Visits: 22.1K
I wish I had that outfit so I could test it for you. Perhaps next month (I've bought enough for this one, unfortunately). You might want to try with a different, older one where I *can* be of more help and revisit this one later.
Kiwi-Hawk
Kiwi-Hawk
Last Active: 8 Months Ago
Visits: 990
Kia ora
When your right @Kellyrtoons your right, for some reason Daz is NOT skinning the clothing so it's not being seen correctly
Visits: 22.1K
Yeah, as Ani mentions your problem is in Daz, not CC3. When you load in separate items from an outfit (as opposed to loading the entire outfit all at once) you MUST always have the base figure selected first. Daz won't correctly either skin or otherwise parent those items, and CC3 has no way of adjusting. Since I don't have this particular outfit I cannot try it for you, but I'm sure CC3 will work correctly when you get it correct in Daz. For that outfit there ought to be a "load outfit" option -- I've never seen a Daz one that didn't have that. With the base figure in Daz selected, use THAT instead and import into CC3 and all should be well. Otherwise you'll need to try a different outfit that I might have in order to help you (as I said, I have nearly everything about a month after it's released -- so something from a month ago would be fine).
Kiwi-Hawk
Kiwi-Hawk
Visits: 990
Kia ora
It seems that in this case where Daz loads items parented to other items and not the character, eg the skirt was parented to the leggings so it layed above and the bag parented to the belt for the same reason, they get dropped when Daz exports them and are NOT exported. Tho that does not explain the lack of options limiting it to a choice of hair or Accessory in the drop down
Edit:
I'm not sure if this is correct or not but I exported a copy as an A (default Gen-8 pose) and loaded it into 3D Max and I se there no skining on the clothing so Dac 3D is not skinning this outfit it would seem
Kiwi-Hawk
Kiwi-Hawk
Visits: 990
Kia ora
Thank you Animagic I missed that, I went back to the video and he did not mention that so I missed it, trying again
Posts: 15.8K,
Visits: 31.4K
In DAZ you do not have Merge Clothing into Figure Skeleton selected, so the clothing will not move with the body.
Kiwi-Hawk
Kiwi-Hawk
Visits: 990
Kia ora
@Kellytoons Ellandra is the base Gen 8 female with Luthril as the character form and your right Wild Winds Outfit
Opps oh and to be clear I open CC3 and click transform and do NOT save the base character which is trhe CC3 starter character that loads
Kiwi-Hawk
Kiwi-Hawk
Visits: 990
Kia ora I'm sorry BUT I'm just not getting this at all, following the instaructions to the letter From this in Daz:  To this in CC3:  I movered the legging forward to be PC correct, so they are not where they imported to and the skirt just did not make it at all.
Visits: 22.1K
You have a weird setup there -- it looks (at least at first glance) that you are trying to apply Transformer to a CC1 character, which it is not designed to do (it's for Genesis and Hivewire characters). That would explain the errors you are getting. Or perhaps I just don't understand what it is you have setup there. Let me know what character you are trying to import and what outfits and I'll see what I can do (no sense trying my routine if we can't get you at least straightened out here). Edit: I think you're trying the Wild Wind Outfit for Gen 8, an outfit so new even *I* don't have it (I usually wait until things go on sale, or at least a few weeks after they are out). But I'd still like to know what character you are trying this with and I can try her with another outfit to see what's going on.
Kiwi-Hawk
Kiwi-Hawk
Visits: 990
Kia ora I'm noticing some changes since they updated and it's not good from what I see I had no problems with the first imports but now after the up date only two choice's and everything is bound to the wrong bone(s)  @Kellytoons BTW I have not managed to find the download link to you profile creator as ya to se if that helps
