07. [iClone 7.3 NEW RELEASE] Discard Simulating Frames
https://forum.reallusion.com/Topic381358.aspx
Print Topic | Close Window
By Joanne (RL) - 8 Years Ago
New Discard Simulating Frames under Render > Output Range can be used to remove the warm up frames for physics, speedtree wind, and particle simulation from the starting value of the Export Range
https://forum.reallusion.com/uploads/images/554eb189-2d65-43a9-9d19-e7d3.png
Instructions: iClone is a real-time engine that requires playback time in order to simulate physics for export to video and image sequences.  These warm up frames would usually be cut out in post-processing. In the example below, warm up time must be reserved for the fluttering dress and hair.https://forum.reallusion.com/uploads/images/fd2a5a79-52dc-4b21-935e-a8f6.gif|
Set Discard Simulating Frames to 75 frames to flutter the dress immediately.
Compare and contrast Discard Simulating Frames set to 0 and 75.
Discard Simulating Frames = 75 exported video (right) effectively achieves mid-motion for  cloth and hair soft-cloth physics.
Compare and contrast Discard Simulating Frames set to 0 and 250 for particle effects.
Discard Simulating Frames = 250 exported video (right) effectively achieves full volume smoke.
Compare and contrast Discard Simulating Frames set to 0 and 250 for Speedtree.
Discard Simulating Frames = 250 exported video (right) effectively achieves strong wind effects.
