Marvelous Designer To CC3 - Any ideas
Posted By The Elliseran Modeller 5 Years Ago
Veteran Member (916 reputation)Veteran Member (916 reputation)Veteran Member (916 reputation)Veteran Member (916 reputation)Veteran Member (916 reputation)Veteran Member (916 reputation)Veteran Member (916 reputation)Veteran Member (916 reputation)Veteran Member (916 reputation)
Posts: 19, Visits: 275
I am using MD to create cloths for CC3 for my own use in illustrations. I have very little trouble bringing in tight fitting cloths and conforming them to my characters as per the picture below. They tend to then follow the character with little or no distortion. Sometimes some sculpting is required but as I usually export my character out from CC3 to use as the avatar in MD problems on tight fitting cloths are minimal pic 1 below.
The problem arises with items that are not tight fitting such as cloaks as seen in the pic 2 below. They come in OK but then seem to attach themselves to all kinds of bones pic 3. I use 'cloak' on import but find the cloth is even attached to fingers. Any tutorials likely on using MD to create cloths for CC3 likely? I have seen the additional purchase tutorials attached to the Street Clothiung package in the store but that first requires the $199 purchase of the package and then refers to Maya use. Maya at a thousand plus dollars is simply out of the range of most single users. Anyway any ideas guys?
76% of original size (was 664x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/563df136-769c-4a24-b49c-8d0a.jpg
76% of original size (was 664x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/1ae1f00a-1d31-42d1-a914-88e4.jpg
76% of original size (was 664x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/fdae05b4-3d74-41fa-abac-aab4.jpg
Threaded View
Threaded View
Forum Post Marvelous Designer To CC3 - Any ideas By The Elliseran Modeller ( 5 Years Ago )
Forum Post It's not the modeling per se (which is why using something else won't... By Kelleytoons ( 5 Years Ago )
Forum Post Thanks. Good advise and helpful in pointing me in the right direction.... By The Elliseran Modeller ( 5 Years Ago )
Forum Post here is a interesting video that shows how to import Animated MD Cloth... By StyleMarshal ( 5 Years Ago )
Forum Post Thanks Baseline303 By The Elliseran Modeller ( 5 Years Ago )
Forum Post Hi Kelleytoons I know you have many videos. Did you get anyway... By cynsegura ( 4 Years Ago )
Forum Post hello Guys, i have a similair problem from Blender coming. Because... By carlo1981 ( 5 Years Ago )
Forum Post i solved this, i just had to rotate the cape like a regular... By carlo1981 ( 5 Years Ago )
Forum Post If I were you, I would not even bother with skin/physics weight. You... By 4u2ges ( 4 Years Ago )
Forum Post @4u2ges I have had the benefit of your experience and advice on this... By MIDI3D ( 4 Years Ago )
Forum Post Many thanks for your video!! I highly appreciate your help!! By cynsegura ( 4 Years Ago )
Forum Post [quote][b]cynsegura (1/7/2021)[/b][hr]Many thanks for your video!! I... By 4u2ges ( 4 Years Ago )
Forum Post @MIDI3D: Don't feel too embarrassed. I have been using iClone for a... By animagic ( 4 Years Ago )
Forum Post @animagic: That's absolutely correct. Personally, I give it a least 45... By MIDI3D ( 4 Years Ago )
Forum Post [quote] Unfortunately for me, I never could get any consistent... By 4u2ges ( 4 Years Ago )
Forum Post @4u2ges: Just curious, what kind of an overhaul might you be expecting... By MIDI3D ( 4 Years Ago )
Forum Post I was rather generalizing as oppose to inviting RL to look into... By 4u2ges ( 4 Years Ago )
Forum Post I'm all for simplicity and I would love for iClone/CC3 to be the only... By MIDI3D ( 4 Years Ago )
Forum Post I am not a clothing designer, but would it be possible to import CC... By animagic ( 4 Years Ago )
Forum Post 😀 I was about to ask MIDI3D the same question. But I think it is not... By 4u2ges ( 4 Years Ago )
Forum Post @animagic Yes! I've already done that. I have purchased some CC... By MIDI3D ( 4 Years Ago )
Forum Post Yes. By MIDI3D ( 4 Years Ago )
Forum Post You can. I think you need version 9 or later though. "OBJ To Garment"... By Rampa ( 4 Years Ago )
Forum Post Oh, that is most interesting and very promising! I am not at the... By 4u2ges ( 4 Years Ago )
Forum Post @MINI3D: Yes that is clear. I will wait for official support of... By animagic ( 4 Years Ago )
Forum Post Apparently I do have OBJ to Garment option in MD :w00t: . I can't... By 4u2ges ( 4 Years Ago )
Forum Post That's good to know.! I'm just so used to getting it because I'm all... By MIDI3D ( 4 Years Ago )
Forum Post Sure thing :) And I forgot about another easier option. There is not... By 4u2ges ( 4 Years Ago )
Forum Post Indeed! By MIDI3D ( 4 Years Ago )
