e1_scheer
e1_scheer
Visits: 1.1K
So this all got fixed this morning with everything up and running and an excellent way to start the new year !
Thanks again Luke :)
luke (RL)
luke (RL)
Group: Power Developer
Visits: 5.6K
Ok, thanks for e1_scheer's help, we finally found the root cause, the reason is an unknown application occupied the port 7001 so Axis Neuron can't stream out the data to MotionLIVE, we changed the port to 7011 then it works. If anyone has the same issue, you could try to download this tool to find the free port, and set it in MotionLIVE and Axis Neuron, thanks
luke (RL)
luke (RL)
Visits: 5.6K
Hi, Would you mind contact me directly? I send a pm to you, thanks
e1_scheer
e1_scheer
Visits: 1.1K
Hi Peter,
Thanks for the heads-up first of all. :)
However if you look at the multiple threads on the forum on this subject (dating back 4 months) it looks like this is a bit of an outstanding issue. And for the record, I did contact technical support more than a week ago.
So let's see what happens,
Iwan
Posts: 23.1K,
Visits: 36.6K
If you are continuing to have problems I would advise contact Technical Support to get the issue logged. They will then be able to advise you further. Thanks.
e1_scheer
e1_scheer
Visits: 1.1K
Thanks first of all for looking into this. :) I've updated all the reallusion software to their latest versions :
motion live v1.02 leapmotion v1.02 faceware v1.02 perception neuron v1.02
I also manage to stream the neuron data into motionbuilder, which makes me think the problem is on the iclone side.
luke (RL)
luke (RL)
Visits: 5.6K
did you play in Axis Neuron before connect to motionlive? And what is the version of MotionLIVE and Neuron profile? The newest version should be 1.02, thanks
e1_scheer
e1_scheer
Visits: 1.1K
Hi,
Just checked these settings and the only one that was different was the fact that you have the displacement checked. So I changed that so it matched up to your settings, but still no actor data inside iclone.
I'm running neuron axis pro 3.8.42.8308 and iclone 7.4
Thanks,
Iwan
luke (RL)
luke (RL)
Visits: 5.6K
Hi. Please help us to confirm the Axis Neuron settings like the images show below:
e1_scheer
e1_scheer
Visits: 1.1K
I'm having exactly the same problem Would be nice to get some kind of follow-up.
