muzico
muzico
Visits: 32
Hi everyone, Im working with a trial version of iClone 7 and Motion LIVE plugin since we bought the Perception Neuron Pro Mocap and in the beginning it worked fine, the data from the Axis Neuron through the IP been sent to Motion Live where it connected and showed 1 Actor and the Sync movements where all OK. Now I was testing some stuff and everything is connected, I can see the Green light and the Character is selected but I get 0 Actors which means I can preview the performance from Axis Neuron or any pre-recorded performance. Tried to restart, changed the IP address nothing works, it still connects but still shows 0 Actors. Does anyone have a clue? Best regards, Angelo.
Posts: 9.1K,
Visits: 21.7K
You're not showing us the relevant part of that dialog box, the place below where it actually has the characters you can select from. You need, of course, one or more avatars in your scene to choose from, but let's assume you do have that. Show us a screen shot of what that whole dialog box looks like when you have that avatar selected on screen (namely, you've pressed Q and then selected the entire avatar, not just a portion of them).
DannyAtBadHoneyBunGames
Visits: 42
e1_scheer
e1_scheer
Visits: 1.1K
I'm having exactly the same problem Would be nice to get some kind of follow-up.
luke (RL)
luke (RL)
Group: Power Developer
Last Active: 3 hours ago
Visits: 5.3K
Hi. Please help us to confirm the Axis Neuron settings like the images show below:
e1_scheer
e1_scheer
Visits: 1.1K
Hi,
Just checked these settings and the only one that was different was the fact that you have the displacement checked. So I changed that so it matched up to your settings, but still no actor data inside iclone.
I'm running neuron axis pro 3.8.42.8308 and iclone 7.4
Thanks,
Iwan
luke (RL)
luke (RL)
Visits: 5.3K
did you play in Axis Neuron before connect to motionlive? And what is the version of MotionLIVE and Neuron profile? The newest version should be 1.02, thanks
e1_scheer
e1_scheer
Visits: 1.1K
Thanks first of all for looking into this. I've updated all the reallusion software to their latest versions : motion live v1.02 leapmotion v1.02 faceware v1.02 perception neuron v1.02 I also manage to stream the neuron data into motionbuilder, which makes me think the problem is on the iclone side.
6 Years Ago by
e1_scheer
Posts: 22.6K,
Visits: 35.6K
If you are continuing to have problems I would advise contact Technical Support to get the issue logged. They will then be able to advise you further. Thanks.
e1_scheer
e1_scheer
Visits: 1.1K
Hi Peter, Thanks for the heads-up first of all. However if you look at the multiple threads on the forum on this subject (dating back 4 months) it looks like this is a bit of an outstanding issue. And for the record, I did contact technical support more than a week ago. So let's see what happens, Iwan
5 Years Ago by
e1_scheer
