Posted By Victor.Soupday 5 Years Ago
Rated 4.8 stars based on 17 votes.
52
53
54
55
56
57
58
Posts: 5.3K, Visits: 16.8K
1. It would be valuable if you add an option to export with Expression Sequence (third option on regular FBX export).
There are cases where backed up expression profile is not applicable (when exporting Humanoids for instance, making certain changes and returning back).
Upon returning, backed up profile would fail to apply and the only way is to re-import expressions from the same FBX file (exported from Blender) containing the sequence.
2. Also not sure how to convert Standard character to Humanoid with pipeline (after making changes to Standard character in Blender).
This one also directly relates to 1.
Right now I use a built-in FBX export/Import routine. But although it was improved lately, it's still a hassle with materials.
Update: There is one more thing :D
This was bugging me for a long time as well. I know RL still does not allow to apply DHS to Humanoid meshes.
I understand it relates to set of external maps which have to match the UV and all (although I wish to have more freedom in this matter).
But now we can Accurig Standard characters and convert them to Humanoids and DHS would be preserved inside CC (this kind of contradicts with RL standards).
So I can now attach CC heads along with other parts of converted with Accurig characters to practically anything while deleting unwanted parts of the body.
Then Accurig it over, save, send to iClone...  etc. All inside CC while preserving DHS for remaining parts.
However, once I export with pipeline and import back to CC, DHS is lost and all is converted to "boring" PBR.
I wonder if you can do anything about it, or RL has a full control of policies here...
This evidently also relates to 1 and 2.
Victor.Soupday
Victor.Soupday
Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)Distinguished Member (5.8K reputation)
Last Active: 3 hours ago
Posts: 569, Visits: 9.0K
4u2ges (8/23/2024)
There is no option in the API to export with an expression sequence.
However... it may not be needed. As an alternative I can fetch the bone rotations used in all the expressions. Adding that data to the export, it could be used to reconstruct a new expression sequence and ExpressionFrameMap.ini, to be compatible with the batch expression sequence import as outlined here.
(Assuming the batch import will work with an FbxKey generated from a non-sequence based export)
4u2ges (8/23/2024)
I did have a function that did this, but it's gone missing. Probably because it was woefully inadequate and it really needs much more work.
But basically all it did was change the generation string, which you can do my hand:
Character Build Settings Panel: Expand Import Details > Generation -> change to "ActorBuild"
4u2ges (8/23/2024)
The API function to set the material's shader does not appear to be allowed to set Digital Human Skin / Head / Eyes / Teeth or Tongue.
Ideally it could be possible to closely replicate the DH Skin shaders with the SSS shader and reconstructing some of the textures. But... the API for the SSS shader is not feature complete either and it's not possible to set this up correctly, yet. But I'm told this is being fixed.
OK, thank you for the info.
Yes, those are not critical to my workflows. And I will take your suggestions.
I shared some SSS shaders for CC3+ topology on Humanoids. Still unfortunate RL is blocking DHS.
Another suggestion though for Datalink. If it's possible to have a cleanup routine for Converted objects.
Like once you Convert object(s), there is no way of going back (to restore the original state and Convert over).
I do not remember, but for whatever reason I needed that recently :)
And a small bug, or rather a need for handling object materials during conversion.
Script will error out if there is a material without a name (I found quite a few no-name materials in some third party projects I was trying to send over).
Update:
It's actually happening not while using Convert but rather with Go IC/CC
For something like that (which may not be common), there is an error.
(maybe just ignore materials without name)
https://forum.reallusion.com/uploads/images/fcd85496-c89b-4767-a62f-a2da.jpg
Wonder if it's possible to add a UV rotate parameter to the texture export/import (API reference indicates there is such parameter exists)
By default IC/CC only have increments of 90 degrees for texture rotation.
In iClone however, it's possible to set any other angle. But it's kind of PITA to redo it every time after export/import.
(and it's not possible to set in CC).
You basically set a 90 degree rotation somewhere at the timeline (frame 90 for instance).
Then, when you got to frame 45, the texture is rotated by 45 degrees. Frame 30 - 30 degrees... etc.
You hit Remove Object Animation and the rotation is baked internally. So it has to be written somewhere?
tiedtke.
tiedtke.
New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)
Last Active: 8 Months Ago
Posts: 2, Visits: 13
"Send mesh alterations back to CC4" is broken in CC4.5 and doesn't update the mesh in CC. Plugin version 2.1.9. Blender version 4.2.2. Is there a fix for this coming? :)
Thanks!
Best,
Michael
52
53
54
55
56
57
58
