Window to big to be able to click on export
Posted By luchorunner2049 6 Years Ago
luchorunner2049
luchorunner2049
Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)Junior Member (190 reputation)
Last Active: 6 Years Ago
Posts: 8, Visits: 69
SO I cant click export since as you can see here the button wont show and I dont seem to be able to resize the windowhttps://forum.reallusion.com/uploads/images/29dc3448-62d9-44e4-97f2-39e6.png
Threaded View
Threaded View
Forum Post Window to big to be able to click on export By luchorunner2049 ( 6 Years Ago )
Forum Post Hi... It's not so much the export panel is too big, it appears you... By Peter (RL) ( 6 Years Ago )
Forum Post Hi so my Display is at 1366x720 since I work mostly on my laptop, I... By luchorunner2049 ( 6 Years Ago )
Forum Post Right Click on a blank area of your desktop and choose Display... By theschemer ( 6 Years Ago )
Forum Post I cant go higher than 1366*720 since again this is a laptop I use,so... By luchorunner2049 ( 6 Years Ago )
Forum Post That may or may not work depending on you GPU. If your GPU supports... By theschemer ( 6 Years Ago )
Forum Post Its an Asus Vivobook S, Comes with a 980MX if I remember correctly,... By luchorunner2049 ( 6 Years Ago )
Forum Post I am afraid you will have to buy an external monitor. Your GPU(if it... By theschemer ( 6 Years Ago )
Forum Post So there isnt really other way?, Right now I only want to be able to... By luchorunner2049 ( 6 Years Ago )
Forum Post Maybe try setting your display resolution to 1024 x 768 and see what... By theschemer ( 6 Years Ago )
Forum Post The model number is S510U So a little something: It still wont... By luchorunner2049 ( 6 Years Ago )
Forum Post Well from what I found your laptop is capable of 1080p so it should... By theschemer ( 6 Years Ago )
Forum Post My problem now is, I uodated all my drivers, yet I dont seem able to... By luchorunner2049 ( 6 Years Ago )
Forum Post Although I don't know if your laptop is new or old or what the exact... By theschemer ( 6 Years Ago )
Forum Post Try this: 1. Select NVIDIA GPU in NVIDIA Control Panel 2. In... By 4u2ges ( 6 Years Ago )
Forum Post Sadly even when doing that method I still dont get something to go... By luchorunner2049 ( 6 Years Ago )
