Special Notice: Character Creator & iClone Auto Setup for Unity
Posted By Miranda (RL) 6 Years Ago
Miranda (RL)
Miranda (RL)
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
Introduction
The process of bringing an animated CC character into the Unity can be tedious.  This is exacerbated by the inordinate amount of time it would take to manually assign every material property, adjust texture settings, modify animation properties, model configuration, along with other complicated manual tasks.  In response, we are providing this plugin to trim your production time by automating the aforementioned idiosyncrasies.
Starting from Beta 1.0 released on 11/30/2018 till now, we have been working on updating the auto-setup procedure.  In Beta 2.0, skin material was supplemented with a Detail Map along with proper subsurface scattering (SSS) settings for HDRP Rendering Pipeline.  The Official "Character Creator & iClone Auto Setup" 1.01 has been released on 8/29/2019, please see the full release note for details.
Installation
The Character Creator & iClone Auto Setup can be manually installed into Unity folder in order to be applicable in Unity.
  1. Download the installation file.
  2. Execute the file and you will get an Auto Setup folder under C:\Program Files\Reallusion\Shared Plugins\Auto Setup by default.
  3. Open the sub-folder named Unity, and you will find three folders which indicate different versions of Unity.
  4. Open the folder ideal for your version of Unity, and drag the unitypackage to the Assets folder in Unity.
  5. The Editor folder and the CC_Assets folder will be automatically generated under the Assets folder after installed.
For the full installation guide and online manual, please check HERE.
We will provide 3 template scripts from which you can use according to your needs.
https://forum.reallusion.com/uploads/images/f3e0a24e-7c45-4da9-8156-6650.png
https://www.reallusion.com/character-creator/tutorial.html#unity
Process Overview
Related Information
Important Notice: Update Guide for Existing Users
If you have installed the Beta version before, please visit Reallusion FAQ to check How to Remove and How to Update the auto-setup tool.
Script Download & Update History
To download the Character Creator & iClone Auto Setup, and find the update history, please check HERE.
Threaded View
Threaded View
Forum Post Special Notice: Character Creator & iClone Auto Setup for Unity By Miranda (RL) ( 6 Years Ago )
Forum Post Step 1 - Export FBX from Character Creator 3 Choose the Target... By Miranda (RL) ( 6 Years Ago )
Forum Post Step 2 - Download and Install the Auto-Setup Script There are two... By Miranda (RL) ( 6 Years Ago )
Forum Post Step 3 - Import the FBX File into Unity to Prompt Auto-Setup Process... By Miranda (RL) ( 6 Years Ago )
Forum Post Step 4 - Adjust Some Settings in Unity (Optional) Correct the... By Miranda (RL) ( 6 Years Ago )
Forum Post Important Considerations To run the auto-processing effectively,... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, Thanks for the update! I made a quick test exporting a... By Jfrog ( 6 Years Ago )
Forum Post Hi Jfrog, Do you have any updates on this case? If it's duplicated,... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, My apologizes for the delay. I finally had the time to... By Jfrog ( 6 Years Ago )
Forum Post Got it, thanks Jfrog!! By Miranda (RL) ( 6 Years Ago )
Forum Post This also seems to fix many of the issues directly Inside unity! I... By AlbinosGambit ( 5 Years Ago )
Forum Post Hi When i Issert my caracher on unity the skin is green ... Plis can... By Light_Show_55 ( 5 Years Ago )
Forum Post That's normal, add the skin profile or turn off sub surface... By Ryan Hayle ( 5 Years Ago )
Forum Post Hi gametuturiaisone, We collected the issues from recent posts, and... By Miranda (RL) ( 5 Years Ago )
Forum Post Hi everyone, It's fixed in version 1.1. There is no need to... By Miranda (RL) ( 5 Years Ago )
Forum Post Still fairly new to CC3 so apologies if I'm being stupid, but I've not... By jerome.dipietro ( 5 Years Ago )
Forum Post Thanks a million for this info Miranda! "7. Unity and Character... By tmhspeechdev ( 5 Years Ago )
Forum Post Hi, you mentioned that we need to go through CC3 to have our... By smileyep1 ( 6 Years Ago )
Forum Post [quote][b]smileyep1 (3/27/2019)[/b][hr]Hi, you mentioned that we need... By Miranda (RL) ( 6 Years Ago )
Forum Post Hello, this thread is great. The problem is that I followed the... By Veganism ( 6 Years Ago )
Forum Post [quote][b]Veganism (4/12/2019)[/b][hr]Hello, this thread is great. The... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, Unity3D 2019.1 just landed! There seem to be some cool... By michael.pickering ( 6 Years Ago )
Forum Post [quote][b]michael.pickering (4/16/2019)[/b][hr] Unity3D 2019.1 just... By Miranda (RL) ( 6 Years Ago )
Forum Post It would be really helpful to understand what the script is doing.... By wiverson ( 6 Years Ago )
Forum Post [quote][b]wiverson (4/22/2019)[/b][hr]It would be really helpful to... By J__s ( 6 Years Ago )
Forum Post Just tried this with Unity 2019.2 and HDRP 6.9.1 and I'm getting a... By e.l.thomas ( 6 Years Ago )
Forum Post Wow, I didn't even know that 2019.x was supported yet! Green light is... By michael.pickering ( 6 Years Ago )
Forum Post Yeah, the auto-setup script works only as far as 2018.4 currently... By Scyra ( 6 Years Ago )
Forum Post Given that there's been no official update on support for newer Unity... By michael.pickering ( 6 Years Ago )
Forum Post I'm using it on 2018.4.5 (the latest version). It doesn't work on 2019... By Scyra ( 6 Years Ago )
Forum Post Thanks! By michael.pickering ( 6 Years Ago )
Forum Post So all I had to do to fix the green light issue was untick... By e.l.thomas ( 6 Years Ago )
Forum Post [quote][b]Scyra (8/10/2019)[/b][hr]Yeah, the auto-setup script works... By Miranda (RL) ( 6 Years Ago )
Forum Post Thanks Miranda, glad to know we'll soon be able to move to Unity... By michael.pickering ( 6 Years Ago )
Forum Post Hi, can someone please tell me a way to correctly import a character... By interloko ( 5 Years Ago )
Forum Post I just did an import into a new 2019.1 HDRP project with no... By michael.pickering ( 5 Years Ago )
Forum Post [quote][b]michael.pickering (1/23/2020)[/b][hr]I just did an import... By interloko ( 5 Years Ago )
Forum Post Apologies, I just did an install of the latest version of 2019.1 but... By michael.pickering ( 5 Years Ago )
Forum Post I just checked in Unity package manager and my HDRP version is 5.7.2.... By michael.pickering ( 5 Years Ago )
Forum Post [quote][b]michael.pickering (1/23/2020)[/b][hr]I just checked in Unity... By interloko ( 5 Years Ago )
Forum Post Happy to give it a try, others on here have certainly helped me! Let... By michael.pickering ( 5 Years Ago )
Forum Post So what version of Unity and which script are you using? Is it... By michael.pickering ( 5 Years Ago )
Forum Post [quote][b]michael.pickering (1/23/2020)[/b][hr]So what version of... By interloko ( 5 Years Ago )
Forum Post Hmm, that's the same Unity version as I had! Can you provide more... By michael.pickering ( 5 Years Ago )
Forum Post [quote][b]michael.pickering (1/23/2020)[/b][hr]Hmm, that's the same... By interloko ( 5 Years Ago )
Forum Post @interloko: is there a texture size setting when export/import? I... By animagic ( 5 Years Ago )
Forum Post I got it! First I found that in my case the importer doesn't apply the... By interloko ( 5 Years Ago )
Forum Post Do you have auto-hide set to on? Did you check the box to remove... By michael.pickering ( 5 Years Ago )
Forum Post [quote][b]michael.pickering (1/24/2020)[/b][hr]Do you have auto-hide... By interloko ( 5 Years Ago )
Forum Post Hi interloko, If you'd like to adjust any settings on the model,... By Miranda (RL) ( 5 Years Ago )
Forum Post Thanks Miranda but it works diferent everyday I got this error, but... By interloko ( 5 Years Ago )
Forum Post Hi interloko, Are you trying to copy avatar definition from other... By Miranda (RL) ( 5 Years Ago )
Forum Post Hi Ryan Hayle, e.l.thomas, I will bring your suggestions and findings... By Miranda (RL) ( 5 Years Ago )
Forum Post The Character Creator and iClone Auto Setup for Unity does not work in... By Ryan Hayle ( 5 Years Ago )
Forum Post You must first import with their plugin in 2019.1 (see what version is... By ptrefall ( 5 Years Ago )
Forum Post Nice idea, but I do not wish to have to install multiple versions of... By Ryan Hayle ( 5 Years Ago )
Forum Post It would also be nice to know why Reallusion choose to put this asset... By Ryan Hayle ( 5 Years Ago )
Forum Post [quote][b]Ryan Hayle (2/5/2020)[/b][hr]It would also be nice to know... By e.l.thomas ( 5 Years Ago )
Forum Post Would there also be an existing similar way to replicate the same... By AlbinosGambit ( 5 Years Ago )
Forum Post Hello, is Version 1.01 (Release Date: 2019-08-29) the most recent... By Dan Miller ( 5 Years Ago )
Forum Post Hello. I have a problem with "Auto Setup for Unity". After import... By alex_ey ( 5 Years Ago )
Forum Post I see that you're using Unity 2019.2. I don't believe that the script... By michael.pickering ( 5 Years Ago )
Forum Post Hi alex_ey, It seems that the error message is from using the... By Miranda (RL) ( 5 Years Ago )
Forum Post maybe I'm blind but I can't find the download link for beta 2.0 it... By polycular ( 5 Years Ago )
Forum Post This is the latest version, the betas are the older versions. However... By Ryan Hayle ( 5 Years Ago )
Forum Post thx than it is a not very logical version numbering system... By polycular ( 5 Years Ago )
