Window to big to be able to click on export
Posted By luchorunner2049 6 Years Ago
theschemer
theschemer
Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)
Posts: 1.4K, Visits: 2.9K
Probably won't help but just for a test try this:
https://www.google.com/search?client=firefox-b-1-d&q=win10+keyboard+command+to+resize+window
or this:
https://www.techsupportalert.com/content/how-use-keyboard-move-or-resize-window-too-big-screen.htm
luchorunner2049
luchorunner2049
Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)
Last Active: 6 Years Ago
Posts: 8, Visits: 69
Sadly even when doing that method I still dont get something to go past 1366x720, so for now I would say im unable to use the software until I get a bigger monitor
Update:I ended up using CRU and It got the job done by setting my Display to a bigger res but still the export window is Just big.
I got an old pic from CC3 3.0 and in there I am able to look at the full windowhttps://forum.reallusion.com/uploads/images/202472f8-f980-45d3-acba-a08.jpeg
Posts: 5.3K, Visits: 16.8K
Try this:
1. Select NVIDIA GPU in NVIDIA Control Panel
https://forum.reallusion.com/uploads/images/e52a1493-741b-47d0-8bed-6dad.jpg
2. In Windows Display settings, select Display Adapter Properties and then click on List All Modes to select desired resolution.
luchorunner2049
luchorunner2049
My problem now is, I uodated all my drivers, yet I dont seem able to change my Display and make it go more than 1366*720,so thats what has been keeping me stuck
theschemer
theschemer
Well from what I found your laptop is capable of 1080p so it should work. Don't give up yet. You just need to switch to 1080p or update your drivers. It should be able to work fine.
I see the one in the link below says it has Intel 620 built-in graphics. Maybe you have used it before using the Intel built in graphics?
https://www.techradar.com/reviews/asus-vivobook-s510u
luchorunner2049
luchorunner2049
The model number is S510U
So a little something:
It still wont work,doesnt matter the resolution the window is still too large and I cant resize it, I cant change more the resolution on my laptop even when updating my drivers.
At this point I think im gonna say its a nice software and all but this problem is Just making me drop it
theschemer
theschemer
Although I don't know if your laptop is new or old or what the exact model is to help look things up, I found this to read just in case this is what you have. Give me you exact model number and maybe I can figure it out for sure...
https://www.laptopmag.com/articles/laptop-screen-resolution-ripoff
theschemer
theschemer
Maybe try setting your display resolution to 1024 x 768 and see what happens. Otherwise I don't know but maybe someone else knows of a keyboard command or something.
edit: Oops, I see the GPU can't do 1024x768 but you try the next lower one and see what happens. Won't hurt to try. Otherwise the minimum specs for CC3 are 1024x768 so the aspect ratio is what is causing your issue.
edit 2 Try reading this and see if relates to your laptop:
https://www.techlicious.com/how-to/how-to-fix-nvidia-resolution-problems/
luchorunner2049
luchorunner2049
So there isnt really other way?, Right now I only want to be able to export the characters and so on,Before I remember I was able to do so but I dunno why not it Just wont work
theschemer
theschemer
I am afraid you will have to buy an external monitor. Your GPU(if it is in fact a 980MX) will handle a bunch of resolutions including and even higher than 1080p. Monitors are pretty inexpensive and depending where you are located you could likely pick one up at you local WalMart or electronics big box store. Just make sure the output on you laptop for an external monitor matches the available input on the monitor or you will be looking for adapters right away.
https://www.techpowerup.com/gpu-specs/geforce-gtx-980mx.c2808
