Last Active: 11 days ago
Posts: 5.7K,
RobertoColombo (9/28/2018) Hello RL,
this is not specifically a problem of CC3 but rather a problem of the pipeline CC3 to iClone. When a CC3 character is reduced in poli-count (CC3 Pipeline new feature) and exported in FBX format, 3DX is not able to read and recognize it is a human character: it is requested to manually map the bones for a non-standard character. This makes no sense at all and generates a lengthy process to import a CC3 low-poli character back to iClone. Pls, fix 3DX so that it can recognize FBX characters generated by CC3 or at least provide a template for 1-click bone mapping, like in the case of 3D Max/May/etc.
Obviously, best solution would be to improve the low-poli export function in CC3 with the option to choose whether to generate the FBX file or rather send the low-poli character directly to iClone!
Thanks Regards Roberto
The Remesh function does not work with iClone, and you can not export a Remeshed iAvater. This function is only available for Game Characters. In CC3, under InstalLOD, you can select to Reduce the Poly count for wearables.  It is also possible to reduce the Texture sizes of the clothing before export to reduce the load on the scene.
tomcleaver
tomcleaver
Visits: 98
Exactly the same problem here, with 2 and, I was hoping it wouldn't occur, in 3 as well. Can't use :( EDIT: Solution to this problem is download the program called Display Driver Uninstaller ( Link Here), follow the instruction on cleaning out your old drivers, then reinstall the latest graphics drivers for your card and voila! Fixed.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Gerry,
this is the current status and we know, but my point is different: is it possible make the low-poli readable by both 3DX and iClone without the bone remapping ? Because the skeleton structure does not change, so, what does it prevents 3DX to read it as an already rigged character, or transferring the low-poli directly to iClone ? My request is to enable these features. If you know precisely the SW code used by RL and can demonstrate that it is really not possible at all, I will withdraw my request, otherwise, pls, let's not jump to conclusions.
I believe many people here bought the Pipeline extension in order to generate low-poli crowds also for iClone and would appreciate an easy way to do that...
Cheers
Roberto
Posts: 5.7K,
The FBX export is not intended to be used in iClone, it is for Game software. At the moment the only way to get low poly characters in to iClone is by using the Reduce Wearables Mesh option. Remeshed characters do not work in iClone at the moment and therefor this option was removed by the Development team for the present.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Hi Gerry,
still you did not get the point. If you create a low-poli CC3 character, export as FBX, import in 3DXChange, retarget the bones, export as iAvatar, it works perfectly in iClone. So, when you say "The FBX export is not intended to be used in iClone" that's wrong: FBX works fine in iClone after being converted through 3DX. Now, having a little experience (about 25 years...) in SW programming, I can tell you that there is no one single bit of difference between exporting a reduced mesh to FBX format or just exporting it as iAvatar: it is just a different format. That's what I am asking to RL: to provide a direct export to iClone directly in iAvatar format. Not rocket science...
Cheers
Roberto
toystorylab
toystorylab
Last Active: 4 Months Ago
Posts: 4.6K,
Visits: 29.9K
Hm, i pre-ordered CC3 + Iray-Plugin but did not install yet, quite busy and want to wait till most issues are polished... BUT what i read from "RobertoColombo" and "wires" makes me wonder. LOD-function in CC3 Pipeline was one of my major reasons (crowds in iClone) to buy it. And the announcement said it would work in iClone! WHY is there no "send to iClone-button" for remeshed characters? And how did these characters (from my understanding not only "Reduce Wearables Mesh") shown in Promo-Video end up in iClone?
Posts: 5.7K,
Roberto, The Beta tests proved that a remeshed iAvatar just doesn't work correctly at the moment and that is why the option has not been included. The mesh reduction option does work and permits full use of materials and collision shapes while not using too many resources.
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
@toystorylab >>> " ... LOD-function in CC3 Pipeline was one of my major reasons (crowds in iClone) to buy it. ... " <<< Same here ...
Please be patient with me ..... I don't always 'get it' the first time 'round - not even the 2nd time! :( - yikes! ... ● MSI GT72VR Laptop, i7 7700HQ 4-Core 3.8 GHz 16GB RAM; Nvidia 1070, 8GB Vram ● iClone-7.93 ● 3DXChange Pipeline 7.81 ● CC-3 Pipeline 3.44 ● Live Face ● HeadShot ● Brekel Pro-Body ● Popcorn FX ● iRAY ● Kinect V2 ● DaVinci Resolve17 ● Mixcraft 8.1
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Hi Gerry,
I see the point. What was the reason ? SW programming issue ? Did RL committed to fix the issue ?
Anyway, the quick&dirty work-around would be to have from RL the 3DX template to re-target the bones in 1-click.
Roberto
brand468
brand468
Visits: 7.8K
RobertoColombo (9/28/2018) Hi Gerry,
If you create a low-poli CC3 character, export as FBX, import in 3DXChange, retarget the bones, export as iAvatar, it works perfectly in iClone. So, when you say "The FBX export is not intended to be used in iClone" that's wrong: FBX works fine in iClone after being converted through 3DX. Roberto
Hi Roberto, i managed to export nude character with lowest LOD to 3Dxchange and used autoconversion. Working fine in iClone and ended up with 362 triangles :-) Christer | | | | | | | | |
Text-to-speech function is limited to 200 characters
My computer: Intel i7-7700K 4.2Hhz 64Gb, Windows 10, GeForce GTX 1080 + GeForce GTX 1070, Phillips monitor 40" 4K 3840x2160 + 2x28"
