sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Last Active: 7 hours ago
No real debate -- everyone I know who does animation (and that includes a lot of Pros) just renders to still frames. So no file "format" to worry about. For any video they bring in, of course, it's lossless AVI for the most part. But for iClone projects just render to PNG (which contains alpha) and you're home free.
And let me clarify that last -- you don't EVER use a codec until you're ready for final output. You do not want to be compressing or decompressing your footage until the very end (which is why you work with stills for animation and other rendered stuff, and uncompressed video for the rest). Only when you are finished do you bring up your final codec (and, of course, you save your project so you can render in different codecs depending on your delivery needs).
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
G'day Mike! ... Yes - I well remember your advice on this in the past re .PNGs (I hadn't forgotten). I guess it's more a question of 'once it's in there' (the NLE) .... Do I keep it that way (my PC struggles playing PNG sequences) - or is there a recommended format to transcode into, and if I do, to keep in mind: ● Minimal or no loss to be incurred ● something 'other than' uncompressed, (huge file sizes - just as sluggish) ● keeping the alpha channel as well ???
6 Years Ago by
sonic7
No -- you do NOT transcode. You can temporarily render so it plays faster but, again, you hold off any compression until the output. Nearly all NLEs will "render" a sequence so it plays faster on the timeline, you just need to find how to do it in yours.
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Ahhhh !!! ..... Yes .... I thought I'd read something about 'proxy' files - smaller versions of the originals .... I get it - yes make the proxy files in Media Studio, Edit and add FX, then when all is complete let it render the *final* using the original PNG sequence ..... OK. Now, the only thought on that is 'will the proxy files' give me accurate enough detail/definition for dialing in my FX? Hopefully that's a 'yes' - so that the final render hasn't 'changed' compared to my 'off line edit'....
6 Years Ago by
sonic7
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
I'll do some testing on this Mike - and report back with my findings (in-case useful to others) .... thnx
Mark won't understand me (I can see him shaking his head) - "why is Sonic mucking about with 8 bits" ....
6 Years Ago by
sonic7
mark
Posts: 4.8K,
Visits: 16.4K
As they say .png is the way to go for sure. One beauty is you can render at very high resolution and then render the size you need when you're done in your NLE. Now if you have an audio track you need to match or reference in you NLE I would also render a .wmv or .mp4 file out of iClone for that. The .png image sequence won't have audio as you know. You can then line everything up in your NLE and lay back in your original audio and of course add to your audio tracks mix and sweeten.
6 Years Ago by
mark
illusionLAB
illusionLAB
Visits: 4.8K
8 bit files the norm for editing. Using PNG or TGA sequences are the way to go right up till your 'final output'. Proxies are a must... I think Vegas calls it "Smart Render". The industry standard for "offline" editing is AVID's quicktime codec. Even the "lowest quality" will look almost as good as your original PNG renders, so you're not going to miss anything. The codecs are free and once installed should just "show up" in your list of options. As you're in a world of discovery right now... you may want to look at BMD's DaVinci Resolve 15 - I've been using Premiere for eons, but find Resolve much more powerful (now that Fairlight Audio and Fusion in the same software). Also free.
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
@Mark .... Yes - what you say makes sense. I've got to get "Video" (and 'codecs') out of my brain when it comes to this work in NLEs. Seems that the good old 'individual' frames (like in Cine film) or 'flip book' animation, is the way to think. Yes - well the audio's done and dusted - but I guess it might be an idea to place it inside iClone as a reference for timing. The clown that 'sings' (mimes) to the finished audio will be *a real actor for the C/Us* and *an avatar for the distant shots*. I haven't the experience for gaining 'realistic' C/U performances with an avatar. So - yeah - still a good idea to have a reference audio and do like you say - bring it over to the NLE.... thnx
6 Years Ago by
sonic7
