Game base to Unreal Engine 4
Posted By trafalgamer 5 Years Ago
trafalgamer
trafalgamer
Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)
Last Active: 4 Months Ago
Posts: 13, Visits: 130
This is the result I get with a game base character using the Auto setup for 4.25 (Look at the nose and ears, you might need to view full size image), this happens with CC3 and CC3+ base characters and with normal export and InstaLOD.
I never had this issue before until I upgraded to 3.3
I get the same result without using CC setup and manually create the materials.
The mesh is around 17K triangles.
Any help is much appreciated, thanks.
https://forum.reallusion.com/uploads/images/b83451cc-b6f0-476e-9c42-eece.png
Threaded View
Threaded View
Forum Post Game base to Unreal Engine 4 By trafalgamer ( 5 Years Ago )
Forum Post After some investigations I concluded that it's a normal map issue,... By trafalgamer ( 5 Years Ago )
Forum Post I do not know Unreal, but there is a clear difference between your... By 4u2ges ( 5 Years Ago )
Forum Post Thanks for replying, to be honest I'm not very experienced with normal... By trafalgamer ( 5 Years Ago )
Forum Post Here is what I mean. On the screenshot both normal maps (3.3 and 3.1)... By 4u2ges ( 5 Years Ago )
Forum Post Oh I see what you mean now, unfortunately no changes. I'll import the... By trafalgamer ( 5 Years Ago )
Forum Post No problem. But yellow background now indicates that Z is inverted... By 4u2ges ( 5 Years Ago )
Forum Post haha interesting. I learned new things about normal maps from your... By trafalgamer ( 5 Years Ago )
Forum Post Hi, I don't know if it's the same issue.For me it happens without... By charly Rama ( 5 Years Ago )
Forum Post Problem solved thanks to 4u2ges who figured it out. My issue is in... By trafalgamer ( 5 Years Ago )
Forum Post [quote][b]4u2ges (8/23/2020)[/b][hr]No problem. But yellow background... By TonyDPrime ( 5 Years Ago )
Forum Post Glad it helped. Good luck. By 4u2ges ( 5 Years Ago )
Forum Post Ahhh.. look at him.. Showed up :Whistling: Where were you yesterday?... By 4u2ges ( 5 Years Ago )
Forum Post [quote][b]4u2ges (8/25/2020)[/b][hr]Ahhh.. look at him.. Showed up... By TonyDPrime ( 5 Years Ago )
Forum Post haha , new game here , find the UE4 issue ;-) But this time it wasn't... By StyleMarshal ( 5 Years Ago )
Forum Post Well, jokes aside, this is another CC 3.3 export bug which needs to be... By 4u2ges ( 5 Years Ago )
Forum Post FT 7188:... By 4u2ges ( 5 Years Ago )
