Poly count for detailed CC3 characters
https://forum.reallusion.com/Topic443360.aspx
Print Topic | Close Window
By shadybearbklyn - 6 Years Ago
I’ve created a number of characters in CC3 with high poly counts. Due to high poly hair, such as the Swam hair, and some clothing items I’ve got some characters that have over 200,000 project triangles. As I bring a few of these characters into an IClone project the response gets slower and slower. What should I be shooting for in regards to poly count of each character? I have a 1080ti card and the video memory with six characters and a detailed scene is only hitting 3.3 GB, but the project triangle is almost 5,000,000. I’m in quick mode but it’s so slow it’s impossible to work. Am I pushing it past its limit. The characters look great and I know I can reduce the poly count of some clothing items, but what is the best way to proceed? The scene is 3,765,898 project traingles and is extremely detailed. When I delete it and some of the characters it runs smoothly at about 30 FPS. With the scene and all of the characters it drops down to about 8.
By thebiz.movies - 6 Years Ago
As Dirty Harry Callahan was known to say, "An Icloner's got to know his limitations".  My own machine bogs down around the 2million poly count and as a result it affects the way I design scenes and my general expectations.  I rarely use main characters over 50K and I try to keep background characters under 30K.  I tend to design my sets myself with an eye on poly counts and texture sizes.  Some folks use tricks like rendering in phases which is effective but requires a good bit of planning.  Other folks here have more resources and have higher expectations.
Heres a pretty solid tutorial on creating multiple resolution characters for different uses: https://www.youtube.com/watch?v=PKcu04Fx9JE
Thanks. I was hoping to push it more once I upgraded my video card, but it looks like I’m going to have to work on reducing the polygons of both the scene and my characters.
By animagic - 6 Years Ago
shadybearbklyn (5/6/2020)
Since characters can be exchanged you could do your animation with lower poly characters of the same proportions and once done swap them out when you are ready to render.
I believe the use of proxies (same size low-poly characters and objects) is common in professional 3D animation development.
Thanks Animagic. I think that’s what I’m going to do. How do you recommend decimating a prop that’s extremely complex? Is Blender a good option or is there a way to reduce poly count for objects like you can do with Characters in CC3?
Maybe someone else can chime in regarding decimating. I have never been very successful with that.
By Mythcons - 6 Years Ago
Are you trying to get the items to retain their UVs and textures? Generally I'd just create lower poly versions of the item and transfer the details using normal maps and textures. I guess it depends on what you're trying to achieve.
It’s a large model of the Capitol with over 3.5 million triangles. I’m hoping to create a lightweight version to use while animating and then replace it with the more detailed one before rendering.
By james_muia - 6 Years Ago
Reallusion really needs to make progress in this area. The engine itself is the main thing keeping a lot of creators from creating highly detailed scenes. As such, you have to use a lot of tricks, and reduce the poly count as well as keeping an eye on your RAM usage.
Thankfully they added the polygon reduction tool in Character Creator, so you can create decent looking characters with various polygon counts and texture quality.
For a main character, try to keep them in the 40-60k Polygon range. Background characters, you can go 25k, or even less. Some of the characters in the film I'm working on are 6K polygons but if you use 'smoothing', you can't tell how low poly they are as long as the camera is some distance away.
Here's a brief overview of what you can expect ram usage wise. This may vary depending on your scene/characters.
4K Character @ 60k Polygons = 3.2GB RAM Usage
2K Character @ 60K Polygons = 3.0GB RAM Usage
1K Character @ 60K Polygons = 1.5GB RAM Usage
512K Character @ 60K Polygons = 1.1GB RAM Usage
4K Character @ 45k Polygons (Converted to GameBase Character) = 2.8GB RAM Usage
2K Character @ 45K Polygons (Converted to GameBase Character) = 2.4GB RAM Usage
Lowest Quality Character using Character Creator Polygon Reduction (Low Quality) - 0.4GB
Not only does high poly count slow down IClone, but going over your RAM usage will prevent you from actually rendering scenes. I've had the program crash on render for going over my graphic card max so it's important to watch both.
By 3DChick - 6 Years Ago
On CC3 Characters coming in from Daz: I used Kelleytoons' directions bringing the characters in through Tranformer, and using the INI file to make sure I got the normal maps, where most of the details I wanted lived (wrinkles etc). I was used to the high def mesh and morphs in Daz, so it took some playing with to get them right, but I eventually did. They all ended up around 100k-600k polys, naked and bald. Then I saved the morphs and the skin in CC3, reloaded the stock CC3 character, applied the morphs and the skin, tweaked again, and got something very close to what I originally had in Daz. I found I could use the Reduce Object function to get the Daz hair (often starting at 300k polys or more!) down to something like 30k and still looking good. Eventually I got fairly high-def looking characters in--dressed with hair--at around 100k each--they all use 4k textures for skin and hair, but lower for clothes. My rig still (8g 1070) bogs down with more than three of them in a scene, but they render nicely.
For sets: I recently caved in and bought a super high poly model on CGTrader, which I had to use Blender to decimate to even get it into iClone. It took some watching of tutorials because I'd never used Blender--I couldn't even navigate--but I got it to work. Set looks pretty good--not quite as good as I wanted (I took it down to about 300k total, and I plan to play with it more to see how high I can go and still render, but mostly worked. If you're not as new at Blender as I was, you could get pretty decent results.
Here's the high poly model promo pic (rendered in Blender, I think) and my set after decimating, etc. I used different consoles and a different chair, and added the ship hologram, etc. The main guy is about 100k, but the bridge crew aren't even 100k all together.
https://forum.reallusion.com/uploads/images/bc789164-238b-48ac-8f70-fe89.jpg
https://forum.reallusion.com/uploads/images/e55606ae-800d-4009-b1d4-1af2.jpg
Whenever possible, I haul higher poly props into CC3 attached to a character and reduce them that way. Particularly if they're just incidental, I can take them waaaay down without any noticeable change (at least I can't see any difference). So that's one way to rather harmlessly get the overall count down.
So, yeah, it's worth trying to decimate your huge set in Blender, and see what you can come up with.
Thanks for the breakdown James. I agree that Reallusion should work on this issue. I have all of these high quality characters that are 120k plus because of high poly hair and clothing and detailed facial characteristics due to 4K images in Headshot. How are you getting them down to 40-60k? The default CC3 character is almost 40k without hair or clothing. Also, what have you used to lower the poly count on scenes that are already configured? The Capitol model that I purchased is nearly 4,000,000 polygons and it is unusable with a couple of characters. While my polygon count is high, I’m only hitting 3GB on a 1080ti card.
That looks fantastic. I’ve tried to decimate in Blender but have been having some issues. I add the modifier with all objects selected but it seems to get stuck before it does anything.
I had to decimate each object separately. It locked up when I tried to do them all. Mine was (I think) 21 objects...
This is going to take a long time;)
Yeah. It took me about two days--admittedly some of that was just figuring out Blender super-basics.
But if you'd like to see the final (for now) product, here it is...
