The animation recorded by the 'sequence recording tool(UE4)' is too fast or too slow
https://forum.reallusion.com/Topic447841.aspx
Print Topic | Close Window
By k747747 - 6 Years Ago
Hi.
I exported scene from IClone7 to UE4(Using Unreal live link), and recorded it by 'Sequanse recording tool' on UE4.
When I saw it on UE4 viewport, It was the same as original one.
But after recorded, I found the video I recorded were too slow or too fast than original one.
I set the frame rate 60/s. So it is same as IClone.
Help is appreciated!
Thanks.
By kungphu - 6 Years Ago
This has been the source of MUCH anxiety! In your project settings don’t use fixed frames as the tutorials state to do. Viola! Your timing will be preserved. Sheer dumb luck I stumbled on this as a solution. That should do the trick!
By StyleMarshal - 6 Years Ago
kungphu (6/16/2020)
haha , I guess  you will have to repeat that sentence very often , I would suggest "copy&paste"   :-)
By rosuckmedia - 6 Years Ago
Normally, RL would have to do a new tutorial and take out the old one.
Best regards rosuckmedia
watch this :
https://forum.reallusion.com/444938/Time-in-Unreal-Sequence-Shorter-Then-iClone
Thanks! I don't use the fixed frame option either, but there's a problem that hasn't been solved yet.
 When I record in by frame mode, when I play the sequencer after recording, it's playing in slow motion.
Do you use the by frame mode?
Yeah, do real-time instead of frame and you should be ok. Kinda crazy I’m just learning all this on the fly! Been a crazy ride.
By cutoffsquid98 - 5 Years Ago
Hello, any help? As this did not solve my problem. I have tried everything possible but still end up either getting too fast or too slow animation. Help please
I think I finally found the reason for my problem.
This might not be for everyone but it worked for me.
I followed reallusion tutorial including the fix frame in the project settings, however I removed raytracing and everything works fine in the sequencer.
