StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
The crash report is "normal" , got it also , it is an issue that will be fixed in the next "Live-Link" update of RL , but no worries , everything works fine. Here are Live-Link tutorials from RL , they are all explained in details. Look for the right one you need : https://forum.reallusion.com/438473/Read-First-Unreal-Live-Link-SelfHelp-Videos
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
Actually, Bassline/Rosuk/3DTester - do you know if LiveLink can be brought in with a Blueprint-skeleton, or can you only do that after. Like can you still LiveLink while your character has already been assigned a BP-skeleton?! If so I had no idea! Or do you just then toggle the skeleton on and off per what you want to do...This would be awesome if it could work all simultaneously. ---- Eigentlich Bassline/Rosuk/3DTester - wissen Sie, ob LiveLink mit einem Blueprint-Skelett eingeführt werden kann, oder können Sie das erst danach tun? Wie kannst du noch LiveLink, während deinem Charakter bereits ein BP-Skelett zugewiesen wurde?! Wenn ja, hatte ich keine Ahnung! Oder schalten Sie das Skelett gerade ein und aus, je nachdem, was Sie tun möchten ... Das wäre fantastisch, wenn alles gleichzeitig funktionieren könnte.
rosuckmedia
rosuckmedia
Last Active: 7 Months Ago
Posts: 3.2K,
Visits: 4.8K
@TonyDPrime, A very interesting question that I cannot answer for you, Bassline3ß3, knows certainly a solution, he is the UE specialist
Best regards rosuckmedia
3dtester
3dtester
Last Active: 6 Months Ago
Visits: 2.2K
You can create several BPs using the same skeleton. As long as you don't change the Live Link BPs them self, there shouldn't be a problem. But: i don't use Live Link yet, so i can't tell for sure ;)
@Bassline Thank you for the video about merging animations. This is very helpful :)
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
@Tony
The transfer with Live-Link creates Blueprints for each Character. Yes you can switch on and off the linked skeleton by giving the Character another name , because it links only the Character with the exact same name.
11.5% :-)
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
Working on some "CC3 - Digital Beauties" and that in Realtime , yessss ! :-)
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
@Bassline 303 Looks good, Best regards rosuckmedia:)
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
Hallo, Is there a way to crossfade the transitions of two shots (from one shot 1 to shot 2) Gibt es eine möglichkeit die Übergänge zweier Shots zu übeblenden( von einem Shot 1 zu Shot 2) Best regards rosuckmedia
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
As far as I know , NO :-( you have to do it in post.
Unfortunately It's not possible right now. You can only have one active camera at a time, fading between two cameras simultaneously would mean rendering both cameras at full resolution which is very expensive and (unfortunately) not something the engine supports. Scene Captures won't fulfil this void either, as there are still rendering differences between cameras and scene captures.
rosuckmedia
rosuckmedia
Posts: 3.2K,
Visits: 4.8K
@ Bassline303 Thank you for your answer, I'll do it in the video editor. Greetings rosuckmedia:)
