Poly count for detailed CC3 characters
Posted By shadybearbklyn 5 Years Ago
3DChick
3DChick
Posts: 411, Visits: 1.9K
Yeah. It took me about two days--admittedly some of that was just figuring out Blender super-basics.
But if you'd like to see the final (for now) product, here it is...
____________________________________________
Life-long learner and having waaaay too much fun with iClone! Youtube Channel: 3DChick
Book Covers: www.significantcover.com Largely Unfinished Fiction: www.nemontgomery.com
shadybearbklyn
shadybearbklyn
Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)
Posts: 337, Visits: 2.8K
This is going to take a long time;)
3DChick
3DChick
I had to decimate each object separately. It locked up when I tried to do them all. Mine was (I think) 21 objects...
shadybearbklyn
shadybearbklyn
That looks fantastic. I’ve tried to decimate in Blender but have been having some issues. I add the modifier with all objects selected but it seems to get stuck before it does anything.
shadybearbklyn
shadybearbklyn
Thanks for the breakdown James. I agree that Reallusion should work on this issue. I have all of these high quality characters that are 120k plus because of high poly hair and clothing and detailed facial characteristics due to 4K images in Headshot. How are you getting them down to 40-60k? The default CC3 character is almost 40k without hair or clothing. Also, what have you used to lower the poly count on scenes that are already configured? The Capitol model that I purchased is nearly 4,000,000 polygons and it is unusable with a couple of characters. While my polygon count is high, I’m only hitting 3GB on a 1080ti card.
3DChick
3DChick
On CC3 Characters coming in from Daz: I used Kelleytoons' directions bringing the characters in through Tranformer, and using the INI file to make sure I got the normal maps, where most of the details I wanted lived (wrinkles etc). I was used to the high def mesh and morphs in Daz, so it took some playing with to get them right, but I eventually did. They all ended up around 100k-600k polys, naked and bald. Then I saved the morphs and the skin in CC3, reloaded the stock CC3 character, applied the morphs and the skin, tweaked again, and got something very close to what I originally had in Daz. I found I could use the Reduce Object function to get the Daz hair (often starting at 300k polys or more!) down to something like 30k and still looking good. Eventually I got fairly high-def looking characters in--dressed with hair--at around 100k each--they all use 4k textures for skin and hair, but lower for clothes. My rig still (8g 1070) bogs down with more than three of them in a scene, but they render nicely.
For sets: I recently caved in and bought a super high poly model on CGTrader, which I had to use Blender to decimate to even get it into iClone. It took some watching of tutorials because I'd never used Blender--I couldn't even navigate--but I got it to work. Set looks pretty good--not quite as good as I wanted (I took it down to about 300k total, and I plan to play with it more to see how high I can go and still render, but mostly worked. If you're not as new at Blender as I was, you could get pretty decent results.
Here's the high poly model promo pic (rendered in Blender, I think) and my set after decimating, etc. I used different consoles and a different chair, and added the ship hologram, etc. The main guy is about 100k, but the bridge crew aren't even 100k all together.
https://forum.reallusion.com/uploads/images/bc789164-238b-48ac-8f70-fe89.jpg
https://forum.reallusion.com/uploads/images/e55606ae-800d-4009-b1d4-1af2.jpg
Whenever possible, I haul higher poly props into CC3 attached to a character and reduce them that way. Particularly if they're just incidental, I can take them waaaay down without any noticeable change (at least I can't see any difference). So that's one way to rather harmlessly get the overall count down.
So, yeah, it's worth trying to decimate your huge set in Blender, and see what you can come up with.
james_muia
james_muia
Posts: 253, Visits: 1.3K
Reallusion really needs to make progress in this area. The engine itself is the main thing keeping a lot of creators from creating highly detailed scenes. As such, you have to use a lot of tricks, and reduce the poly count as well as keeping an eye on your RAM usage.
Thankfully they added the polygon reduction tool in Character Creator, so you can create decent looking characters with various polygon counts and texture quality.
For a main character, try to keep them in the 40-60k Polygon range. Background characters, you can go 25k, or even less. Some of the characters in the film I'm working on are 6K polygons but if you use 'smoothing', you can't tell how low poly they are as long as the camera is some distance away.
Here's a brief overview of what you can expect ram usage wise. This may vary depending on your scene/characters.
4K Character @ 60k Polygons = 3.2GB RAM Usage
2K Character @ 60K Polygons = 3.0GB RAM Usage
1K Character @ 60K Polygons = 1.5GB RAM Usage
512K Character @ 60K Polygons = 1.1GB RAM Usage
4K Character @ 45k Polygons (Converted to GameBase Character) = 2.8GB RAM Usage
2K Character @ 45K Polygons (Converted to GameBase Character) = 2.4GB RAM Usage
Lowest Quality Character using Character Creator Polygon Reduction (Low Quality) - 0.4GB
Not only does high poly count slow down IClone, but going over your RAM usage will prevent you from actually rendering scenes. I've had the program crash on render for going over my graphic card max so it's important to watch both.
IMDB: James Muia
Aviticus Dragon on YouTube
Computer Specs:
Intel® Core™ i7-7820X Processor (8x 4.30GHz/11MB L3 Cache)
Corsair Hydro Series H115i 280mm
Liquid CPU CoolerASUS ROG STRIX X299-E Gaming Motherboard
32 GB DDR4-3200 GSKILL Ripjaws V Memory
NVIDIA GeForce GTX 1080 Ti - 11GB - EVGA FTW3
shadybearbklyn
shadybearbklyn
It’s a large model of the Capitol with over 3.5 million triangles. I’m hoping to create a lightweight version to use while animating and then replace it with the more detailed one before rendering.
Mythcons
Mythcons
Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)
Posts: 455, Visits: 3.2K
Are you trying to get the items to retain their UVs and textures? Generally I'd just create lower poly versions of the item and transfer the details using normal maps and textures. I guess it depends on what you're trying to achieve.
Posts: 15.8K, Visits: 31.4K
shadybearbklyn (5/6/2020)
Thanks Animagic. I think that’s what I’m going to do. How do you recommend decimating a prop that’s extremely complex? Is Blender a good option or is there a way to reduce poly count for objects like you can do with Characters in CC3?
Maybe someone else can chime in regarding decimating. I have never been very successful with that.
