ok made another test, just in case
Can you tell me if in the 1st part the GPU is not used again?
I made 3 sections
1= GPU+ CPU
2 = GPU
3= GPU + CPU with Iclone Added to the control panel from Nvidia under Manage 3D settings.
I didn't see any improvement, but looks like the log is different.
GPU + CPU
1.0 IRT rend info : Initializing context.
1.0 IRT rend info : Creating irt render context (cache id: 0x0000000100000000).
1.0 IRT rend info : Shutting down irt render context.
1.0 IRT rend info : Resource assignment for host 0 has changed.
1.0 IRAY rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 5.54383 GiB available, display attached
1.0 IRAY rend info : iray photoreal CPU fallback is enabled.
GPU only
1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 2.48881 GiB available, display attached
1.14 IRAY rend info : Received update to 00059 iterations after 65.311s.
1.14 IRAY rend info : Rendering with 1 device(s):
1.14 IRAY rend info : CUDA device 0 (GeForce GTX 1070)
1.14 IRAY rend info : Rendering...
1.16 IRAY rend info : JIT-linking wavefront kernel in 0.064s
1.16 IRAY rend info : JIT-linking mega kernel in 0.035s
1.17 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 0.101s
1.22 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 12.8458 MiB for frame buffer
1.17 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.000s)
1.17 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
1.14 IRAY rend info : Received update to 00060 iterations after 69.493s.
1.14 IRAY rend info : Received update to 00062 iterations after 71.284s.
1.14 IRAY rend info : Received update to 00066 iterations after 74.658s.
1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1070): compute capability 6.1, 8 GiB total, 2.48619 GiB available, display attached
1.14 IRAY rend info : Received update to 00074 iterations after 81.200s.
1.14 IRAY rend info : CPU: using 3 cores for rendering
1.14 IRAY rend info : Rendering with 2 device(s):
Here I added Iclone to the Nvideo Control Panel and checked always use GPU for this program
1.14 IRAY rend info : Allocating 1-layer frame buffer
1.14 IRAY rend info : Using interactive scheduling, architectural sampler unavailable, caustic sampler disabled
1.14 IRAY rend info : Initializing local rendering.
1.8 IRAY rend info : Using device 0 to build data for host
1.8 IRAY rend info : Importing lights for motion time 0
1.8 IRAY rend info : Initializing light hierarchy.
1.8 IRAY rend info : Light hierarchy initialization took 0.13s
1.5 IRAY rend info : CPU: Scene processed in 5.484s
1.15 IRAY rend info : CPU: Allocated 424.387 KiB for frame buffer
1.2 IRAY rend info : JIT-linking wavefront kernel in 1.354s
1.2 IRAY rend info : JIT-linking mega kernel in 0.032s
1.6 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 6.940s
1.15 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 12.4326 MiB for frame buffer
1.6 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.6875 GiB of work space (2048k active samples in 0.056s)
1.6 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
1.14 IRAY rend info : Received update to 00001 iterations after 8.034s.
1.14 IRAY rend info : Received update to 00002 iterations after 9.039s.
1.14 IRAY rend info : Received update to 00003 iterations after 10.044s.
1.14 IRAY rend info : Received update to 00004 iterations after 11.027s.
1.14 IRAY rend info : Received update to 00005 iterations after 12.024s.
1.22 IRAY rend info : CPU: Allocated 3.08456 MiB for frame buffer
1.18 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 9.76251 MiB for frame buffer
1.14 IRAY rend info : Received update to 00006 iterations after 12.982s.
1.14 IRAY rend info : Received update to 00007 iterations after 14.241s.
1.14 IRAY rend info : Received update to 00008 iterations after 15.485s.
1.14 IRAY rend info : Received update to 00009 iterations after 16.764s.
1.14 IRAY rend info : Received update to 00010 iterations after 17.970s.
1.14 IRAY rend info : Received update to 00011 iterations after 19.233s.
1.14 IRAY rend info : Received update to 00012 iterations after 20.483s.
1.14 IRAY rend info : Received update to 00013 iterations after 21.739s.
1.4 IRAY rend info : CPU: Allocated 2.53677 MiB for frame buffer
1.5 IRAY rend info : CUDA device 0 (GeForce GTX 1070): Allocated 10.3103 MiB for frame buffer
1.14 IRAY rend info : Received update to 00014 iterations after 22.978s.
1.14 IRAY rend info : Received update to 00015 iterations after 23.984s.
1.14 IRAY rend info : Received update to 00017 iterations after 25.903s.
