hayward
hayward
Visits: 174
I just pressed saved. As well as save as. Is there a certain folder I am supposed to save it in?
m.altajer93
m.altajer93
Visits: 52
Yes exactly that's what I meant , Hopefully it will be fix this month, I have tried the cc1 base also but the same issue. Thank you @animagic
m.altajer93
m.altajer93
Visits: 52
inash
Visits: 775
I read somewhere on this forum that it was a glitch CC3 had with the newer versions for Maya, that was supposed to have been fixed with the most recent version. Guess it wasn't fixed though.
___________________________________________ Graphic Designer / Video Editor / Sound Engineer
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-4930K 3.4 GHZ / MB: ASUS Sabertooth X79 / RAM: 32GB G-SKILL RIPJAW / HD: 2TB+2TB+3TB / SSD: 256 Samsung 860 EVO & 128 Samsung 860 EVO/ GPU: GTX 1080 Ti 11GB / COOLER : CORSAIR H75 Liquid Cooler
Last Active: 4 days ago
Posts: 15.8K,
Visits: 31.3K
@m.altajer: Are you saying that you can't access the Appearance Editor with a CC1 character? That should work. The editor is not compatible with CC3 characters. However, a much improved editor is expected this month or so.
m.altajer93
m.altajer93
Visits: 52
Hello, I have an issue with cc1 base and cc3 also when i try to use the appearance editor. I cant select the option, so i cant change eyebrows color as an example. please how can I solve this issue. 76% of original size (was 661x19) - Click to enlarge
Zeronimo
Zeronimo
Visits: 19.3K
hayward (7/15/2020) I am having problems with Character Creator saving my projects. I save them and I come back the next day and it comes up with old versions of my file after I saved it many times. Is there something I am not doing?are you sure you saved your new file in the same directory as the old file? You must have made the backups in a different directory
hayward
hayward
Visits: 174
Ascensi
Ascensi
Visits: 1.9K
inash
Visits: 775
CC3 Character will not Open in Maya 2020.2. I export as FBX with the Maya Preset and it crashes Maya on import.
