DS-Waqas
DS-Waqas
Visits: 284
Synchronous Audio Recording during Facial Capture using audio interface w/ external mic Yeah, this is simply not working for me. I believe I have everything set up correctly. If I go to the Facial - Create Script option I can record there fine.However if I try to record while capturing face mocap using my mic via the Live Face windowupon playback I do not get any audio at all.
3 Years Ago by
DS-Waqas
Last Active: 26 minutes ago
Posts: 9.1K,
You might want to file a trouble ticket with RL support to help you with this.
DS-Waqas
DS-Waqas
Visits: 284
I am using an external microphone ( Shure SM58) as you can see it is being detected by iclone. There was no signal being recorded. However if I try to record audio via the Record Voice option under Create Script it does record and playback the audio.
I even made sure that the Global settings on the timeline for audio were set up correctly.
So then I tried switching microphones. With my second mic I do get a signal as you can see in the timeline but there is no sound at all when I try playing it back. I tried changing the output source. It made no difference whether I chose the speakers connected via the computer's audio jack or the headphones connected to my Xtone audio interface.
So then I tried my webcam. That worked great as far as recording a signal that you can play back but the audio quality is absolutely horrible and unuseable. So it seems the problem is mainly due to using an audio interface to connect a microphone to the computer. I wonder if anyone else has had this problem? Any good quality microphone is going to require using an audio interface. This just doesn't make any sense. For every other program I tried to use with the mic hooked up to the audio interface everything worked great without my having to set up try to adust anything.
Posts: 9.1K,
As I suggested, file a trouble ticket. I use Live Face ALL the time with my Yeti USB mic and it works a treat.
charly Rama
charly Rama
Posts: 1.9K,
Visits: 16.8K
Hello, I'm using a audio interface and it works.
DS-Waqas
DS-Waqas
Visits: 284
@Kelleytoons I did submit a ticket at the same time I posted here. I thought there was no harm in posting in the forums as well in case someone else also had experienced this same problem and found a solution
Posts: 9.1K,
I was just trying to save yourself some grief - some of us have been around the forum a LONG time and have long memories <g> and I never heard of ANYONE having the issue you described. Therefore it's unlikely anyone here can help. But it's a good thing you filed for help from RL. They usually can sort things out (not always, but usually).
