Transparent Characters in Unreal 4.23 using Auto Setup Plugin
Posted By VinnyJ 7 Years Ago
VinnyJ
VinnyJ
Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)
Posts: 3, Visits: 106
Okay, so apparently the Master Material set to each of the Transparent Instances was RL_Standard.
Changing it to the appropriate Eyelash, Eyeball, or LW or HQ Skin fixes the issue, but still all clothing, which uses RL_Standard as its master is transparent.
Once again, this is not an issue in 4.22.  Don't see any difference in the settings on RL_Standard in 4.23.
VinnyJ
VinnyJ
Heyo!
Used the Auto-Setup Plugin to import a few Characters into Unreal 4.23.
Tried the HQ, LW, and Standard Shaders and everything is See-Through.
The Master materials are set to Masked, but literally everything is basically ghosted: skin, clothing, hair, and all - except for one character, which has Opaque Skin, but Transparent Clothing (2nd Picture).
I tried changing parameters on a few Material Instances, but no change.
Didn't see any mention of this on any forums or in any of the tutorial videos.
What should I do?
Interesting Note: Imported Same Character into Unreal 4.22 with Auto Setup and works fine (3rd Picture).https://forum.reallusion.com/uploads/images/47f28e27-c587-4e83-8e33-d988.jpghttps://forum.reallusion.com/uploads/images/4a97d38b-d606-4f35-b6ae-6667.jpghttps://forum.reallusion.com/uploads/images/b4ba87ed-61c3-4362-81ff-8692.jpg
***NEVERMIND***
Started a New Project in 4.23.  Reimported Character using Auto Setup Plugin, and RL_Standard material now works fine!  Just a buggy project, I guess.
- I had installed the Plugin folder into the Content folder, gone through the clean up process, then re-installed, so must've tripped it up somewhere -
