Crazy Talk Animator 3.3.3007.1 ver we used dummy G2 Character Replacement problem
Posted By gvraju.666 8 Years Ago
3
Crazy Talk Animator 3.3.3007.1 ver we used dummy G2 Character...
agastyamedia2018
agastyamedia2018
New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)
Last Active: 7 Years Ago
Posts: 1, Visits: 14
we are also problem in g2 270 sprite replacemrnt
gvraju.666
gvraju.666
Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)
Posts: 16, Visits: 65
hello sir
we had a problem in 270 gs sprite replacement ....pls give video tutorial...are any in steps to over come that  270 g2 sprite replacement
gvraju.666
gvraju.666
hello sir
we request u sir pls  give us a video tutorial for rigging 270 angle in crazytalk animator with using flash
in CTAstepbystep we r not  getting any rigging tutorial so pls give us url link YouTube link to us
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
Ok, here is the issue: To use the Mirror function in Composer Mode you MUST have ALL the sprites for ALL angles loaded before executing the Mirror Function.
If you load a sprite for each angle for a body part then it will work. Loading just angle 270 and trying to use the mirror function Will Not Work.
Jeff
gvraju.666
gvraju.666
hello sir
thank for replay ..sir we r using only vectors sir ..we or attaching the  vectors to u pls give us a reliable answer ...
we r not getting how to rig in 270 angle sir
270.rar (106 views, 5.00 KB)
jlittle
jlittle
Ok, I see the problem now!
You are trying to mirror the right side to the left in the 270 angle.
I believe the Mirror function only works on Vector sprites and not Image sprites.
If you are using images then it will not work.
If you are using vector sprites then it will work.
Jeff
gvraju.666
gvraju.666
Hello
sir the the problem in 270 angle  mirror issue is not mirroring
sir pls send us a reliable answer ..with video tutorial ...pls we requesting  u ...pls solve our problem
this attached file
jlittle
jlittle
Go to your profile page. On the left at the bottom there is a section called "Options"
Click on the "Edit Attachments".
Select and Delete attachments until you have room.
Jeff
gvraju.666
gvraju.666
https://forum.reallusion.com/uploads/images/3f647d6d-186a-48db-8b08-cb73.jpg
https://forum.reallusion.com/uploads/images/99a47676-d107-4fef-b740-56eb.jpg
it is not mirroring
sir we r trying to  attached file  file...but file is not uploading in this reallusion forum ..tell that space problem how to recover it and how to send the file
jlittle
jlittle
Attach the character with the issue here and I will look at it.
Jeff
3
