Special Notice: Character Creator & iClone Auto Setup for Unity
Posted By Miranda (RL) 6 Years Ago
3
4
5
6
7
tmhspeechdev
tmhspeechdev
New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)
Posts: 1, Visits: 81
Thanks a million for this info Miranda!
"7. Unity and Character Creator calculates mesh normals in a fundamentally different manner which can cause mesh edges to appear hard inside Unity.  Fix this by trying out different settings for the Normal & Tangents > Normals parameter.  However, before doing so, don't forget to disable Auto-Processing. "
I was wondering what was wrong with my normal map since it looked good when I imported the mesh directly to Unity from Zbrush.  But when it went from Zbrush to CC3 and then to Unity It had facets. Now I'm happy again :) Thank you!
jerome.dipietro
jerome.dipietro
Posts: 91, Visits: 1.1K
Still fairly new to CC3 so apologies if I'm being stupid, but I've not previously had a problem with this (when using CC3.2, AutoSetup 1.02 and same version of Unity, i.e. 2019.3)
Followed the optimisation recommendations, converted character body to a GameBase and swapped eyes to GameEyes_OneUV. This is the result in CC3:
75% of original size (was 672x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/a3487d1d-f26a-4b42-86a9-081e.png
Imported into Unity 2019.3.13 using AutoSetup 1.1 (URP package, as project is set to use that render pipeline) I get this:
75% of original size (was 672x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/2c2a418d-5924-4e98-a30e-0161.png
Not only is the mesh not smoothed properly but the face actually looks different (eye and nose are different proportions somehow).
[as a minor point the T-Shirt material is also wrong, but that's not what I'm most worried about]
Import settings in Unity are set to this (by the AutoSetUp I assume?):
75% of original size (was 672x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/ae8d5c98-8297-4881-90a8-b21a.png
I tried changing the smoothness Source but it didn't help.
As an additional sanity check, I then imported the unoptimised character (original body but GameEyes). Got this:
75% of original size (was 672x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/c6eb77d0-e1a6-4a9d-a76d-6433.png
I can tweak the overzealous normals (but surprised I'd have to...) and the eyes are doing that thing I've seen mentioned in the docs that Daz characters are meant to do if not prepared properly. But this is all 100% CC3.3
Am I doing something massively wrong, or are these CC3+ meshes not quite ready for prime time in Unity?
Unity Virtual Reality Developer
Miranda (RL)
Miranda (RL)
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
Hi everyone,
It's fixed in version 1.1. There is no need to manually change the diffuse profile.
Please download the tool, and try again, thank you!
Miranda (RL)
Miranda (RL)
Hi gametuturiaisone,
We collected the issues from recent posts, and made a report yesterday.
https://forum.reallusion.com/451720/Auto-Setup-11-for-Unity-compatible-with-CC-33-iClone-78
Here is the feedback for the issue you asked:
Cause: Diffuse profile isn't automatically assigned for skin; it displays as "None".
Workaround: We are still searching the solution to set diffuse profile via Unity C#, before it fixed, please manually set to the correct one.
75% of original size (was 672x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/85be0196-f839-49f3-b08a-2501.png
Ryan Hayle
Ryan Hayle
Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)
Posts: 49, Visits: 371
That's normal, add the skin profile or turn off sub surface scattering. You can read about it in the docs.
Light_Show_55
Light_Show_55
New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)
Posts: 1, Visits: 6
Hi When i Issert my caracher on unity the skin is green ... Plis can anyone help plis ?
75% of original size (was 672x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/95908373-43d0-4505-8bf8-8c05.png
polycular
polycular
New Member (49 reputation)New Member (49 reputation)New Member (49 reputation)New Member (49 reputation)New Member (49 reputation)New Member (49 reputation)New Member (49 reputation)New Member (49 reputation)New Member (49 reputation)
Posts: 4, Visits: 157
thx than it is a not very logical version numbering system...
Ryan Hayle
Ryan Hayle
This is the latest version, the betas are the older versions. However we just got this news today:
To be compatible with the latest released version of Unity (2019.3) and Unreal Engine (4.25), we will release new versions of Unity Auto Setup and Unreal Auto Setup this month (May).
The new version of Auto Setup tools will be compatible with Character Creator 3.22 and iClone 7.22.
The specific release date is not firmed yet, please wait for further announcement, thank you!
polycular
polycular
maybe I'm blind but I can't find the download link for beta 2.0 it always just refers me to the main download site https://www.reallusion.com/character-creator/unity-auto-setup.html where there is just version 1.01 to download
please if you could supply us with the beta for HDR pipeline test would be awesome...
Miranda (RL)
Miranda (RL)
Hi alex_ey,
It seems that the error message is from using the incorrect package for template you are choosing. Can you help to double check? Thanks!
75% of original size (was 672x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/b1260e3f-2247-4cde-9c33-522a.png
3
4
5
6
7
