4u2ges (3/10/2018)
@grabiller
lol no, that is not what I did. I do not shrink images after the render.
I did set my computer screen resolution to 3840x2160. Then in iClone I did set the viewport size (you can call it a 3D viewer or viewport, it does not really matter) to a full screen with Ctrl+7 and set the render export size to 1920x1080. Then started render. That is it../..Lol ok, so I was right to suspect my understanding of your wordings ^^
4u2ges (3/10/2018)
../..Now the iCLone super-sampling in this render setup is irrelevant and it simply does not have any effect on a final render, whether I turn it ON or set OFF../..
It can't be. Perhaps you just don't notice it due to the low contrast of your scene and the high resolution.
4u2ges (3/10/2018)
../..But at the same time the anti-aliasing is still taking place and works whole lot better than iClone super-sampling. Why? I cannot be sure. I can only speculate.
Possibly I am getting a "Spatial anti-aliasing" effect (Indigo super-sampling works that way, not sure about iCLone)../..
Again, it can't be, there is NO iClone "internal" antialiasing taking place outside the super-sampling feature.
4u2ges (3/10/2018)
../..Just look at the last 4 sec of my test video. Super sampling is OFF there. But it looks a lot better that 2 previous parts where I had super-sampling ON../..I can't see any difference in antialiasing between those part, I think you qualify the last part being "better" because you are focused on the glare.
Ok, now, lets try to understand. If there is indeed antialiasing happening during your renderings despite the fact you did not enabled super-sampling, then the only reason I can think of is that because anti-aliasing is "forced" in your graphic card drivers settings. If not, then there is no antialiasing and you are blind lol.
Well, to be sure of that, lets experiment this, I'll do it on my side too:
1) Open the default Project Template -> 1. Character -> 2. Turntable (the horse)
2) Be sure render settings are Image/UHD/Final Render/ NO SS.
3) F10 then save the image
4) Do the same but this time enable SS 3x3
5) Open the images in any image viewer - ie photoshop - and zoom both images to 800%
You then should clearly see the difference.
Here Without Super Sampling (no anti-aliasing):
And Here With Super Sampling 3x3 (anti-aliasing is clearly present):
guy rabiller | GOETZIWOOD STUDIOS
"N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
