Posts: 23.1K,
Visits: 36.6K
wires (9/30/2018) I'm getting massive screen flicker when Mesh Edit is selected, makes using it almost impossible.
Anyone else seeing this?Hi Gerry... Obvious question, but are you using the latest graphics drivers which CC3 prompts about? This issue can occur with older graphics drivers.
Posts: 23.1K,
Visits: 36.6K
Rogue Anime (9/29/2018)
Postfrosch (9/28/2018) Why can you start the avatar in CC 3 not edit with the Apearance Editor ????INDEED?!?! It does not work on ANY characters CC3 or otherwise!! I AM LIVID! What in the HELL have they DUMPED on us here? Unfortunately the Appearance Editor does not currently support the new CC3 Base but we are working on it. For now you can use the Appearance Editor with a CC1 Base and then convert to CC3 Base. Please do keep a check on the "Known Issues" page below for some tips and workarounds on known issues. https://forum.reallusion.com/381995/Special-Notice-Known-issues
Posts: 5.7K,
Peter (RL) (10/1/2018)
Anyone else seeing this?Hi Gerry... Obvious question, but are you using the latest graphics drivers which CC3 prompts about? This issue can occur with older graphics drivers. Driver version and GPU are visible below in my system specs. I've been using them for a few weeks now.
Posts: 23.1K,
Visits: 36.6K
animagic (9/28/2018) A minor issue. When saving a character in CC 3, the thumbnail is allows a "quick" thumbnail, regardless of the settings in Project Preferences.
If this is confirmed by others, I will enter this in FT. (I'm surprised this was overlooked, frankly.)I can't reproduce this myself. I get a Quick Thumbnail if the box is checked in Preferences but not if the box is unchecked.
Posts: 15.8K,
Visits: 31.4K
wires (9/30/2018) I'm getting massive screen flicker when Mesh Edit is selected, makes using it almost impossible. Anyone else seeing this?Gerry, make sure TAA is switched off (Shift T) in program preferences.
duchess110
duchess110
Last Active: 6 Years Ago
Posts: 2.0K,
Visits: 15.5K
Not sure if it is me but I have checked for videos and checked the online manual on Creating Morph Sliders. I was able to easily do this in CC2 but with CC3 it keeps crashing. I fill in the info and the path all as the manual. This is what it is saying causes the problem. Problem Event Name: APPCRASH Application Name: CharacterCreator.exe Application Version: 3.0.926.1 Application Timestamp: 5bab3b51 Fault Module Name: RLMmfU.dll Fault Module Version: 0.0.0.0 Fault Module Timestamp: 5bab2f91 Exception Code: c0000005 Exception Offset: 000000000000560e Has anyone tried this and had success if so please let me know how. edit update typing error
Duchess Designs Store
Posts: 5.7K,
animagic (10/1/2018)
wires (9/30/2018) I'm getting massive screen flicker when Mesh Edit is selected, makes using it almost impossible. Anyone else seeing this?Gerry, make sure TAA is switched off (Shift T) in program preferences. Thanks Job. A much more informed and helpful answer than the "update your drivers". The question however still remains - why is it happening?
duchess110
duchess110
Posts: 2.0K,
Visits: 15.5K
duchess110 (10/1/2018) Not sure if it is me but I have checked for videos and checked the online manual on Creating Morph Sliders. I was able to easily do this in CC2 but with CC3 it keeps crashing. I fill in the info and the path all as the manual. This is what it is saying causes the problem.
------------------------------------------------------------------------------------------ UPDATE Got the morph to finally import but I still get the same crash on closing Fault Module Name: RLMmfU.dll so still unsure if me or not.
Steelsky
Steelsky
Visits: 570
@wires: Hello! Your drivers actually are old and in need of update, if what is in your quote is right. You say in your subtitle thing that your driver version is 399.07. That is a couple months old. The latest GeForce driver version is 411.70. Nvidia made a lot improvements especially during in the September releases. I don't know about CC3, but I know September driver update fixed a flickering issue in PUGB.
Posts: 15.8K,
Visits: 31.4K
wires (10/1/2018) Thanks Job. A much more informed and helpful answer than the "update your drivers". The question however still remains - why is it happening?I don't know why. With TAA enabled, I've had the same in CC2, and also with the grid in iClone.
