toystorylab
toystorylab
Last Active: 6 hours ago
Posts: 4.6K,
Visits: 29.9K
According to this thread: https://forum.reallusion.com/439194/Animating-walking-down-the-stairsI tried doing this and it is damned tricky... Here is my result: I can imagine only very few, if any, will accept the challenge, but the main goal of this challenge is to find out what's the easiest/best way to do a walk down stairs whithout having the possibility to adjust stairs to motion. And it's definitely a good practice, could be useful in the future. :DAs the title says, let Jade (Avatar template - Avatar - 0.Jade) walk down the stairs of the "Loft Scene" (Project Template - 2.GI - 2.Loft Scene)... Conditions - Use Jade - No scaling of the stairs/Loft Scene - After Challenge is over, reveal your way how you did it... If there are more than 3 people joining we could let the community vote who did the best job. And I will think about a reward ;) Or even better, @ RL any chance you could fork out a little freebie to your wonderful community? Peter (RL)? To give everybody the same chance, here is the motion I used: see attachment...
By the way, anybody who can make the descending motions @ Mixamo usable? They are useless, as there is kinda footcontact implemented...
Toystorylab on Vimeo : 75% of original size (was 671x19) - Click to enlarge Crassitudes (my "Alter Ego") on Youtube: 75% of original size (was 671x19) - Click to enlarge
Visits: 62.5K
Posts: 5.3K,
Visits: 16.6K
I am not sure if I will participate, but for those who will, I quickly made this stairs terrain for Loft Scene to illuminate that annoying step. In addition, I'd say not to use a walk cycle - do a manual cycle animation and try using reach effectors to prevent feet sleeping.
AlbinosGambit
AlbinosGambit
Visits: 478
Hi ToyStoryLab! This is a great idea to shed some light on the subject I also had huge problems solving. I hope many will try to participate and show us the best and easiest way to actually do this, and it would be very helpful to everyone for future projects and also to learn and share knowledge:-)
WIN 10, COOLERMASTER MASTERCASE 500H, MSI GAMING PRO CARBON X470 RGB, AMD Ryzen 7 2700X CPU, MSI GeForce GTX 1650 GAMING X - 4GB GDDR5 RAM GPU, Corsair Vengeance RGB PRO DDR4 3200MHz 16GB RAM, SSD M.2 Corsair Force Series MP510 480 GB, SEAGATE BARRACUDA 3.5 HDD 4 TB.
Best regards Albin (AlbinosGambit)
Visits: 62.5K
I thought I would see what I can do on this challenge, as it is a big one that I have attempted to solve in the past using different methods that were never quite satisfactory.
So to adjust the stride length in the Modify panel, use the exaggeration sliders. Move them both the same amount to keep upper body and lower body in sync. It effects the entire motion, including the distance traveled, so it will be tricky. ;) I have only just had a look at it, so no tutorial yet.
But you can actually the stairs and scale them a little on the Y axis (green) to do some additional fine tuning. You may need to reposition them a little if you scale them.
AlbinosGambit
AlbinosGambit
Visits: 478
Thanks again Rampa for joining in on the discussion and challenge. I will be excited to see what ideas and results you come up with:-) I really hope you accept the challenge, I am eager to learn from the masters and become a master my self one day!? :cool:I was hoping for - No scaling of the stairs/Loft SceneAlso, I am not sure what you meant by "But you can actually the stairs" :w00t::w00t:Rampa (3/31/2020) I thought I would see what I can do on this challenge, as it is a big one that I have attempted to solve in the past using different methods that were never quite satisfactory.
AlbinosGambit
AlbinosGambit
Visits: 478
@Rampa By the way like ToyStoryLab said: By the way, anybody who can make the descending and ascending motions @ Mixamo usable?They are useless, as there is kinda footcontact implemented
Is this even possible, then it would be a good fast and easy solution maybe also?
Visits: 62.5K
AlbinosGambit (3/31/2020) @Rampa
By the way like ToyStoryLab said: By the way, anybody who can make the descending and ascending motions @ Mixamo usable? They are useless, as there is kinda footcontact implemented
Is this even possible, then it would be a good fast and easy solution maybe also?Use the clip that ToyStoryLab uploaded a few posts earlier. The Mixamo ones are indeed no good. I looked them up, and it turns out Adobe almost removed them because they were broken. It would be extremely difficult to fix them.
AlbinosGambit
AlbinosGambit
Visits: 478
The Zip.file you included, thank you for this, but how did you actually make this? :w00t::cool:toystorylab (3/31/2020)
AlbinosGambit
AlbinosGambit
Visits: 478
Yes, I saw the zip file included, but I am not sure how to replicate the process without instructions :w00t: I just tried using mixamo motions for descending the stairs (following advice from animagic) and Zane as the character. Used the Ybot descending stairs motionI get some weird results. Zane starts the walking down cycle, but his feet slide backward, but also the longer the mixamo animation plays, the further back he slips and deeper his legs get down to the floor, haha. Very funny stuff this, I have no idea what's happening here. Hmmm.Here is a photo of the start walking descending the stairs from the loft scene:27% of original size (was 1920x1200) - Click to enlarge Here is the photo at the end of the mixamo motion applied to Zane27% of original size (was 1920x1200) - Click to enlarge Rampa (3/31/2020)
