Visits: 22.1K
StrangeMotions90
StrangeMotions90
Visits: 153
Thank you so much Geoff, I'm now able to do what I set out to do.
Galfridus
Galfridus
Visits: 2.2K
After you import your avatar to CC3 via "Transformer" you get an Asset Import Status report screen. Make sure the Bake Body Texture option in the top left hand corner is checked before you press OK to proceed. If you don`t, you get the CC texture on your avatar by default. Geoff.
93% of original size (was 541x16) - Click to enlarge
StrangeMotions90
StrangeMotions90
Visits: 153
Yes I have embed textures checked and I have also followed the tutorial shown on the RL YouTube channel, I have tried it with both FBX 2012 Binary and 2011 and still end up with the same results. 93% of original size (was 541x16) - Click to enlarge
Posts: 23.1K,
Visits: 36.6K
Brick Loko (9/28/2018)
Hi Peter, pls could you reconfirm what FBX export option should be used at DAZ (FBX 2012 or FBX2011). I'm asking, since on the tutorial video about importing Daz Characters ( https://www.youtube.com/watch?v=uuhCCgJQHYk&t=515s) posted today at RL Youtube channel, the option used was FBX2011. And you informed FBX2012 on the above post Bellow is a print screen from the video
Thanks a lot for all you support.Do also ensure you are using FBX 2012 Binary in the Output Options. The screenshot below is taken from the manual. As you can see FBX2012 Binary is the one you should use. It doesn't mean 2011 won't work but we strongly recommend FBX 2012 Binary. 93% of original size (was 541x16) - Click to enlarge
swordflasher
swordflasher
Visits: 287
I eventually found CC3 pipeline amongst a list of downloads on my account.
But when CC3 starts up I first get a box saying, 'unsaved project data found' and the chance to replace a character creator restore file that exists in my documents [haven't tried that as it already exists]. Then when the program starts a message says 'get new serial number error no internet' and it closes itself. I've registered it. I have internet.
I tried looking for updates on the hub but all my products are up to date.
What now?
*edit* I tried replacing the restore file as the box suggests. Now CC3 opens for a few seconds but looks weird, and disappears without an error message.
Should I try uninstalling and reinstalling CC3?
*edit* and now it has randomly started working! As you were. [ ;
Brick Loko
Brick Loko
Visits: 1.4K
93% of original size (was 541x16) - Click to enlarge Do also ensure you are using FBX 2012 Binary in the Output Options.
Posts: 23.1K,
Visits: 36.6K
StrangeMotions90 (9/28/2018) I was eventually able to update iC7, 3DX7 and Curve editor as well as download the resource packs but I'm still having the same issue with exporting a character with its skin texture materials. The whole reason for me buying CC3 was for the export feature and I can't get it to work at all, it's seriously frying my brain. I'm following all the tutorials RL has uploaded exactly as they show but I never end up with the right results, I know this is the release version but CC3 is really glitchy, it's soo bad. With how many problems I've come across personally as well as other creators I know, it doesn't look like anyone having a good time with this.
Do you have "Embed Textures" checked on the Daz Studio export page. This should ensure that the Diffuse textures are correctly assigned when you use Transformer. Do also ensure you are using FBX 2012 Binary in the Output Options.
StrangeMotions90
StrangeMotions90
Visits: 153
Do you happen to know what the problem is with my exporting Daz characters? I'm still unable to export any of my characters with their skin textures, also when I try to pose them they end up looking disfigured.
Posts: 23.1K,
Visits: 36.6K
StrangeMotions90 (9/28/2018) Having quite a few problems with my reallusion products. Firstly I'm not able to use my reallusion hub, it won't update my iClone 7, 3DXchange 7 or Curve Editor also I'm unable to download and install the Character Creator 3 Resource Packs as it keeps staying that I've disconnected from the internet when I haven't, my internet connection is perfectly fine. Unfortunately our servers became overloaded for several hours after the release of CC3 which caused the Reallusion Hub issues and the activation issues. This should all be resolved now. We do apologise for the inconvenience this issue caused.
