Hyzenthlay
Hyzenthlay
Last Active: 6 Years Ago
Visits: 32
Hello the community! Here is my issue. I'm trying to nail down a procedure to bring Vroid actors across to iClone. The problem is with the textures I think. Everything looks super good in 3DXchange, but when I load the asset into iClone everything seems to glow and look washed out. I tried to get as close to flat shading as possible because they are anime characters, so I dialed the specularity and glossiness down to zero. Can anyone tell me what I'm missing there please? I notice there are three lights in 3DXchange which I never added. Are they getting attached to the character somehow? Sorry if this is an irritating newb question but it's fairly twisting my melon at this point. Some screenshots; 3DXChange ---------------- iClone ----------------
Visits: 22.1K
This is almost surely just the texture weights are dialed down to 80%. This happens a lot (so much that my routines for Daz to iClone accounted for it, although not needed anymore). Just go through all the base color weighting and set to 100%
Hyzenthlay
Hyzenthlay
Visits: 32
Hi Kelleytoons! Thanks for replying. The weights were all at 80 as you said, and setting them to 100 made a good bit of difference to the textures. Things are definitely looking a lot better now. There is still a pronounced glow happening from somewhere though. I thought it might have been the normals but they're all good. @ Strength 100% -----------------------
Skuzzlebutt
Skuzzlebutt
Visits: 8.6K
select all the textures open adjust color select metallic increase brightness
Hyzenthlay
Hyzenthlay
Visits: 32
@ KipsterThat's the stuff I was looking for. Thank you so much, buddy! The metalicy and the roughness of all the textures were all out of whack. You are a superstar :)
Fixed -------
Skuzzlebutt
Skuzzlebutt
Visits: 8.6K
they are linked so you dont have to select all my bad!
Posts: 5.3K,
Visits: 16.5K
Still, seems the gamma is off. Make sure "Use sRGB" is checked on Base Color texture for all materials
hirospot
hirospot
Visits: 5.9K
Re: Vroid Sample image Here is my test for the best result: 1. Select 'Traditional' for Shader Type with checking on 'Use sRGB' & Strength=100%. fig 1: Traditioal Shader Type, Use sRGB, Strength=100% & Key Light Off 2. Diffuse image color level of Face is modified in the 2D tool. fig 2: Left: Original image Right: Increased Color Level Thank you, Hiro
