k747747
k747747
Visits: 69
Hi. I exported scene from IClone7 to UE4(Using Unreal live link), and recorded it by 'Sequanse recording tool' on UE4. When I saw it on UE4 viewport, It was the same as original one. But after recorded, I found the video I recorded were too slow or too fast than original one. I set the frame rate 60/s. So it is same as IClone. Help is appreciated! Thanks.
kungphu
kungphu
Visits: 7.1K
This has been the source of MUCH anxiety! In your project settings don’t use fixed frames as the tutorials state to do. Viola! Your timing will be preserved. Sheer dumb luck I stumbled on this as a solution. That should do the trick!
My "NEWEST" Latest Movie Made With Amaaaazing iClone
Bassline303
Bassline303
Posts: 5.6K,
Visits: 14.0K
kungphu (6/16/2020) This has been the source of MUCH anxiety! In your project settings don’t use fixed frames as the tutorials state to do. Viola! Your timing will be preserved. Sheer dumb luck I stumbled on this as a solution. That should do the trick!haha , I guess you will have to repeat that sentence very often , I would suggest "copy&paste" :-)
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
Normally, RL would have to do a new tutorial and take out the old one. Best regards rosuckmedia
Bassline303
Bassline303
Posts: 5.6K,
Visits: 14.0K
k747747
k747747
Visits: 69
Thanks! I don't use the fixed frame option either, but there's a problem that hasn't been solved yet. When I record in by frame mode, when I play the sequencer after recording, it's playing in slow motion. Do you use the by frame mode?
kungphu
kungphu
Visits: 7.1K
Yeah, do real-time instead of frame and you should be ok. Kinda crazy I’m just learning all this on the fly! Been a crazy ride.
cutoffsquid98
cutoffsquid98
Visits: 312
Hello, any help? As this did not solve my problem. I have tried everything possible but still end up either getting too fast or too slow animation. Help please
cutoffsquid98
cutoffsquid98
Visits: 312
I think I finally found the reason for my problem. This might not be for everyone but it worked for me. I followed reallusion tutorial including the fix frame in the project settings, however I removed raytracing and everything works fine in the sequencer.
