Game base to Unreal Engine 4
Posted By trafalgamer 5 Years Ago
trafalgamer
trafalgamer
Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)
Last Active: 4 Months Ago
Posts: 13, Visits: 130
This is the result I get with a game base character using the Auto setup for 4.25 (Look at the nose and ears, you might need to view full size image), this happens with CC3 and CC3+ base characters and with normal export and InstaLOD.
I never had this issue before until I upgraded to 3.3
I get the same result without using CC setup and manually create the materials.
The mesh is around 17K triangles.
Any help is much appreciated, thanks.
https://forum.reallusion.com/uploads/images/b83451cc-b6f0-476e-9c42-eece.png
trafalgamer
trafalgamer
Problem solved thanks to 4u2ges who figured it out.
My issue is in the preferences of CC, I had this set to 1024x1024 by default, after changing it to max value (or at least something reasonable than 1024) the issue is finally solved.
Again many thanks to 4u2ges I appreciate it.
https://forum.reallusion.com/uploads/images/82c571e3-344c-4fd0-b9e9-35dd.png
