for a... By MatCreator ( 5 Years Ago )
Forum Post FT 8011:... By 4u2ges ( 5 Years Ago )
Forum Post [quote]If I were to guess, I would think CC3 looks for a certain fbx... By 4u2ges ( 5 Years Ago )
Forum Post Honeslty guys I am not understanding how the inability to bring... By AutoDidact ( 5 Years Ago )
Forum Post Blender is a popular and second to none app for those who cannot... By 4u2ges ( 5 Years Ago )
Forum Post Blender or not, FBX import into iClone (and I guess CC) is highly... By animagic ( 5 Years Ago )
Forum Post [quote][b]animagic (7/15/2021)[/b][hr]Blender or not, FBX import into... By 4u2ges ( 5 Years Ago )
Forum Post [quote]There some who still prefer to work within RL eco system -... By AutoDidact ( 5 Years Ago )
Forum Post Update 0.7.1 Back... By Victor.Soupday ( 5 Years Ago )
Forum Post Using the latest version of the blender plugin, it's GREAT! I just... By letsdothis ( 5 Years Ago )
Forum Post More transparency bounces: By Victor.Soupday ( 5 Years Ago )
Forum Post RE: More transparency bounces Thanks Victor I will try that out. By letsdothis ( 5 Years Ago )
Forum Post Hey Victor, first of all, thanks a lot for the update. I wanted to ask... By oonabe ( 5 Years Ago )
Forum Post It picks up on whatever alpha settings the fbx importer sets for the... By Victor.Soupday ( 5 Years Ago )
Forum Post there is a way to make my weight map of my custom cloth in blender and... By sylvain@artanim ( 5 Years Ago )
Forum Post PhysX weightmaps? You have to load them in manually in CC3 once... By Victor.Soupday ( 5 Years Ago )
Forum Post Sorry i was talking about skin weight By sylvain@artanim ( 5 Years Ago )
Forum Post That requires importing back as fbx, with the fbxkey. To bring a... By Victor.Soupday ( 5 Years Ago )
Forum Post thank you victor i will try this on monday By sylvain@artanim ( 5 Years Ago )
Forum Post I only wanted to say that after learning a little bit more on how to... By oonabe ( 5 Years Ago )
Forum Post Hi all, I'm experiencing a weird issue when I try to import a... By Smit_R ( 5 Years Ago )
Forum Post It probably hasn't detected it as hair properly. As there is no... By Victor.Soupday ( 5 Years Ago )
Forum Post Thank you for your answer, but here's the weird part. I did all what... By Smit_R ( 5 Years Ago )
Forum Post Somethings clearly going wrong. Can you post some screenshots of the... By Victor.Soupday ( 5 Years Ago )
Forum Post Yeah, off course. Here are the screenshots.I can also send you the... By Smit_R ( 5 Years Ago )
Forum Post I think I know what it is... The material looks right. Everything is... By Victor.Soupday ( 5 Years Ago )
Forum Post Here are the default fbx import shaders. Hair: Scalp: Sidenote:... By Smit_R ( 5 Years Ago )
Forum Post If there were any special UV tiling or offsets the base FBX importer... By Victor.Soupday ( 5 Years Ago )
Forum Post Hi Victor, the imported meshes have just one UV map. :( By Smit_R ( 5 Years Ago )
Forum Post [quote][b]Smit_R (8/5/2021)[/b][hr]Hi Victor, the imported meshes have... By Victor.Soupday ( 5 Years Ago )
Forum Post Is that possible to add tiling to the mix (I know it getting passed to... By 4u2ges ( 5 Years Ago )
Forum Post [quote][b]4u2ges (8/5/2021)[/b][hr]I know it has nothing to do with... By animagic ( 5 Years Ago )
Forum Post [quote][b]4u2ges (8/5/2021)[/b][hr]Is that possible to add tiling to... By Victor.Soupday ( 5 Years Ago )
Forum Post I am starting to sound like a broken record :), but IMO, RL should... By 4u2ges ( 5 Years Ago )
Forum Post [quote][b]4u2ges (8/7/2021)[/b][hr]I am starting to sound like a... By Peter (RL) ( 5 Years Ago )
Forum Post Anyone else getting such error with textures ? I had to go and... By zen.parvez ( 5 Years Ago )
Forum Post actually looks cool =) By oldnewusa ( 5 Years Ago )
Forum Post Pre-release Version 1.0.0 ( Release Link ) Change-log : Moved... By Victor.Soupday ( 5 Years Ago )
Forum Post [quote]Fear not. We have been collaborating with Victor for some time... By 4u2ges ( 5 Years Ago )
Forum Post Hello, could you guys please help me? I am getting this error when I... By SioraFede ( 5 Years Ago )
Forum Post [quote][b]SioraFede (9/12/2021)[/b][hr]Hello, could you guys please... By Victor.Soupday ( 5 Years Ago )
Forum Post Hello, thank you for answering. The character I tried to import was a... By SioraFede ( 5 Years Ago )
Forum Post Oh, that vest in CC has messed up UV and non importable into Blender... By 4u2ges ( 5 Years Ago )
Forum Post Can confirm, the Biker Vest in the Cloth... By Victor.Soupday ( 5 Years Ago )
Forum Post Release: 1.0.2 1.0.2 Fixed Eevee subsurface scattering... By Victor.Soupday ( 5 Years Ago )
Forum Post great update, I didn't even konw there was a cycles/eevee material... By oonabe ( 5 Years Ago )
Forum Post There is no make-up layer or make-up shader. All make up from skin-gen... By Victor.Soupday ( 5 Years Ago )
Forum Post It is weird because after trying different parameteres and changing... By oonabe ( 5 Years Ago )
Forum Post You could try putting a little bit of subsurface in the eyelash... By Victor.Soupday ( 5 Years Ago )
Forum Post Thank you for the useful information and feedback. Now I want to ask... By SioraFede ( 5 Years Ago )
Forum Post is someone else having issues since the latest CC3 / iClone7 updates?... By oonabe ( 5 Years Ago )
Forum Post Yes, my problem is similar to yours, oonabe. I will place a detailed... By amtenorio2000 ( 5 Years Ago )
Forum Post I am doing some animations in iClone 7 designing characters in CC3... By amtenorio2000 ( 5 Years Ago )
Forum Post Multiple character exports from iClone have never worked well, because... By Victor.Soupday ( 5 Years Ago )
Forum Post thanks for the hint, exporting the characters one by one solved the... By oonabe ( 5 Years Ago )
Forum Post Hi guys. Im just courius, i made some facial animation(+Head) and... By oldnewusa ( 5 Years Ago )
Forum Post The old legacy hair meshes worked reasonably well with Blender's... By Victor.Soupday ( 5 Years Ago )
Forum Post Lets see... where am I up to? Version 1.1.2 of the Blender Auto-setup... By Victor.Soupday ( 5 Years Ago )
Forum Post Thank you so much for this, I really appriciate it. By Markom3D ( 5 Years Ago )
Forum Post Another reason I use this Blender pipeline tool.... By AutoDidact ( 5 Years Ago )
Forum Post Cel shading sorcery without custom shader nodes... It looks like... By Victor.Soupday ( 5 Years Ago )
Forum Post [quote][b]Victor.Soupday (12/2/2021)[/b][hr]Cel shading sorcery... By AutoDidact ( 5 Years Ago )
Forum Post @AutoDidact: I like the "new look", an interesting departure from what... By animagic ( 5 Years Ago )
Forum Post Thanks Job!😁 By AutoDidact ( 5 Years Ago )
Forum Post Has anyone tried CC Tools in Blender 3.0 now that is officially... By oonabe ( 5 Years Ago )
Forum Post I've tried it, I don't think it's broken. It works for me. Blender... By rosuckmedia ( 5 Years Ago )
Forum Post [quote][b]oonabe (12/4/2021)[/b][hr]Has anyone tried CC Tools in... By Victor.Soupday ( 5 Years Ago )
Forum Post NO issues over here with the Blender pipeline tool. had to update... By AutoDidact ( 5 Years Ago )
Forum Post [quote][b]Victor.Soupday (12/4/2021)[/b][hr][quote][b]oonabe... By oonabe ( 5 Years Ago )
Forum Post Hey everyone i just recently bought CC3+IClone7 bundle and i love the... By Da_Drood ( 4 Years Ago )
Forum Post Peter Alexander still uses an older version of the Blender Auto Setup... By rosuckmedia ( 4 Years Ago )
Forum Post [quote][b]Da_Drood (1/11/2022)[/b][hr]Hey everyone i just recently... By Victor.Soupday ( 4 Years Ago )
Forum Post Posted also in the thread linked below. By any chance would you... By tmbpodcastoffice ( 4 Years Ago )
Forum Post [quote][b]tmbpodcastoffice (1/13/2022)[/b][hr] Posted also in the... By Victor.Soupday ( 4 Years Ago )
Forum Post Baking add-on brought up to date, with a few updates to the main tools... By Victor.Soupday ( 4 Years Ago )
Forum Post Any thoughts on best practices for getting hair structures to work... By tmbpodcastoffice ( 4 Years Ago )
Forum Post That's because Jpegs don't have an alpha channel, so to pack the alpha... By Victor.Soupday ( 4 Years Ago )
Forum Post Thank you for the clarifications! This matches the information I have... By tmbpodcastoffice ( 4 Years Ago )
Forum Post Hi... I'm kinda new to this and not very good. I was wondering if... By BrotherShamus ( 4 Years Ago )
Forum Post [quote][b]BrotherShamus (1/25/2022)[/b][hr]Hi... I'm kinda new to this... By Victor.Soupday ( 4 Years Ago )
Forum Post Hi Victor, Many Thanks for the Physik Tutorial.👍 Greetings... By rosuckmedia ( 4 Years Ago )
Forum Post Hey guys, quick question. What facial expressions can be exported with... By stergiosbiternasv ( 4 Years Ago )
Forum Post [quote][b]stergiosbiternasv (1/28/2022)[/b][hr]Hey guys, quick... By Victor.Soupday ( 4 Years Ago )
Forum Post thank you so much for the fast response! This is some very awesome... By stergiosbiternasv ( 4 Years Ago )
Forum Post Hi. At first. Amazing Tool :-) But since i switched to the newst... By m.schulte ( 4 Years Ago )
Forum Post I checked it again. The last working version is 1.02. After that i get... By m.schulte ( 4 Years Ago )
Forum Post [quote][b]m.schulte (1/30/2022)[/b][hr]I checked it again. The last... By Victor.Soupday ( 4 Years Ago )
Forum Post Will try it tonight and let you know. A character from cc3, with... By m.schulte ( 4 Years Ago )
Forum Post Hi. I tested version 1.1.7. The import takes longer, but it fails... By m.schulte ( 4 Years Ago )
Forum Post Had a feeling more would go wrong, because that first error should... By Victor.Soupday ( 4 Years Ago )
Forum Post Hey. My json is around 161KB. What Eyes? The default from CC3. I... By m.schulte ( 4 Years Ago )
Forum Post Hey. i removed the eyes in cc3 and then re-added them. Then it... By m.schulte ( 4 Years Ago )
Forum Post So frustrated. I followed all instructions and cannot get this to... By Sp3c1alk ( 4 Years Ago )
Forum Post [quote][b]Sp3c1alk (1/31/2022)[/b][hr]So frustrated. I followed all... By Victor.Soupday ( 4 Years Ago )
Forum Post I dont see either By Sp3c1alk ( 4 Years Ago )
Forum Post It seems I don't have the Blender Autosetup in my plug-in section from... By StudioMM ( 4 Years Ago )
Forum Post I tried to use the CC3 > Blender Pipeline with a standard character... By StudioMM ( 4 Years Ago )
Forum Post Hello, I am trying to follow a tutorial to build a cloth, usiing... By babyfoothero ( 4 Years Ago )
Forum Post Sculpt mask extract doesn't like the scaling on the armature. You can... By Victor.Soupday ( 4 Years Ago )
Forum Post Can someone tell me if this blender pipeline will help with what I am... By cstrauss42a ( 4 Years Ago )
Forum Post [quote][b]cstrauss42a (2/7/2022)[/b][hr]Can someone tell me if this... By Victor.Soupday ( 4 Years Ago )
Forum Post Version 1.1.8: (Github Release Page) Texture Channel Mixer... By Victor.Soupday ( 4 Years Ago )
Forum Post I'm trying to edit a purchased Cartoon Base character in Blender with... By StudioMM ( 4 Years Ago )
Forum Post [quote][b]StudioMM (2/12/2022)[/b]... but the 'export to CC3' button... By Victor.Soupday ( 4 Years Ago )
Forum Post Thank you for all your answers and support. It seems I've missed your... By StudioMM ( 4 Years Ago )
Forum Post Version 1.1.9: Github page - Release Page Fixed PBR eye... By Victor.Soupday ( 4 Years Ago )
Forum Post I'm getting pretty desperate. Seems i've been posting issues on the... By StudioMM ( 4 Years Ago )
Forum Post Did you also select everything from the character in the outliner?... By rosuckmedia ( 4 Years Ago )
Forum Post Hi, I now tried it with everything selected in the outliner. No... By StudioMM ( 4 Years Ago )
Forum Post Hi, I think it works for all of us, try it with this Standard... By rosuckmedia ( 4 Years Ago )
Forum Post [quote][b]StudioMM (2/14/2022)[/b][hr]Hi, I now tried it with... By Victor.Soupday ( 4 Years Ago )
Forum Post Thank you! I will give it a try. By StudioMM ( 4 Years Ago )
Forum Post Hi Victor, thanks again for you help and detailed information. That... By StudioMM ( 4 Years Ago )
Forum Post It would be nice if the Blender plugin, and Re Importer Plugin... By rosuckmedia ( 4 Years Ago )
Forum Post [quote][b]StudioMM (2/13/2022)[/b][hr]I'm getting pretty desperate.... By wires ( 4 Years Ago )
Forum Post This plugin is really amazing! But I´d like to make eyebrows similar... By leandromeire ( 4 Years Ago )
Forum Post [quote][b]leandromeire (2/18/2022)[/b][hr]This plugin is really... By Victor.Soupday ( 4 Years Ago )
Forum Post Thank you for you reply, Victor. I tried to fix changing the opacity,... By leandromeire ( 4 Years Ago )
Forum Post Hi guys. After export the character, I have access to expressions by... By leandromeire ( 4 Years Ago )
Forum Post I discovered something about it: if I select the 3D Eyebrow, and... By leandromeire ( 4 Years Ago )
Forum Post [quote][b]leandromeire (2/22/2022)[/b][hr]Hi guys. After export the... By Victor.Soupday ( 4 Years Ago )
Forum Post Ok, Victor. I think it´s not complicated to do in Blender. I´ll try to... By leandromeire ( 4 Years Ago )
Forum Post Thank you very much, Victor, for making such an amazing add-on! I'm a... By BigSkyMG ( 4 Years Ago )
Forum Post [quote][b]BigSkyMG (2/23/2022)[/b][hr]...One issue that I can't seem... By Victor.Soupday ( 4 Years Ago )
Forum Post Thank you for the prompt reply, Victor! Switching to... By BigSkyMG ( 4 Years Ago )
Forum Post Hello! I am desperate for help. We are working with many blend files... By macklawrencefilms ( 4 Years Ago )
Forum Post That's going to take some untangling. I take it everything is purple... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks for getting back to me! Does each blend file come with it's... By macklawrencefilms ( 4 Years Ago )
Forum Post There is no default rule for relative or absolute paths in Blender, it... By Victor.Soupday ( 4 Years Ago )
Forum Post If you are sharing Blender scene files for use on other computers you... By AutoDidact ( 4 Years Ago )
Forum Post Hi. I exported character Sandra to Blender, as I exported the Default... By leandromeire ( 4 Years Ago )
Forum Post The shirtless character I posted earlier on this page has those same... By BigSkyMG ( 4 Years Ago )
Forum Post Hi. Adjust the roughness setting on the body material. That effect... By Colonel_Klink ( 4 Years Ago )
Forum Post [quote][b]Colonel_Klink (3/3/2022)[/b][hr]Hi. Adjust the roughness... By leandromeire ( 4 Years Ago )
Forum Post In this case, there is actually an error in the skin shader... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote][b]Victor.Soupday (3/3/2022)[/b][hr]In this case, there is... By leandromeire ( 4 Years Ago )
Forum Post Dear Victor I just downloaded your plugin yesterday, and it instantly... By jonathan.v.nielsen ( 4 Years Ago )
Forum Post Version 1.2.1: Github page - Release Page Some fixes to... By Victor.Soupday ( 4 Years Ago )
Forum Post I'm having an issue with cc3 exports to blender and rendering with... By Beansupreme ( 4 Years Ago )
Forum Post [quote][b]Beansupreme (3/14/2022)[/b][hr]I'm having an issue with cc3... By Victor.Soupday ( 4 Years Ago )
Forum Post I had a similar issue which I raised on github (... By jeff.davies ( 4 Years Ago )
Forum Post Hey Victor, I'm aoakalin from GitHub that suggested the blend file... By VARTS ( 4 Years Ago )
Forum Post [quote][b]VARTS (3/14/2022)[/b][hr] * Morphs were baked when I did a... By Victor.Soupday ( 4 Years Ago )
Forum Post Ok nice information, good to know what I can and can't do. I will try... By VARTS ( 4 Years Ago )
Forum Post Blender 3.0+ subsurface scattering method set to Christensen-Burley,... By Beansupreme ( 4 Years Ago )
Forum Post @Victor Quick question for you. On the CC3 Import tool in Blender, in... By jeff.davies ( 4 Years Ago )
Forum Post [quote][b]jeff.davies (3/16/2022)[/b][hr]@Victor Quick question for... By Victor.Soupday ( 4 Years Ago )
Forum Post Awesome! Thank you for the clarification. By jeff.davies ( 4 Years Ago )
Forum Post sorry for the double post. I accidentally double-clicked the Post... By jeff.davies ( 4 Years Ago )
Forum Post Version 1.2.2: Github page - Release Page Object Management... By Victor.Soupday ( 4 Years Ago )
Forum Post Dev version test: Rigify conversion... By Victor.Soupday ( 4 Years Ago )
Forum Post Hi! The RealIlusion team directed me to here. They are well aware of... By mellyless ( 4 Years Ago )
Forum Post I'm not sure why this is happening. The top image is a "full" Cycles... By lightbearer ( 4 Years Ago )
Forum Post When you switched to cycles did you rebuild the materials using the... By jeff.davies ( 4 Years Ago )
Forum Post I did use the CC3 add on to rebuild the shader. I have not checked... By lightbearer ( 4 Years Ago )
Forum Post Which version of the add-on are you using? Older versions used to do... By Victor.Soupday ( 4 Years Ago )
Forum Post Using 1.2.2 But I think I figured it out. I had Rebuild Advanced... By lightbearer ( 4 Years Ago )
Forum Post In your opinion, is there a way to keep the flexibility of using the... By lightbearer ( 4 Years Ago )
Forum Post It looks like there either entirely too much subsurface or there's... By Victor.Soupday ( 4 Years Ago )
Forum Post Here is a picture of the node structure, if it helps. I've been... By lightbearer ( 4 Years Ago )
Forum Post Map heading into the shader node was/is designated as sRGB. By lightbearer ( 4 Years Ago )
Forum Post Image created using the Basic Shader. By lightbearer ( 4 Years Ago )
Forum Post @lightbearer Just out of curiosity, what are you using for lighting... By Lord_Dreadmoor ( 4 Years Ago )
Forum Post I'm using an HDRI from PolyHaven.com (formerly HDRIHaven.com), along... By lightbearer ( 4 Years Ago )
Forum Post Blender Auto setup Tool 1.2.2 I have a question about skin tone and... By rosuckmedia ( 4 Years Ago )
Forum Post Hello Victor, I have tested the Blender too to export to Unity and I... By Necka ( 4 Years Ago )
Forum Post Version 1.3.2: Rigify Part 1 Full Image on Artstation... By Victor.Soupday ( 4 Years Ago )
Forum Post +1 Soupday for president of the world! By jeff.davies ( 4 Years Ago )
Forum Post Hey there, I am working with iclone and importing it into blender... By Mitsi.studio ( 4 Years Ago )
Forum Post [quote]Animation Retargeting Animation retargetting is still... By AutoDidact ( 4 Years Ago )
Forum Post [quote][b]AutoDidact (4/14/2022)[/b][hr] Hi victor,... By Victor.Soupday ( 4 Years Ago )
Forum Post hi Folks ! no matter what im setting up , (i guess i missed... By oldnewusa ( 4 Years Ago )
Forum Post It looks like the Eye Occlusion mesh. It's mean to simulate the... By Victor.Soupday ( 4 Years Ago )
Forum Post something went wrong with ammm i guess i screwed something when... By oldnewusa ( 4 Years Ago )
Forum Post Still greyed out for me. I've done everything as you depicted in the... By towlie2110 ( 4 Years Ago )
Forum Post RE: Blender Auto Setup By towlie2110 ( 4 Years Ago )
Forum Post @Victor This is exactly what I was hoping for !!, My Current CC3 to... By AutoDidact ( 4 Years Ago )
Forum Post [quote][b]towlie2110 (4/17/2022)[/b][hr] [/quote] It's hard to make... By Victor.Soupday ( 4 Years Ago )
Forum Post Sorry guys for post under post. But do you have any idea how to... By oldnewusa ( 4 Years Ago )
Forum Post [quote][b]oldnewusa (4/18/2022)[/b][hr]Sorry guys for post under post.... By Victor.Soupday ( 4 Years Ago )
Forum Post Hi, Importing multiple animations as one file, has been... By AutoDidact ( 4 Years Ago )
Forum Post [quote][b]AutoDidact (4/18/2022)[/b][hr] Hi, Importing multiple... By oldnewusa ( 4 Years Ago )
Forum Post Hi, folks. Why am I getting these black eyes in Cycles? The materials... By martinvazquezsoto ( 4 Years Ago )
Forum Post Hard to be sure, but I saw something similar with one of my models a... By jeff.davies ( 4 Years Ago )
Forum Post [quote][b]martinvazquezsoto (4/18/2022)[/b][hr]Hi, folks. Why am I... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote][b]Victor.Soupday... By martinvazquezsoto ( 4 Years Ago )
Forum Post [quote][b]martinvazquezsoto... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks again victor👍... By AutoDidact ( 4 Years Ago )
Forum Post I do all of my animations in iClone and my final renders in Blender... By jeff.davies ( 4 Years Ago )
Forum Post The skin materials do look a bit basic. Have the characters been... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks Victor, Here is a screenshot of my character's Materials... By jeff.davies ( 4 Years Ago )
Forum Post Materials look right, with full textures. So that leaves the... By Victor.Soupday ( 4 Years Ago )
Forum Post I see there is a lot of custom Roughness controls for shaders. But I... By 4u2ges ( 4 Years Ago )
Forum Post Thats an interesting solution 4u2ges. I'll have to play with that in... By jeff.davies ( 4 Years Ago )
Forum Post [quote][b]4u2ges (4/19/2022)[/b][hr]I see there is a lot of custom... By rosuckmedia ( 4 Years Ago )
Forum Post Hi Victor, I spent a few hours ,before sunrise, testing out the... By AutoDidact ( 4 Years Ago )
Forum Post The preview mode binds the rigs together so that whatever is played on... By Victor.Soupday ( 4 Years Ago )
Forum Post But also there should be no foot sliding, especially if the animation... By Victor.Soupday ( 4 Years Ago )
Forum Post Thanks, I ran my tests with some imotions from some old project... By AutoDidact ( 4 Years Ago )
Forum Post Yes, true, that is why I was asking Victor if he can integrate that... By 4u2ges ( 4 Years Ago )
Forum Post RE: Blender Auto Setup By thanhvt_615296 ( 4 Years Ago )
Forum Post [quote][b]thanhvt_615296 (4/20/2022)[/b][hr] [/quote] Wrong version... By Victor.Soupday ( 4 Years Ago )
Forum Post i am not able to install your plugin in cc3 even though i followed the... By thanhvt_615296 ( 4 Years Ago )
Forum Post Sorry Again for Post above Post but this is Rly Important guys. 1.... By oldnewusa ( 4 Years Ago )
Forum Post I've seen that there is a problem with shorter than normal body for... By kanchanpathak4 ( 4 Years Ago )
Forum Post [quote][b]kanchanpathak4 (4/21/2022)[/b][hr]I've seen that there is a... By Victor.Soupday ( 4 Years Ago )
Forum Post Just updated the addon to 1.35 and did some tests with a few exported... By Leodegrance ( 4 Years Ago )
Forum Post Looks really good. Is that rendered with Eevee or Cycles? By animagic ( 4 Years Ago )
Forum Post Rendered in Cycles. Used the plug-in to rebuild the advanced... By Leodegrance ( 4 Years Ago )
Forum Post Quick question Victor, have you done any testing of the plug in with... By jeff.davies ( 4 Years Ago )
Forum Post Well, the plug-in also works like a charm with CC4! :cool: By Smit_R ( 4 Years Ago )
Forum Post Version 1.3.6 : Some more updates to Rigify and some Physics... By Victor.Soupday ( 4 Years Ago )
Forum Post Many Thanks Victor, Here is a small test CC4 Face Expression Render... By rosuckmedia ( 4 Years Ago )
Forum Post [quote][b]Smit_R (5/12/2022)[/b][hr]Well, the plug-in also works like... By Victor.Soupday ( 4 Years Ago )
Forum Post Nice Victor👍 I edited my demo a bit with HDRI Maker Greetings... By rosuckmedia ( 4 Years Ago )
Forum Post Hey. The rigify controls work. basic and advanced with and without... By Mike Giggs ( 4 Years Ago )
Forum Post Victor, for clarification, does the latest build still work with CC3... By AutoDidact ( 4 Years Ago )
Forum Post [quote][b]AutoDidact (5/13/2022)[/b][hr]Victor, for clarification,... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote][b]Victor.Soupday (5/13/2022)[/b][hr][quote][b]AutoDidact... By AutoDidact ( 4 Years Ago )
Forum Post [quote][b]Mike Giggs (5/13/2022)[/b][hr]Hey. The rigify controls work.... By Victor.Soupday ( 4 Years Ago )
Forum Post Thank you. Its working now, By Mike Giggs ( 4 Years Ago )
Forum Post Im just courius what im doing wrong Ver 1.3.6 Body rig is Fine , but... By oldnewusa ( 4 Years Ago )
Forum Post Has it been converted to GameBase or material merged? It uses UV maps... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote][b]Victor.Soupday (5/16/2022)[/b][hr]Has it been converted to... By oldnewusa ( 4 Years Ago )
Forum Post Fixed: The problem was when i Exporting cc3 char. NEVER TICK this... By oldnewusa ( 4 Years Ago )
Forum Post CC/iC Blender Tools 1.3.8 Github: Github Project Page -... By Victor.Soupday ( 4 Years Ago )
Forum Post This is only getting better....and better. Thanks, Victor! By Smit_R ( 4 Years Ago )
Forum Post It sure is getting better. Thanks! I wonder now if there are plans to... By 4u2ges ( 4 Years Ago )
Forum Post I also wonder if it's possible to implement sort of "hybrid" Export... By 4u2ges ( 4 Years Ago )
Forum Post [quote][b]4u2ges (5/22/2022)[/b][hr]It sure is getting better. Thanks!... By Victor.Soupday ( 4 Years Ago )
Forum Post That is just awesome! I love those new buttons in Export and Object... By 4u2ges ( 4 Years Ago )
Forum Post Please add Constraints and Fix the FK Rig components please, thanks By depredor2018 ( 4 Years Ago )
Forum Post @depredor2018 I think you'll need to provide more context in order for... By jeff.davies ( 4 Years Ago )
Forum Post [quote][b]depredor2018 (5/28/2022)[/b][hr]Please add Constraints... By AutoDidact ( 4 Years Ago )
Forum Post [quote][b]depredor2018 (5/28/2022)[/b][hr]Please add Constraints and... By Victor.Soupday ( 4 Years Ago )
Forum Post Alright, thanks for taking the time to explain that. I'm not really... By depredor2018 ( 4 Years Ago )
Forum Post [quote][b]depredor2018 (5/28/2022)[/b][hr]Alright, thanks for taking... By AutoDidact ( 4 Years Ago )
Forum Post Thanks man this helps a ton, I'm going to try one more approach with... By depredor2018 ( 4 Years Ago )
Forum Post Hi,I am doing the following: In CC3 I add accesories by Create... By primalemotiongames ( 4 Years Ago )
Forum Post Hi, I am having difficulty installing the CC4 input file into latest... By Gleneth ( 4 Years Ago )
Forum Post [quote][b]Gleneth (7/18/2022)[/b][hr]Hi, I am having difficulty... By Victor.Soupday ( 4 Years Ago )
Forum Post hi i am having problem with physic in blender in iclone i have done... By thanhvt_615296 ( 4 Years Ago )
Forum Post Ah, exploding hair syndrome. I've seen it a few times. It seems to be... By Victor.Soupday ( 4 Years Ago )
Forum Post i tried that function but it broke and completely different from what... By thanhvt_615296 ( 4 Years Ago )
Forum Post Version 1.4.0: Github: Github Project Page - Releases... By Victor.Soupday ( 4 Years Ago )
Forum Post Thank you very much for your contribution but I see the problem of... By thanhvt_615296 ( 4 Years Ago )
Forum Post @Victor, Thank you for the information and newTutorials 👍 Greetings... By rosuckmedia ( 4 Years Ago )
Forum Post This add-on is amazing and I ALMOST have my CC4/IC8 character imported... By sunriser1116 ( 4 Years Ago )
Forum Post [quote][b]sunriser1116 (7/31/2022)[/b][hr] Import seems to be fine and... By Victor.Soupday ( 4 Years Ago )
Forum Post You never cease to amaze! A quick response and a quick fix. Works... By sunriser1116 ( 4 Years Ago )
Forum Post hello friend I just wanted to ask if there is a fix for the problem of... By thanhvt_615296 ( 4 Years Ago )
Forum Post [quote][b]thanhvt_615296 (8/1/2022)[/b][hr]hello friend I just wanted... By Victor.Soupday ( 4 Years Ago )
Forum Post Blender cloth system only works properly at a scale of about FIVE... By AutoDidact ( 4 Years Ago )
Forum Post CC4 Plugin Update 1.0.9... By Victor.Soupday ( 4 Years Ago )
Forum Post Hi Victor, Many Thanks for the New Update.😀 Greetings rosuckmedia By rosuckmedia ( 4 Years Ago )
Forum Post [YouTube]https://www.youtube.com/watch?v=XFQOrgVcqcw[/YouTube]... By Victor.Soupday ( 4 Years Ago )
Forum Post Hello Victor, this is Great.👍👍 I probably won't be able to do... By rosuckmedia ( 4 Years Ago )
Forum Post I've been thinking of maybe some kind of helper system, like the... By Victor.Soupday ( 4 Years Ago )
Forum Post Yes that would be cool. 👍😀 Greetings rosuckmedia By rosuckmedia ( 4 Years Ago )
Forum Post CC/iC Blender Tools 1.4.4 Github: Github Project Page -... By Victor.Soupday ( 4 Years Ago )
Forum Post @Victor Great, many thx for the Information , and your effort and... By rosuckmedia ( 4 Years Ago )
Forum Post [quote]CC/iC Blender Tools 1.4.4[/quote] Awesome release, Thanks!... By 4u2ges ( 4 Years Ago )
Forum Post Hello! I'm having an issue with the head texture being broken while... By philip_193876 ( 4 Years Ago )
Forum Post Also, one more thing, I realized that when I create a rig for the... By philip_193876 ( 4 Years Ago )
Forum Post [quote][b]philip_193876 (9/7/2022)[/b][hr] Hello! I'm having an issue... By Victor.Soupday ( 4 Years Ago )
Forum Post I noticed after I updated the addon, the settings window still says... By Leodegrance ( 4 Years Ago )
Forum Post [quote][b]Leodegrance (9/7/2022)[/b][hr]I noticed after I updated the... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote][b]Victor.Soupday (9/7/2022)[/b][hr][quote][b]Leodegrance... By Leodegrance ( 4 Years Ago )
Forum Post Ah sorry, it must have been because I was using 3.3. Thanks for the... By philip_193876 ( 4 Years Ago )
Forum Post Hey Victor, I honestly think you are superstar! Your transfer tool... By Trender 3D ( 4 Years Ago )
Forum Post Currently I am using the obj method with udimm imported textures. To... By Mike Giggs ( 4 Years Ago )
Forum Post [quote][b]Mike Giggs (10/20/2022)[/b][hr]Currently I am using the obj... By Victor.Soupday ( 4 Years Ago )
Forum Post Hey y'all, I've had this problem for months now and couldn't get it... By misuta.nout ( 4 Years Ago )
Forum Post Looks like the script is throwing an error and stopping. What does... By Victor.Soupday ( 4 Years Ago )
Forum Post I installed them plugins fresh like two weeks ago, so i'm fairly... By misuta.nout ( 4 Years Ago )
Forum Post I am having trouble with the CC4 Blender Tool Round trip editing. I... By rosuckmedia ( 4 Years Ago )
Forum Post Small update. CC4 Blender Plugin 1.1.2 last version Okay I got it... By rosuckmedia ( 4 Years Ago )
Forum Post The material properties in Red are Blender only properties and don't... By Victor.Soupday ( 4 Years Ago )
Forum Post [quote][b]Victor.Soupday (12/9/2022)[/b][hr]Things like... By General Picture Animation ( 4 Years Ago )
Forum Post I wonder if it's possible to correctly return Displacement and Glow... By 4u2ges ( 4 Years Ago )
Forum Post Hello Victor, thank you very much, I can't find the documentation... By rosuckmedia ( 4 Years Ago )
Forum Post Everytime I import back from Blender, I get this warning, even though... By benjaminpbass ( 4 Years Ago )
Forum Post Not sure what happened, but I am not seeing my post and doing it... By maximum2000 ( 4 Years Ago )
Forum Post [quote][b]maximum2000 (12/26/2022)[/b][hr]Not sure what happened, but... By Victor.Soupday ( 3 Years Ago )
Forum Post Hello! I have noticed that if I GoZ a model from CC to Zbrush, sculpt... By shavonne.w ( 3 Years Ago )
Forum Post I have an error when im trying to import to blender. Material are not... By cxvisualstudio ( 3 Years Ago )
Forum Post It seems that when importing the character from CC4 to blender in ACES... By cxvisualstudio ( 3 Years Ago )
Forum Post [quote][b]cxvisualstudio (1/18/2023)[/b][hr]It seems that when... By Victor.Soupday ( 3 Years Ago )
Forum Post And, Blender wrinkle map system:... By Victor.Soupday ( 3 Years Ago )
Forum Post I'm attempting to update the textures following the steps in this... By ahotch2 ( 3 Years Ago )
Forum Post [quote][b]ahotch2 (2/8/2023)[/b][hr]I'm attempting to update the... By Victor.Soupday ( 3 Years Ago )
Forum Post Oops, my bad. It's this video:... By ahotch2 ( 3 Years Ago )
Forum Post FYI - I tried with Blender 2.93 LTS and it worked flawlessly so I... By ahotch2 ( 3 Years Ago )
Forum Post [quote][b]ahotch2 (2/8/2023)[/b][hr]FYI - I tried with Blender 2.93... By Victor.Soupday ( 3 Years Ago )
Forum Post Version 1.5.4: Github: Github Project Page - Releases... By Victor.Soupday ( 3 Years Ago )
Forum Post Hi Victor, Many Thanks for the information.👍👍 Greetings Robert By rosuckmedia ( 3 Years Ago )
Forum Post Thanks @rocksuckmedia. I'll have Part 3 ready on Monday. Lot's of good... By jeff.davies ( 3 Years Ago )
Forum Post Version 1.5.5: Github: Github Project Page - Releases... By Victor.Soupday ( 3 Years Ago )
Forum Post Hello Victor, Thanks very much,👍 Could you maybe provide an update... By rosuckmedia ( 3 Years Ago )
Forum Post Hithis is a cc3 addon from cc3 and blenderit ok but i want to know... By ahmedabdelazizhd ( 3 Years Ago )
Forum Post [quote][b]ahmedabdelazizhd (3/4/2023)[/b][hr] Hithis is a cc3 addon... By Victor.Soupday ( 3 Years Ago )
Forum Post I have a fresh Blander 3.4 install and I am trying to add the... By BlueMetalVictory ( 3 Years Ago )
Forum Post [quote][b]BlueMetalVictory (3/5/2023)[/b][hr] ...... By Victor.Soupday ( 3 Years Ago )
Forum Post Version 1.5.6: Github: Github Project Page - Releases... By Victor.Soupday ( 3 Years Ago )
Forum Post Version 1.5.7: Github: Github Project Page - Releases... By Victor.Soupday ( 3 Years Ago )
Forum Post Hello, I tried the latest version 1.57, importing a CC4 character via... By Leodegrance ( 3 Years Ago )
Forum Post [quote][b]Leodegrance (3/14/2023)[/b][hr]Hello, I tried the latest... By Victor.Soupday ( 3 Years Ago )
Forum Post It worked. I employed the second fix in the video you posted above.... By Leodegrance ( 3 Years Ago )
Forum Post Hello i am having a problem with the Blender Auto Setup plugin when... By cheyennerobinson_45 ( 3 Years Ago )
Forum Post [quote][b]cheyennerobinson_45 (3/18/2023)[/b][hr]Hello i am having a... By Victor.Soupday ( 3 Years Ago )
Forum Post You are correct. It is missing the files. Not sure why it is not... By cheyennerobinson_45 ( 3 Years Ago )
Forum Post Well this is a curious thing. The only thing I noticed about the Json... By Victor.Soupday ( 3 Years Ago )
Forum Post Thank you so much. That fixed the issue. By cheyennerobinson_45 ( 3 Years Ago )
Forum Post Hi, apologies if I missed it. Using the search feature in this... By Kuddleminski ( 3 Years Ago )
Forum Post They both work on copies of the body mesh and they each generate a... By Victor.Soupday ( 3 Years Ago )
Forum Post Version 1.5.8: Github: Github Project Page - Releases... By Victor.Soupday ( 3 Years Ago )
Forum Post Hello Victor, Thank you for your work and information.👍👍 I look... By rosuckmedia ( 3 Years Ago )
Forum Post Hi Victor, I upgraded to the new version this morning. I have a... By jeff.davies ( 3 Years Ago )
Forum Post [quote][b]jeff.davies (4/17/2023)[/b][hr]Hi Victor, I upgraded to... By Victor.Soupday ( 3 Years Ago )
Forum Post See if 1.5.8.1 fixes it? Version 1.5.8.1: Github: Github... By Victor.Soupday ( 3 Years Ago )
Forum Post [YouTube]https://www.youtube.com/watch?v=UXvfMQkWVeU[/YouTube] By Victor.Soupday ( 3 Years Ago )
Forum Post [quote][b]Victor.Soupday (4/18/2023)[/b][hr]... By rosuckmedia ( 3 Years Ago )
Forum Post [quote][b]rosuckmedia (4/19/2023)[/b] Hi Victor, Thanks for the... By Victor.Soupday ( 3 Years Ago )
Forum Post [quote][b]Victor.Soupday (4/19/2023)[/b][hr] 3.5 bakes physics a lot... By jeff.davies ( 3 Years Ago )
Forum Post [quote][b]Victor.Soupday (4/19/2023)[/b][hr][quote][b]rosuckmedia... By rosuckmedia ( 3 Years Ago )
Forum Post ThanksVictor. I did have empties in the model because in Blender I... By jeff.davies ( 3 Years Ago )
Forum Post [quote][b]jeff.davies (4/18/2023)[/b][hr]ThanksVictor. I did have... By Victor.Soupday ( 3 Years Ago )
Forum Post [quote] [YouTube]https://www.youtube.com/watch?v=7Nr_LADT3yE[/YouTube]... By illuminoctis ( 3 Years Ago )
Forum Post Looks amazing. Looking forward to the tutorials. Thanks for the... By Leodegrance ( 3 Years Ago )
Forum Post [YouTube]https://www.youtube.com/watch?v=Rjpm8AJeoD0[/YouTube] Bit... By Victor.Soupday ( 3 Years Ago )
Forum Post That looks awesome , Victor 👍 By StyleMarshal ( 3 Years Ago )
Forum Post Hi Victor, Great, thanks for the Tutorial, 👍👍 Greetings Robert By rosuckmedia ( 3 Years Ago )
Forum Post [quote][b]Victor.Soupday (4/20/2023)[/b][hr]... By helielfilmz ( 3 Years Ago )
Forum Post You need to use the Scale Body Weights slider when you're binding... By Victor.Soupday ( 2 Years Ago )
Forum Post I installed 1.5.8.3, but I get an error when importing Windows10... By yogdyr ( 3 Years Ago )
Forum Post Whups, that's a bug. Fix in 1.5.8.4:... By Victor.Soupday ( 3 Years Ago )
Forum Post everything worked perfectly! Thank you Victor! By yogdyr ( 3 Years Ago )
Forum Post My first Test with Hair Spring Bones and Wind.... By rosuckmedia ( 3 Years Ago )
Forum Post Enjoying the recent update. Haven't tested the spring bones and... By Leodegrance ( 3 Years Ago )
Forum Post Is it possible to export a mesh made in blender, that has ARKIT... By junckerlucas ( 3 Years Ago )
Forum Post [quote][b]junckerlucas (5/1/2023)[/b][hr]Is it possible to export a... By Victor.Soupday ( 3 Years Ago )
Forum Post Hello everyone, I have just started using CC4 and Blender, and I have... By dev.kh ( 3 Years Ago )
Forum Post [quote][b]dev.kh (5/3/2023)[/b][hr] Hello everyone, I have just... By Victor.Soupday ( 3 Years Ago )
Forum Post Just to clarify Victor's reply about using the add on to import the... By jeff.davies ( 3 Years Ago )
Forum Post I am having an issue when importing back into CC4. The rotation for... By lightbearer ( 3 Years Ago )
Forum Post [quote][b]lightbearer (5/8/2023)[/b][hr] I am having an issue when... By Victor.Soupday ( 3 Years Ago )
Forum Post I think I figured it out. I was using File Export FBX with the Blende... By lightbearer ( 3 Years Ago )
Forum Post Well, I thought I had it. New video below (different character).... By lightbearer ( 3 Years Ago )
Forum Post Version 1.6.0.1: Github: Github Project Page - Releases... By Victor.Soupday ( 3 Years Ago )
Forum Post @Victor.Soupday, CC3 Blender Addon (v1.6.0.3) do not export character... By MercilessPainTrain ( 3 Years Ago )
Forum Post Hi, What is the recommended way to append a set-up character to a new... By Casanuda ( 3 Years Ago )
Forum Post On a similar note, I was wondering how to reselect a previously... By BigSkyMG ( 3 Years Ago )
Forum Post If you set up a character and save it to a ( character source ) blend... By Victor.Soupday ( 3 Years Ago )
Forum Post Thanks for the info. I had a feeling it wouldn't be straight forward.... By Casanuda ( 3 Years Ago )
Forum Post Different question if you don't mind: Do you have a prefered method to... By Casanuda ( 3 Years Ago )
Forum Post Got it. Thank you for the reply! By BigSkyMG ( 3 Years Ago )
Forum Post I'm experiencing weird jitter with the addon when applying "quick... By Beansupreme ( 3 Years Ago )
Forum Post So I figured out the jittering issue after lots of trial and error. It... By Beansupreme ( 3 Years Ago )
Forum Post I set the character to 0 xyz in iclone, then started playing around... By Beansupreme ( 3 Years Ago )
Forum Post [quote][b]Beansupreme (7/30/2023)[/b][hr] So I figured out the... By Victor.Soupday ( 3 Years Ago )
Forum Post [quote][b]Victor.Soupday (7/30/2023)[/b][hr][quote][b]Beansupreme... By Beansupreme ( 3 Years Ago )
Forum Post Blender does something called Visual Keying in it's modifiers and... By Victor.Soupday ( 3 Years Ago )
Forum Post [quote][b]Victor.Soupday (7/30/2023)[/b][hr]Blender does something... By Beansupreme ( 3 Years Ago )
Forum Post I'm having issues with the Blender auto setup. I looked through some... By hcameron90 ( 3 Years Ago )
Forum Post Sounds like you're looking at the python plugin for CC3/CC4. The... By Victor.Soupday ( 3 Years Ago )
Forum Post Thank you soo much! This Helped! By hcameron90 ( 3 Years Ago )
Forum Post With the release of Blender Beta 4.0, I decided to load up a couple of... By Leodegrance ( 3 Years Ago )
Forum Post [quote][b]Leodegrance (10/2/2023)[/b][hr]With the release of Blender... By andrewsdesk ( 3 Years Ago )
Forum Post Mostly want to say thanks for the amazing work on this blender addon,... By animaliok ( 3 Years Ago )
Forum Post Oh yes it does seem to work kinda perfectly, here I've pushed it to... By animaliok ( 3 Years Ago )
Forum Post Hey Victor, i'm a new user in CC4. I've got 15+ years of experience in... By thart3m8 ( 3 Years Ago )
Forum Post [quote][b]thart3m8 (10/23/2023)[/b][hr]Hey Victor, i'm a new user in... By Victor.Soupday ( 3 Years Ago )
Forum Post Another method is just to convert the normal maps into height online,... By animaliok ( 3 Years Ago )
Forum Post [quote][b]animaliok (10/24/2023)[/b][hr]... [/quote] Interesting. I... By Victor.Soupday ( 3 Years Ago )
Forum Post Hi Victor, Your plugin is amazing and worked more or less flawlessly... By mac_tyler ( 3 Years Ago )
Forum Post Hi mac_tyler, I was facing the same hair issue. I fixed it by doing... By fivemmgames ( 3 Years Ago )
Forum Post Just Rebuild the materials under Character Build settings and it will... By kanchanpathak4 ( 3 Years Ago )
Forum Post Hi, I was wondering if it is possible to export just the... By fivemmgames ( 3 Years Ago )
Forum Post Heyo, any updates for Blender 4.0 version? By piotrgajda17 ( 3 Years Ago )
Forum Post [quote][b]piotrgajda17 (11/27/2023)[/b][hr]Heyo, any updates for... By sternbach ( 3 Years Ago )
Forum Post [quote][b]sternbach (11/30/2023)[/b][hr] [quote][b]piotrgajda17... By Victor.Soupday ( 3 Years Ago )
Forum Post Pushed it up to date with Blender 4. There's some data link code in... By Victor.Soupday ( 3 Years Ago )
Forum Post Hi Victor, Thank you very much for the update. (CC4/IC8) I can't... By rosuckmedia ( 3 Years Ago )
Forum Post Hello, here is my first test Data Live Link.IC8 to Blender 4.0.1... By rosuckmedia ( 3 Years Ago )
Forum Post Awesome, thank you very much! It's life saver for me :) By piotrgajda17 ( 3 Years Ago )
Forum Post Hello. I DL'd and put in the cc blender tools for blender 4.01... By echizen78 ( 3 Years Ago )
Forum Post [quote][b]echizen78 (12/4/2023)[/b][hr] Hello. I DL'd and put in... By Victor.Soupday ( 3 Years Ago )
Forum Post Dear Victor. Thank you for your quick reply. I didn't think it... By echizen78 ( 3 Years Ago )
Forum Post Victor, this update with the data live link looks awesome, can't wait... By NCN ( 3 Years Ago )
Forum Post What spring effect is that? The spring rigging or something else? By Victor.Soupday ( 3 Years Ago )
Forum Post I mean this on the spine from iClone, it looks like it's automatically... By NCN ( 3 Years Ago )
Forum Post Live link is so cool. I was just playing around with the Camilla cc4... By Beansupreme ( 3 Years Ago )
Forum Post [quote][b]Beansupreme (12/11/2023)[/b][hr]Live link is so cool. I was... By Victor.Soupday ( 3 Years Ago )
Forum Post Does anyone have an idea why the teeth and tongue are shifting out of... By johnahartman ( 2 Years Ago )
Forum Post Hi Victor, just bumping this up to see if you had any ideas what is... By johnahartman ( 2 Years Ago )
Forum Post [quote][b]elevatelabs (1/6/2024)[/b][hr]Hi Victor, just bumping this... By Victor.Soupday ( 2 Years Ago )
Forum Post Not sure if it's something to do with CC4, the Blender plug-in or a... By Leodegrance ( 2 Years Ago )
Forum Post [quote][b]Leodegrance (1/11/2024)[/b][hr]Not sure if it's something to... By Victor.Soupday ( 2 Years Ago )
Forum Post The problem is there in both Eevee and Cycles (the render above is... By Leodegrance ( 2 Years Ago )
Forum Post [quote][b]Leodegrance (1/11/2024)[/b][hr]The problem is there in both... By Victor.Soupday ( 2 Years Ago )
Forum Post I've just run into the same error with wrinkle maps, everything is up... By hohwproductions ( 2 Years Ago )
Forum Post Hello I having been this trouble: Im trying to import the altered... By alancruz ( 2 Years Ago )
Forum Post Hello. I'm new to the plugin. I'm able to export from CC4 to Blender... By barca-8 ( 2 Years Ago )
Forum Post The parameters in red don't have equivalent settings in CC4's... By Victor.Soupday ( 2 Years Ago )
Forum Post Ok. Thank you. By barca-8 ( 2 Years Ago )
Forum Post I don't use the plugin, so this is a guess. In case you use SkinGen... By animagic ( 2 Years Ago )
Forum Post Hi there, I am having a problem with importing my cc4 character with... By mtscontrolcenter ( 2 Years Ago )
Forum Post I'm having an issue where i export a iclone 8 character with... By Beansupreme ( 2 Years Ago )
Forum Post Hi Victor, I don't know if this is a problem, but I get the... By sternbach ( 2 Years Ago )
Forum Post [quote][b]sternbach (1/25/2024)[/b][hr] Hi Victor, I don't know if... By Victor.Soupday ( 2 Years Ago )
Forum Post [quote][b]Victor.Soupday (1/25/2024)[/b][hr][quote][b]sternbach... By sternbach ( 2 Years Ago )
Forum Post [quote][b]sternbach (1/25/2024)[/b][hr][quote][b]Victor.Soupday... By Victor.Soupday ( 2 Years Ago )
Forum Post [quote][b]Victor.Soupday (1/26/2024)[/b][hr][quote][b]sternbach... By sternbach ( 2 Years Ago )
Forum Post Hello everyone, Blender 4.02 Export Replace Mesh doesn't work for... By rosuckmedia ( 2 Years Ago )
Forum Post I modified a character using the pipeline (made some mods to the hair... By barca-8 ( 2 Years Ago )
Forum Post [quote][b]barca-8 (2/7/2024)[/b][hr]I modified a character using the... By Victor.Soupday ( 2 Years Ago )
Forum Post [quote][b]Victor.Soupday (2/8/2024)[/b][hr] Can confirm this is a... By barca-8 ( 2 Years Ago )
Forum Post I downloaded the latest CCiC-Blender-Pipeline-Plugin-2.0.0.zipI... By cthrower ( 2 Years Ago )
Forum Post I am using the Iclone 8 with the CC3 Blender tools, also configure... By Rodney Costa ( 2 Years Ago )
Forum Post Blender 4.02 Since the last update Blender Pipeline 2.0.4 👍👍👍... By rosuckmedia ( 2 Years Ago )
Forum Post Hi Victor, I was asked to contact you by Rampa at technical support.... By jd_ionson ( 2 Years Ago )
Forum Post Oops, messed up and forgot to quote the original post from jd_ionson. By BigSkyMG ( 2 Years Ago )
Forum Post [quote][b]jd_ionson (3/15/2024)[/b][hr]Hi Victor, I was asked to... By BigSkyMG ( 2 Years Ago )
Forum Post Hi, just a quick question. has the Limb Correction section been... By MonolithVFX ( 2 Years Ago )
Forum Post Hi there, I'm experiencing some issues with retargeting... By Smit_R ( 2 Years Ago )
Forum Post [quote][b]Smit_R (3/18/2024)[/b][hr] Hi there, I'm... By Victor.Soupday ( 2 Years Ago )
Forum Post Small update to fix Blender 4.1 import crash, as they have removed the... By Victor.Soupday ( 2 Years Ago )
Forum Post Hello! Any advice for transferring/matching cameras from Blender... By pretendforreal ( 2 Years Ago )
Forum Post Hey, I want to send animation from blender to CC4 how do i achive that... By warlockadityav ( 2 Years Ago )
Forum Post I cannot get the Blender 2.07 CC add on to even show up in the blender... By gtjr ( 2 Years Ago )
Forum Post [quote][b]gtjr (5/1/2024)[/b][hr]I cannot get the Blender 2.07 CC add... By Victor.Soupday ( 2 Years Ago )
Forum Post that worked thanks. I guess I must have misunderstood the new webinar... By gtjr ( 2 Years Ago )
Forum Post How to download this?? Sorry new here not able to understand it. By adv.ysharma7 ( 2 Years Ago )
Forum Post I meant to ask this for a long time... We have a button "Export... By 4u2ges ( 2 Years Ago )
Forum Post [quote][b]4u2ges (6/2/2024)[/b][hr]I meant to ask this for a long... By Victor.Soupday ( 2 Years Ago )
Forum Post Utterly awesome (and speaking about timing :D )! Gave me a chance to... By 4u2ges ( 2 Years Ago )
Forum Post Just tested the latest version of the plug-in (2.09) and transferred a... By Leodegrance ( 2 Years Ago )
Forum Post Doesn't install into Blender 4.1 for me? By mikegris ( 2 Years Ago )
Forum Post [quote][b]mikegris (6/16/2024)[/b][hr]Doesn't install into Blender 4.1... By Victor.Soupday ( 2 Years Ago )
Forum Post Thanks a lot for the reply. I've been using the plugins for a while... By mikegris ( 2 Years Ago )
Forum Post It does say at the top of the Read-me in each repository where it is... By Victor.Soupday ( 2 Years Ago )
Forum Post Thanks again, appreciate the info and patience. I jus sent a reply a... By mikegris ( 2 Years Ago )
Forum Post I was trying to load the folder and not the .zip. I had downloaded on... By mikegris ( 2 Years Ago )
