Having issues with the new Character Creator 3
Posted By StrangeMotions90 8 Years Ago
StrangeMotions90
StrangeMotions90
Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)Veteran Member (550 reputation)
Posts: 24, Visits: 153
Having quite a few problems with my reallusion products. Firstly I'm not able to use my reallusion hub, it won't update my iClone 7, 3DXchange 7 or Curve Editor also I'm unable to download and install the Character Creator 3 Resource Packs as it keeps staying that I've disconnected from the internet when I haven't, my internet connection is perfectly fine. Another thing that I'm having issues with is exporting my Daz characters to CC3 as it exports the characters without the skin texture materials. Has anyone else had these issues and is there currentlyhttps://forum.reallusion.com/uploads/images/571bd767-86e8-4900-a3be-9454.jpg a solution for any of these problems? Would really appreciate the help.
Threaded View
Threaded View
Forum Post Having issues with the new Character Creator 3 By StrangeMotions90 ( 8 Years Ago )
Forum Post Same problem here with the Hub. But at least you did get CC3... By larrygj ( 8 Years Ago )
Forum Post I installed updated my iClone 7 to iClone7.3 this morning and now when... By Delerna ( 8 Years Ago )
Forum Post CC3 shows on new Reallusion Hub only. Not sure whether your... By Edward (RL) ( 8 Years Ago )
Forum Post Peter (RL) said that there were issues with the Hub, but that doesn't... By animagic ( 8 Years Ago )
Forum Post Yes I did it the old fashioned way at first. One thought I had was... By Delerna ( 8 Years Ago )
Forum Post I have no base CC3 in my downloads, so basically nothing works! Really... By Spiny Norman ( 8 Years Ago )
Forum Post I checked the HUB this am. found 2 updates. IC7 and 3dx7P. I... By Alien Maniac ( 8 Years Ago )
Forum Post I was eventually able to update iC7, 3DX7 and Curve editor as well... By StrangeMotions90 ( 8 Years Ago )
Forum Post [quote][b]StrangeMotions90 (9/28/2018)[/b][hr] I was eventually able... By Peter (RL) ( 8 Years Ago )
Forum Post Yes I have embed textures checked and I have also followed the... By StrangeMotions90 ( 8 Years Ago )
Forum Post [quote][b]StrangeMotions90 (9/28/2018)[/b][hr]Having quite a few... By Peter (RL) ( 8 Years Ago )
Forum Post Do you happen to know what the problem is with my exporting Daz... By StrangeMotions90 ( 8 Years Ago )
Forum Post Hi Peter, pls could you reconfirm what FBX export option should be... By Brick Loko ( 8 Years Ago )
Forum Post [quote][b]Brick Loko (9/28/2018)[/b][hr]Hi Peter, pls could you... By Peter (RL) ( 8 Years Ago )
Forum Post I eventually found CC3 pipeline amongst a list of downloads on my... By swordflasher ( 8 Years Ago )
Forum Post After you import your avatar to CC3 via "Transformer" you get an Asset... By Galfridus ( 8 Years Ago )
Forum Post Thank you so much Geoff, I'm now able to do what I set out to do. By StrangeMotions90 ( 8 Years Ago )
Forum Post [YouTube]https://www.youtube.com/watch?v=GeF-BMOFjDE&t=19s[/YouTube]... By Kelleytoons ( 8 Years Ago )
