StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
Thats absolute ok...I had the same problem long time ago with cloth ... but I don't know anymore what the issue was... ;-) maybe it was a "normals" problem. You can send me the Armor only and I can do some tests here , looks like only the Armor has the polygon problem , right?
georgekirby86
georgekirby86
Last Active: 7 Months Ago
Visits: 18
That's the entire character poly count. The armor is around 65,000.
georgekirby86
georgekirby86
Visits: 18
The tessellation is working when viewed in wire frame.
I modeled the armor myself in blender, imported into CC3 to conform and weight etc. I made it as low poly as possible as I knew i could smooth it in CC3.
Will try the FBX export. Thanks
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
where is that amor from , daz or any other source? (over 700.000 Triangles) why so much , is it the cloth or the hair? What you also can test , is to import the Character via FBX , maybe it is a normal problem , import it with " Normal Import Method" = "Compute Normals" ... and also try "Import Normals and Tangents" how does it look then?
georgekirby86
georgekirby86
Visits: 18
Iclone no tessellation/subdivision:  CC3 no tessellation/subdivision
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
Also do a wireframe check if tessellation is working right. (from Lit mode to Brush Wireframe) 1. No Tessellation  2. Tessellation 1 ... you also can go higher... do you see a difference in the wireframe?
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
Hmm , can you show a picture of IClone with the Armor without Subdivision or Tessellation ?
georgekirby86
georgekirby86
Visits: 18
Yep looks the same as yours.
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
Please take a look if tessellation is activated for your Armor. 1.  2.
georgekirby86
georgekirby86
Visits: 18
Just tried it but it had no effect :(
