HELP- Synchronous Audio Recording during Facial Capture not working!
Posted By DS-Waqas 3 Years Ago
DS-Waqas
DS-Waqas
Veteran Member (599 reputation)Veteran Member (599 reputation)Veteran Member (599 reputation)Veteran Member (599 reputation)Veteran Member (599 reputation)Veteran Member (599 reputation)Veteran Member (599 reputation)Veteran Member (599 reputation)Veteran Member (599 reputation)
Posts: 47, Visits: 284
Synchronous Audio Recording during Facial Capture using audio interface w/ external mic
https://manual.reallusion.com/Motion_LIVE_Plugin/ENU/Content/iClone_7/Pro_7.0/29_Plug_in/Motion_Live/Synchronous_Audio_Recording.htm
Yeah, this is simply not working for me.
I believe I have everything set up correctly.
If I go to the Facial - Create Script  option I can record there fine.
However if I try to record while capturing face mocap using my mic via the Live Face window
upon playback I do not get any audio at all.
3 Years Ago by DS-Waqas
Posts: 9.2K, Visits: 21.8K
You might want to file a trouble ticket with RL support to help you with this.
DS-Waqas
DS-Waqas
I am using an external microphone  ( Shure SM58)  as you can see it is being detected by iclone.  There was no signal being recorded. However if I try to record audio via the Record Voice option under Create Script it does record and playback the audio.
https://forum.reallusion.com/uploads/images/e0cafe3a-c7ef-464a-8436-abd4.jpg
I even made sure that the Global settings on the timeline for audio were set up correctly.
https://forum.reallusion.com/uploads/images/4789349e-55d7-47eb-b494-ce67.jpg
https://forum.reallusion.com/uploads/images/6465f4f2-2046-4d18-b228-8fc6.jpg
So then I tried switching microphones. With my second mic  I do get a signal as you can see in the timeline but there is no sound at all when I try playing it back. I tried changing the output source. It made no difference whether I chose the speakers connected via the computer's audio jack or the headphones connected to my Xtone audio interface.
https://forum.reallusion.com/uploads/images/342bd6b9-ec03-49ee-9eb0-2774.jpg
So then I tried my webcam. That worked great as far as recording a signal that you can play back but the audio quality is absolutely horrible and unuseable.
So it seems the problem is mainly due to using an audio interface to connect a microphone to the computer. I wonder if anyone else has had this problem? Any good quality microphone is going to require using an audio interface. This just doesn't make any sense. For every other program I tried to use with the mic hooked up to the audio interface everything worked great without my having to set up try to adust anything.
As I suggested, file a trouble ticket.
I use Live Face ALL the time with my Yeti USB mic and it works a treat.
charly Rama
charly Rama
Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)
Posts: 1.9K, Visits: 16.9K
Hello, I'm using a audio interface and it works.
DS-Waqas
DS-Waqas
@Kelleytoons   I did submit a ticket at the same time I posted here. I thought there was no harm in posting in the forums as well in case someone else  also had experienced this same problem and found a solution
I was just trying to save yourself some grief - some of us have been around the forum a LONG time and have long memories <g> and I never heard of ANYONE having the issue you described.  Therefore it's unlikely anyone here can help.
But it's a good thing you filed for help from RL.  They usually can sort things out (not always, but usually).
