Joanne (RL)
Joanne (RL)
Last Active: 3 Weeks Ago
Visits: 4.9K
New Discard Simulating Frames under Render > Output Range can be used to remove the warm up frames for physics, speedtree wind, and particle simulation from the starting value of the Export Range.
![https://forum.reallusion.com/uploads/images/554eb189-2d65-43a9-9d19-e7d3.png](https://forum.reallusion.com/uploads/images/554eb189-2d65-43a9-9d19-e7d3.png)
Instructions: iClone is a real-time engine that requires playback time in order to simulate physics for export to video and image sequences. These warm up frames would usually be cut out in post-processing. In the example below, warm up time must be reserved for the fluttering dress and hair. |
Set Discard Simulating Frames to 75 frames to flutter the dress immediately.
Compare and contrast Discard Simulating Frames set to 0 and 75. Discard Simulating Frames = 75 exported video (right) effectively achieves mid-motion for cloth and hair soft-cloth physics.
Compare and contrast Discard Simulating Frames set to 0 and 250 for particle effects. Discard Simulating Frames = 250 exported video (right) effectively achieves full volume smoke.
Compare and contrast Discard Simulating Frames set to 0 and 250 for Speedtree. Discard Simulating Frames = 250 exported video (right) effectively achieves strong wind effects.
6 Years Ago by
Joanne (RL)
