What's New in Character Creator 3.03
https://forum.reallusion.com/Topic396915.aspx
Print Topic | Close Window
By Peter (RL) - 8 Years Ago
Dear Character Creator users,
The Character Creator 3.03 update has now been released.
Important: To get the update, please use the Reallusion Hub.
Note: Character Creator 3 Pipeline users need to install two updates. One for the CC3 Base and one for the Pipeline Extensions. Both are included in the Reallusion Hub under the Updates tab.
v3.03 (3.03.1205.1) released on Dec. 6th, 2018
The CC 3.03 update includes several enhancements and bug fixes.
Added:
  • New HDRP map will now be exported when using the Unity FBX export preset.
  • Enhanced:
  • Enhanced performance for IBL blur, in turn, increasing the frame rate for the default project.
  • Delete Hidden Mesh can now be applied to meshes with merged materials.
  • Objects without UV information are supported, but does not support InstaLOD.
  • Added skin weight template for knee-high boots.
  • Fixed:
  • Importing a G8F character without eyelashes into CC, will dislocate its eye bones.
  • Inability to apply hair to CC3 characters. Feedback Tracker
  • Probability of sampling mistakes with the Transformer texture baker.
  • Application crash from lack of skin data for clothing assets brought in by Transformer.
  • Application title bar does not update after performing Save Project as to a different project file name. Feedback Tracker
  • Performing undo (Ctrl+Z) in Conform > Edit Range removes selection and turns on vertex mode. Feedback Tracker
  • Daz G2F/G2M imported with Transformer lack the "Eye Reflection" material. Feedback Tracker
  •    Some of the lower lip vertices aren't in the right places for the neutral base in the default project. This can cause problems and inaccuracies with morph shapes derived from this mesh.
  • Dislocation of the teeth and tongue upon application of the CC3 Base Male Head / Body or Female Head / Body morph slider.
  • By wires - 8 Years Ago
    Why doesn't the HUB save the patch files in the RL Download folder for the user?
    By hj - 8 Years Ago
    no, not in my HUB
    nothing more
    How can i get the updater for CC3.02 to CC3.03
    best
    Hans Jörgen
    By Postfrosch - 8 Years Ago
    and not in my HUB
    The same as with hj
    Greets Postfrosch
    @HJ, @Postfrosch
    If the Character Creator 3.03 Base update isn't listed, please try going to Help > Check For Update in CC3, or alternatively click the Download  link for CC3 on your Member Account > Registration page.
    You should be able to update that way.
    By hj - 8 Years Ago
    Hi Peter
    In that way i do not get the update, i only get he new full-version.
    Therefore i have to uninstall CC 302 with all Components .
    I whant to get the Update may you can publish a link to the updat-software
    best
    Hans Jörgen
    PS
    I got your link, thank you
    By jarretttowe - 8 Years Ago
    I still had to download the resource pack when I updated...it worked fine, but that is a 2gb download!
    It would be very helpful if users had access to the patch downloads - even those used by this crappy Hub - for storing on their systems. RL are becoming experts at making life as difficult for users wishing to keep their paid for software up to date. Even their brainless "full" installer can't work if a previous version is present, forcing the user to constantly uninstall and reinstall when they are denied access to a patch version.
    wires (12/7/2018)
    Hi Gerry
    You should still be able to go to Help > Check For Update to find the downloadable updates. These can then be stored on your computer if you wish.
    Peter (RL) (12/7/2018)
    wires (12/7/2018)
    Hi Gerry
    This does not work for plugins, there is no Help>Check for Update available.
    By animagic - 8 Years Ago
    It would be so much easier just to go back to the system we had before the fancy website update: With each product list the full download and the latest patch. Some users are sophisticated enough to update that way.
    Also, for those in areas that don't have super-fast internet, downloading once is really much more convenient if you have multiple installations to update. I recently moved from an urban to a rural area and there is is a big difference in speed.
    By justaviking - 8 Years Ago
    Why can't we have both?
    Although I have had good luck with the Hub lately, I do miss being able to download and keep a local copy of the files - both full installs and patches.
    It's not like I'm going to pirate them.  I need an internet connection and a valid license to make them functional.
    As Job said, for installing on two machines (as is legally permitted per the license agreement), it's nice to only download once.  And if you ever need to roll back and/or reinstall something, then you already have the files at your fingertips.
    Please provide access to downloadable copies of the software, both current and past.
    I too would be in favor of being able to download the patches again as was possible in the past.
    I did not understand today why RL deviated from this reasonable future.
    The RL Hub may be great for some users, but the old system was a lot better. The HUB crashes occasionally or shows no updates or just halfway on (as in the last patch of CC 3). Also, the resource package had to be reinstalled was not displayed by the hub (but was not made known by RL)
    Greets from Germany
    Postfrosch
    By modernstoryteller - 8 Years Ago
    Hi Peter
    According to your post, the new version of CC should mean: "Delete Hidden Mesh can now be applied to meshes with merged materials."
    However, I have the latest version and when I go to export a character, I check the "Delete hidden mesh" box, but as soon as I click the "Merge Materials" box, it automatically greys out and unchecks "Delete hidden mesh".
    So unless I've misunderstood, these features are still not compatible.
    By VirtualMedia - 8 Years Ago
    While this topic is still active could RL please fix the content activation system as well. Activating the same content 100's of times is not a proper way to treat customers.
    Simple fix suggestion - Activate after install - lock to application serial number and or machine - happy customer - done!
    wires (12/7/2018)
    wires (12/7/2018)
    Hi Gerry
    As you rightly say you can't download plug-in updates this way but software updates can be downloaded using Help > Check For Update.
    Thank you all for the feedback regarding downloads. I have passed this on for review and further discussion.
    modernstoryteller (12/9/2018)
    Hi Peter
    Hi...
    "Delete Hidden Mesh" should be working fine with merged materials after the 3.03 update. I just tested and was able to export with "Delete Hidden mesh" checked.
    Are you certain you updated both the CC3 Base and CC3 Pipeline Extensions to 3.03? If you only did the base update then that will be the problem.
    VirtualMedia (12/10/2018)
    Can you explain more about this because you certainly shouldn't need to constantly activate your content. You should only need to do it once and that's it.
    Is it just one particular content pack or does this happen with all packs?
    Also have you been in contact with Technical Support (or used the Feedback Tracker) about this because I'm not aware of this being a common problem or one that needs a general fix.
    hj (12/6/2018)
    no, not in my HUB
    data:image/jpeg;base64,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
    data:image/jpeg;base64,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
    nothing more
    How can i get the updater for CC3.02 to CC3.03
    best
    Hans Jörgen
    UPDATE: This issue should now be fixed for German account holders who have CC3 Pipeline. We do apologise for the inconvenience caused.
    By modernstoryteller - 8 Years Ago
    Thanks Peter. I got the Pipeline Extension Update and it works fine now!
    By rideroda - 8 Years Ago
    Hello,
    i have this issue with CC3 :
    https://forum.reallusion.com/uploads/images/536998c6-f3dd-4540-b842-863b.jpg
    Can you help me please?
    Thanks
    By wires - 8 Years Ago
    wires (12/7/2018)
    Peter (RL) (12/7/2018)
    wires (12/7/2018)
    It would be very helpful if users had access to the patch downloads - even those used by this crappy Hub - for storing on their systems. RL are becoming experts at making life as difficult for users wishing to keep their paid for software up to date. Even their brainless "full" installer can't work if a previous version is present, forcing the user to constantly uninstall and reinstall when they are denied access to a patch version.
    Hi Gerry
    You should still be able to go to Help > Check For Update to find the downloadable updates. These can then be stored on your computer if you wish.
    This does not work for plugins, there is no Help>Check for Update available.
    Still waiting for a solution, other than the crappy Hub, for this issue. :Whistling:
    By animagic - 8 Years Ago
    rideroda (12/11/2018)
    Hello,
    Thanks
    I've never seen that one...:unsure:
    In order, you can try:
    1. Reboot your system and launch CC again.
    2. Check if your graphics drivers are up-to-date. If they needed updating, repeat step 1.
    3. If none if this helps, it is time to contact RL Support: https://www.reallusion.com/CustomerSupport/UserEx/QForm.html.
    By Peter (RL) - 8 Years Ago
    wires (12/16/2018)
    wires (12/7/2018)
    wires (12/7/2018)
    Hi Gerry
    Hi Gerry
    I understand that you are not a fan of the Hub but with an increasing number of plug-ins being introduced, we believe the Reallusion Hub is the best way to ensure your programs and plug-ins get installed in the correct order and are kept up to date.
    As I mentioned previously, you can still download full versions of our software from your Member Account > Registration page, and download software updates by going to Help > Check For Update once a new update has been released.  However there are no plans at this time to go back to the old way of making all updates available to download from Member Accounts.
    Full versions of the software are so badly coded that they require an uninstall before they can be installed on a system, and at the moment it does not appear that the Hub saves a copy of any plugin patch on the user PC.
    wires (12/17/2018)
    Some Hub downloads are stored in C:\Users\<username>\AppData\Local\Reallusion\RLDownloads, but not all of them. For example, I don't see the CC 3 Extension.
    If at least the downloads could be stored there that are not available otherwise, it would allow those with limited internet speed (like myself) to install on other systems.
    I have two iClone 7 licenses (for four installs), so it would be really helpful not to have to download 4 times. I know the Hub must download the stuff somewhere, and it would be helpful to know where.
    I'm neutral on the Hub. I just want RL to take care of customers that don't have a super-fast internet.
    animagic (12/16/2018)
    Thanks for your answer
    1) Done
    2) my graphichs card has the latest drivers
    3) to do :(
    animagic (12/17/2018)
    wires (12/17/2018)
    Thanks for the continued feedback on this issue.
    After discussion we do plan to make it possible to save downloads from the Hub and keep them stored locally on your computer. So with the next Hub update in January, you will have an option in Settings to either "Clean Up" downloads as they are installed, or keep them on your computer in a central folder. This will save having to download them again if you later need to reinstall. :)
    By justaviking - 8 Years Ago
    Peter (RL) (12/19/2018)
    Yay!
    Even though I've had good luck with the Hub lately, I still say, "Yay!!!"
    Thank you.  :)
