Peter (RL) (12/19/2018) After discussion we do plan to make it possible to save downloads from the Hub and keep them stored locally on your computer. So with the next Hub update in January, you will have an option in Settings to either "Clean Up" downloads as they are installed, or keep them on your computer in a central folder. This will save having to download them again if you later need to reinstall. :)Yay! Even though I've had good luck with the Hub lately, I still say, "Yay!!!" Thank you. :)
Posts: 23.1K,
Visits: 36.6K
animagic (12/17/2018)
wires (12/17/2018) Full versions of the software are so badly coded that they require an uninstall before they can be installed on a system, and at the moment it does not appear that the Hub saves a copy of any plugin patch on the user PC. Some Hub downloads are stored in C:\Users\<username>\AppData\Local\Reallusion\RLDownloads, but not all of them. For example, I don't see the CC 3 Extension. If at least the downloads could be stored there that are not available otherwise, it would allow those with limited internet speed (like myself) to install on other systems. I have two iClone 7 licenses (for four installs), so it would be really helpful not to have to download 4 times. I know the Hub must download the stuff somewhere, and it would be helpful to know where. I'm neutral on the Hub. I just want RL to take care of customers that don't have a super-fast internet. Thanks for the continued feedback on this issue. After discussion we do plan to make it possible to save downloads from the Hub and keep them stored locally on your computer. So with the next Hub update in January, you will have an option in Settings to either "Clean Up" downloads as they are installed, or keep them on your computer in a central folder. This will save having to download them again if you later need to reinstall. :)
rideroda
rideroda
Visits: 10
animagic (12/16/2018)
I've never seen that one...:unsure: In order, you can try: 1. Reboot your system and launch CC again. 2. Check if your graphics drivers are up-to-date. If they needed updating, repeat step 1. 3. If none if this helps, it is time to contact RL Support: https://www.reallusion.com/CustomerSupport/UserEx/QForm.html. Thanks for your answer 1) Done 2) my graphichs card has the latest drivers 3) to do :(
Last Active: 5 Months Ago
Posts: 15.8K,
Visits: 31.4K
Last Active: 5 days ago
Posts: 5.7K,
Posts: 23.1K,
Visits: 36.6K
wires (12/16/2018)
wires (12/7/2018)
Peter (RL) (12/7/2018)
wires (12/7/2018) It would be very helpful if users had access to the patch downloads - even those used by this crappy Hub - for storing on their systems. RL are becoming experts at making life as difficult for users wishing to keep their paid for software up to date. Even their brainless "full" installer can't work if a previous version is present, forcing the user to constantly uninstall and reinstall when they are denied access to a patch version.Hi Gerry You should still be able to go to Help > Check For Update to find the downloadable updates. These can then be stored on your computer if you wish. This does not work for plugins, there is no Help>Check for Update available. Still waiting for a solution, other than the crappy Hub, for this issue. :Whistling: Hi Gerry I understand that you are not a fan of the Hub but with an increasing number of plug-ins being introduced, we believe the Reallusion Hub is the best way to ensure your programs and plug-ins get installed in the correct order and are kept up to date. As I mentioned previously, you can still download full versions of our software from your Member Account > Registration page, and download software updates by going to Help > Check For Update once a new update has been released. However there are no plans at this time to go back to the old way of making all updates available to download from Member Accounts.
Posts: 15.8K,
Visits: 31.4K
rideroda (12/11/2018)
Hello, i have this issue with CC3 :  Can you help me please? Thanks I've never seen that one...:unsure: In order, you can try: 1. Reboot your system and launch CC again. 2. Check if your graphics drivers are up-to-date. If they needed updating, repeat step 1. 3. If none if this helps, it is time to contact RL Support: https://www.reallusion.com/CustomerSupport/UserEx/QForm.html.
Posts: 5.7K,
wires (12/7/2018)
rideroda
rideroda
Visits: 10
modernstoryteller
modernstoryteller
Visits: 316
Thanks Peter. I got the Pipeline Extension Update and it works fine now!
