Blender FBX crashes 3dXchange
Posted By dogscooby007 5 Years Ago
dogscooby007
dogscooby007
Senior Member (473 reputation)Senior Member (473 reputation)Senior Member (473 reputation)Senior Member (473 reputation)Senior Member (473 reputation)Senior Member (473 reputation)Senior Member (473 reputation)Senior Member (473 reputation)Senior Member (473 reputation)
Posts: 18, Visits: 132
Hello everyone!
I've had a designer create this character in Blender and have been trying to import the FBX into 3dXchange, but it crashes once it reaches 100% as I saw someone else say in another post.
They said they corrected the issue by exporting it into an FBX format that 3dXchange recognized, but I need some help understanding what that format is.
I'm fairly new to iClone7 and 3DXchange, having tried it out a while ago and am now just getting back into it.
I have iClone 3dXchange v7.71 if that helps at all. Also, I zipped the blender doc, the textures, and the fbx files here: https://drive.google.com/file/d/1Xl2R5koQe6pgzR5gGsKu2kM3A5-Amtra/view?usp=sharing
In the zip file, I have two fbx files I was trying with.
I contacted support, but so far they have not yet responded after I had fixed the rig as they stated.
Any help would be greatly appreciated!
Threaded View
Threaded View
Forum Post Blender FBX crashes 3dXchange By dogscooby007 ( 5 Years Ago )
Forum Post I did set to only export The last one you sent worked. I saved an... By Rampa ( 5 Years Ago )
Forum Post Exported from Blender FBX is unstable. It might open 4 times and then... By 4u2ges ( 5 Years Ago )
Forum Post Thanks for responding so quickly guys! I wanted to wait until I had... By dogscooby007 ( 5 Years Ago )
Forum Post Actually I see why it won't let me convert now. Not all the bones are... By dogscooby007 ( 5 Years Ago )
Forum Post I went ahead and fixed it for you. It is beyond me figuring out what... By 4u2ges ( 5 Years Ago )
Forum Post Thank you so much for that, 4u2ges! When I exported from your blender... By dogscooby007 ( 5 Years Ago )
Forum Post But where did you open that blender file from? I only included .blend... By 4u2ges ( 5 Years Ago )
Forum Post Awesome! Thank you! I appreciate your patience with me! I got it... By dogscooby007 ( 5 Years Ago )
Forum Post That is what I meant, when I said you need to talk to your... By 4u2ges ( 5 Years Ago )
Forum Post Oh ok. File Extensions So I allowed "show file extensions" in... By dogscooby007 ( 5 Years Ago )
Forum Post When I suspect that the binary file type does not correspond to the... By 4u2ges ( 5 Years Ago )
Forum Post Are the various parts of your model correctly UV mapped? If there is... By Rampa ( 5 Years Ago )
Forum Post [quote][b]Rampa (2/1/2020)[/b][hr] Also Blender textures always import... By 4u2ges ( 5 Years Ago )
Forum Post Wow! Thanks so much, 4u2ges! You're super knowledgeable and have a... By dogscooby007 ( 5 Years Ago )
Forum Post You will likely save yourself a lot of headache just creating the... By Rampa ( 5 Years Ago )
Forum Post Very nice job with character design I must say. Good luck with your... By 4u2ges ( 5 Years Ago )
Forum Post 4u2ges, if I had my designer start off with the blender file you fixed... By dogscooby007 ( 5 Years Ago )
Forum Post I am not sure how your designer has done it in the first place.... By 4u2ges ( 5 Years Ago )
Forum Post You can send your texture to an external editor, or use the internal... By Rampa ( 5 Years Ago )
Forum Post Rampa reminded me about something... While the hardest part is to... By 4u2ges ( 5 Years Ago )
Forum Post That looks awesome, 4u2ges! I'll have to get the free trial and try to... By dogscooby007 ( 5 Years Ago )
Forum Post Fairly easy. I have 1.5m tut on this one. By 4u2ges ( 5 Years Ago )
Forum Post That's a great simple tutorial! You guys are awesome. 1.) So when you... By dogscooby007 ( 5 Years Ago )
Forum Post Well, you certainly getting there. 1. No, the .objkey is generated... By 4u2ges ( 5 Years Ago )
Forum Post Thanks for all the answers and that link to the tutorials! When I... By dogscooby007 ( 5 Years Ago )
Forum Post Yes, the object comes with base maps and .mtl file. The rest is just... By 4u2ges ( 5 Years Ago )
Forum Post I was trying to import the hair, but ran into some issues: In the... By dogscooby007 ( 5 Years Ago )
Forum Post I have not seen mentioned tutorial, but I believe you misunderstood.... By 4u2ges ( 5 Years Ago )
Forum Post Thanks for clearing that up! Here's the tutorial Rampa put up in... By dogscooby007 ( 5 Years Ago )
Forum Post Blender OBJs are usually 1000 times to small. Try scaling it up! ;)... By Rampa ( 5 Years Ago )
Forum Post Thanks, Rampa! You were right - it was incredibly tiny which is why it... By dogscooby007 ( 5 Years Ago )
Forum Post Actually I answered question #2 - there was an option in the viewport... By dogscooby007 ( 5 Years Ago )
Forum Post Sorry my mistake... still learning! haha So I answered question 2... By dogscooby007 ( 5 Years Ago )
Forum Post It always comes down to material settings (whether in Blender or CC).... By 4u2ges ( 5 Years Ago )
