Posts: 23.1K,
Visits: 36.6K
Thank you all for the excellent feedback in this thread. We have now released the Character Creator 3.01 update so please post all 3.01 issue reports in the thread below. This thread will now be closed. https://forum.reallusion.com/388910/OFFICIAL-Character-Creator-301-Issues-ThreadThank you.
Posts: 23.1K,
Visits: 36.6K
Rogue Anime (10/10/2018) Someone may have already reported this, but when I try to 'save' it forces me to 'save as' and overwrite the project file. ~V~You can use the "Replace" button if you wish to update an existing project. If you wish to save as a new file you can use the "Add" button. http://manual.reallusion.com/Character_Creator_3/ENU/3/Default.htm#Character_Creator_3/3/04_Introducing_the_User_Interface/Content_manager.htm
Posts: 23.1K,
Visits: 36.6K
digitalworlddreamer (10/12/2018)
Hi Peter, Having trouble with loading Character Creator 3 pipeline trial version, I'm actually interested in buying but for some reason can't get it loaded.. See my error message attached and information about my computer Dxdiag file. My email directed me here for help. Thank you  g? Please try logging out of your Reallusion Hub and then restart your computer. Then restart your computer and log back into the Reallusion Hub. Now try again to download Character Creator 3 Base again. Once that completes you can download and install the Character Creator 3 Pipeline Extension.
digitalworlddreamer
digitalworlddreamer
Last Active: 5 Months Ago
Visits: 175
Posts: 23.1K,
Visits: 36.6K
info_05_81 (10/2/2018) man, I have to do many adjustments to existing scenes, that cc3 makes linked stuff to the characters to move slightly out of place + some transform movements are offPlease can you explain more about this problem and try to include screenshots or a video clip showing the issue. Even better if you can let us have your project we can see first hand what is happening.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Peter (RL) (10/10/2018)
Hi Roberto... Just to let you know we are working on adding an easy option to send low poly CC characters back to iClone. We hope to have more news soon.
Great news, Peter Thanks :)
Rogue Anime
Rogue Anime
Visits: 3.4K
Val RogueAnanda
Posts: 23.1K,
Visits: 36.6K
Firepro (9/30/2018) When exporting an FBX and then uploading to Sketchfab, or uploading directly to Sketchfab the CC3 character's pose is ignored and all I get is the T-pose.
I found that if I add the static pose desired to the INCLUDE MOTION TRACK then it is available as an animation. Is this the way it is suppose to work?
Also, in the "Upload to Sketchfab" dialogue box, if a Motion Track is listed as being added, it gets added even if the "Include Motion" checkbox is NOT checked.
Hi... The T-Pose will always be the pose sent to Sketchfab unless you add a pose to the "Include Motion" list. So if you have created a custom pose, please save it to your custom library and then add it to the "Include Motion" list. For the second issue, this will be fixed in future update. :)
Posts: 23.1K,
Visits: 36.6K
Zkeko (9/28/2018)
 Issue When CC3 opens (or after pressing new) there is always a window saying..... (pic) But, there is no old CC1, because it just start openning new CC3 basic female character. But, nevertheless you have to press YES or CANCEL, beecause third option MORE tells you that you should supposedly download morph slider, which leads you to your order page (where I downloaded and installed everything conserning morphs twice ( also because its impossible to determine if you downloaded and install everything that you got with CC3 upgrade, but that's another story), where there is nothing new to happened. When you press YES, then it finish loading same CC3 base female model. Bug maybe, or I missed something!? UPDATE: In the upcoming CC 3.01 version this issue should be fixed and you will only be asked once to update your old morphs. :)
Posts: 23.1K,
Visits: 36.6K
RobertoColombo (9/28/2018) Hello RL,
this is not specifically a problem of CC3 but rather a problem of the pipeline CC3 to iClone. When a CC3 character is reduced in poli-count (CC3 Pipeline new feature) and exported in FBX format, 3DX is not able to read and recognize it is a human character: it is requested to manually map the bones for a non-standard character. This makes no sense at all and generates a lengthy process to import a CC3 low-poli character back to iClone. Pls, fix 3DX so that it can recognize FBX characters generated by CC3 or at least provide a template for 1-click bone mapping, like in the case of 3D Max/May/etc.
Obviously, best solution would be to improve the low-poli export function in CC3 with the option to choose whether to generate the FBX file or rather send the low-poli character directly to iClone!
Thanks Regards RobertoHi Roberto... Just to let you know we are working on adding an easy option to send low poly CC characters back to iClone. We hope to have more news soon.
