Crazy Talk Animator 3.3.3007.1 ver we used dummy G2 Character Replacement problem
Posted By gvraju.666 7 Years Ago
3
Crazy Talk Animator 3.3.3007.1 ver we used dummy G2 Character...
gvraju.666
gvraju.666
Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)
Last Active: 6 Years Ago
Posts: 16, Visits: 65
1 =
Hey so i'm new to crazy talk animator 3 and i'm trying to make a custom G2 character. For some reason in the sprite editor I cant replace the sprites for different angles. First i put the template G2 dummy character in stage and then switch to composer mode.I then click on left forearm and sprite editor button to change it success.
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/21753add-fd13-4b58-a10c-86b0.jpg
 When i open the it in stage mode 270  it is not visible to me.in  other angles also it get same problem -
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/17fb8410-6c68-4738-980e-7ec6.jpg
again tried to fix the sprite replacement run time composer..
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/736d9c39-8556-490f-b6ad-e970.jpg
then i open the composer mode it visible..when i mirror it at right side
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/033ebe04-dbd1-4b1f-a0e0-ee40.jpg
and test it in stage mode with 2d motion key editor the sprits of other side is not visible
pls tell us the right way to  how to add sprits in different angle  0-45-90-135-180-225-270-315-
we already seen the tutorial of basic character creation -with sprite replacement in 0 angle.. we need 45 and 270 angled base tutorial ...
in crazytalk animator 3 ...
And with flash white paper Pipeline_Template_and_Tools
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
After you edit a character in Composer Mode and return to the stage it will show at the angle before it went into composer mode.
While in Composer or Stage Mode you can rotate the character using the bracket ("[", "]") keys.
To replace sprites at any angle, in Composer Mode, rotate the character to that angle. If you have the Sprite Editor open, with a sprite selected, you can see the sprite change as you rotate the character.
At the selected rotation angle,select and replace the sprite using the "Replace Current Angle" function (Ctrl+Shift+R).
Size, rotate, and position the new sprite as needed.
Rinse and repeat for the other sprites and angles.
Jeff
gvraju.666
gvraju.666
sir
we r not able to get the YouTube  tutorial  the sprite using the replace current angle " function based tutorial  link in step by step crazy talk animator 3
 pls send us url link of that ,pls help us ..
gvraju.666
gvraju.666
hello sir
we tried to replace as u said before -  " replace current angle"  { Ctrl+shift+r } for replace current angle  with g2 dummy we replaced 0-45-315 in composer mode and copied similar to 45-315 in sprite editor
it is good in composer mode when we tested using brackets  . in stage mode O- 45-315 also good
but in stage mode we got a problem -90-135-180-225-270 angles  the left lower hand is showing  in stage mode
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/cb25bbf3-f235-47e3-8d40-1cf6.jpg
then we test in composer mode 93% of original size (was 543x16) - Click to enlarge
it is good in composer mode ..in stage mode their is problem  in other angles -90-135-180-225-270-
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/d593d198-7813-4b8e-8e1e-2736.jpg
pls  tell the way to over come ...we need u r support in clear cut method...we already seen g2 character creation videos ..in that u r showing only for 0 degree angle -- and   with white paper tool of flash...beyond that we need support of character creation in 45-90-180-225-270-315 method in crazy talk animator 3
pls help us sir
jlittle
jlittle
Here is a short video showing step by step G2 character sprite replacment.
gvraju.666
gvraju.666
HELLO SIR THANK U FOR SEND  VIDEO TO US .WE TRIED IT ..PLS SEE THIS PICS
WE APPLIED A SPRITE IN 270 ANGLE .. IN COMPOSER MODE  IN COMPOSER MODE WE SEEN ALL THE ANGELS NO PROBLEM FOUND ..THEN WE BACK TO STAGE MODE.
IN STAGE MODE  THE SPRITE NOT VISIBLE  IN 270 ANGLE   SEE THE PIC
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/5b9c5721-06ff-4397-a3bb-3ee2.jpg
IT VISIBLE IN 315
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/74d743f1-caef-4872-97aa-ef53.jpg
THIS PROBLEM AGAIN  IN STAGE MODE WE TRIED THIS WAY
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/2abaefa7-ab7e-4ea2-9f32-d60f.jpg
WHEN WE SEE IT COMPOSER MODE ITS GOOD
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/4a5adb3e-6342-483b-b94a-7928.jpg
AGAIN STAGE MODE  WE SEEING THE SPRITE IN ALL MODES  WE HAVE A PROBLEM
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/a81ab274-ee7e-4171-9785-dd1a.jpg
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/1a859161-b0da-42f0-bd6b-651a.jpg
THIS PROBLEM .... WE GETTING FROM THE DAY  WE USE THE SOFTWARE CRAZY TALK ANIMATOR 3.3.3007.1 PLS HELP US RECOVER
PLS GIVE US A PROPER RELATED VIDEO TO  RECOVER ALL THIS PROBLEM  SIR ....PLS UNDERSTAND US AND GIVE MAIL ALSO ...
jlittle
jlittle
Do the sprite replacement on the character.
Save the character from the Stage.
Right click on saved character in Content Manager and use "Find File" to locate character file.
Zip file and post here as attachment.
That way I can see the issue using your character.
Jeff
gvraju.666
gvraju.666
HELLO  SIR
    WE DON AS U SAID  ..SEE ONCE  RAR FILE  AND PIC
 93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/25859819-f9ef-44e0-b778-4666.jpg
AND IN COMPOSER MODE
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/c7548557-cb58-4d6f-b89d-7c4d.jpg
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/9286c1fa-6f50-4bd7-b9f2-677a.jpg
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/afc53e23-fac4-4d7d-b606-dad2.jpg
IN STAGE  MODE
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/5fa129fa-e6b0-47af-968e-4531.jpg
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/73312737-3129-4c0b-b654-0a1c.jpg
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/b3dadf3b-9572-49d5-8acb-540a.jpg
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/3a1b4681-28ff-41dd-b5c4-888d.jpg
THIS THE PROBLEM WE GOT
WE OR SENDING { THE STAGE MODE SAVED FILE  } AND ALSO  {  COMPOSER MODE   SAVED FILE } ...IF WE HAVE DON ANY WRONG WAY TELL US THE PROPER WAY ...
PLS RECTIFY OUR PROBLEM SIR ....
AFTER RECTIFYING THIS PROBLEM PLS SEND A VIDEO FILE TUTORIAL RECOVER THIS  .... WE U R HELP
jlittle
jlittle
Ok, I see the issue now.
What the problem is, is that the Fore Arm is not at the same angle as the character is.
This seems to be an issue even with the 3D Ref Guy character so might be present in all characters.
See the picture below with your character and 3D Ref Guy character at angle 270.
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/1bb0ea58-bba9-4509-af33-6288.jpg
Note that the Fore Arm is at angle 225, not 270.
Rotating the characters to angle 315 we see:
93% of original size (was 543x16) - Click to enlargehttps://forum.reallusion.com/uploads/images/73dc5407-4476-44bb-a921-4496.jpg
That the characters Fore Arm is at 270 instead of 315 and your 270 sprite now shows up.
You can use the 3D Motion Key Editor to correct this.
Once corrected the Fore Arm sprite will now be in sync with each character angle.
Jeff
gvraju.666
gvraju.666
hello sir
thank u sir ..
sir  we need help that in your tutorials  potato character is rigged in 0  and pasted in  45 and 315  angles .
we need 270 and 315 angels and other angels to rig in crazy talk animator ...is their any possibilities to do it in only crazy talk animator with out using flash or animate cc ..templates  files
pls help us to rig 270 ,315 angles and  in which angles we use to comping sprites similar to  in other angles in
 270 an 315 ...
 pls  help us again we r getting the stage mode problem which i posted Posted 3 days ago earlier to u sir
is they any problem in software any possibility  to re download it ..pls inform us sir
3
