Motion Capture Plug-in - iClone7 - Windows10 - Kinect Xbox OneV2
Posted By Snarp Farkle 8 Years Ago
Snarp Farkle
Snarp Farkle
Posts: 770, Visits: 3.6K
Exactly what software is needed to make this all work in iC7 and Win10 is a bit confusing so I started this topic to try to put it all in one place and relevant for iC7 and Win10.
Windows10:
You should not install any other drivers, SDK's or software. (Excerpt from the FAQ page)
  • So this would mean that you don't need to download or install the "KinectSDK-v2.0_1409-Setup" or the "KinectRuntime-v2.0_1409-Setup" to use the Kinect Xbox OneV2 Sensor for iClone7 and Win10 because the Mocap Device Plug-in contains everything you need.
iClone7:
Mocap Device Plug-in Kinect for Xbox One.
  • This should be the only software you need to install.
Minimum System Requirements:  (Excerpt from KINECT Mocap page)
KINECT Mocap Plug-in – Xbox One:
    64-bit ( x64 ) processor - Physical dual-core 3.1 GHz ( 2 logical cores per physical ) or faster processor
    USB 3.0 controller dedicated to the Kinect for Windows v2 sensor or the Kinect Adapter for Windows for use with the Kinect for Xbox One sensor
    4 GB of RAM
    Graphics card that supports DirectX 11
    Windows 8 or 8.1, Windows Embedded 8, or Windows 10 ( x64 )
    iClone Pro v 6.21 and above.
Feel free to correct me if any of this information is incorrect and I'll make the necessary changes.
Threaded View
Threaded View
Forum Post Motion Capture Plug-in - iClone7 - Windows10 - Kinect Xbox OneV2 By Snarp Farkle ( 8 Years Ago )
Forum Post That is all correct. :) Have you tried using the Kinect For Xbox... By Peter (RL) ( 8 Years Ago )
Forum Post Thanks Peter, I have the sensor but I'm still waiting for the over... By Snarp Farkle ( 8 Years Ago )
Forum Post Well the overly priced adapter finally arrived but now see I need a... By Snarp Farkle ( 8 Years Ago )
Forum Post After Kellytoons kindly posted an iMotion file for me to use in a... By sonic7 ( 8 Years Ago )
Forum Post Thanks sonicthehedgehog_24 for posting about the hardware side of... By Snarp Farkle ( 8 Years Ago )
Forum Post I see what you mean about the scalpers having a field day ..... t he... By sonic7 ( 8 Years Ago )
Forum Post Is there a trick to connecting this to iClone 7? I'm trying iClone... By asecretofthe ( 8 Years Ago )
Forum Post @asecretofthe, You posted: "Is there a trick to connecting this to... By Snarp Farkle ( 8 Years Ago )
Forum Post Am I missing anything here? - apart from my marbles :w00t: Other than... By sonic7 ( 8 Years Ago )
Forum Post your computer can't power the kinnect. You need to use the MS power... By asecretofthe ( 8 Years Ago )
Forum Post @asecretofthe Thanks for confirming about the power .... And yes, -... By sonic7 ( 8 Years Ago )
Forum Post [quote][b]sonicthehedgehog_24 (3/22/2018)[/b][hr]Am I missing anything... By 《/^\》 ( 8 Years Ago )
Forum Post Hi《/^\》... I stumbled across this video - the narrator says he was... By sonic7 ( 8 Years Ago )
Forum Post [quote][b]sonic7 (3/23/2018)[/b][hr]Hi《/^\》... I stumbled across this... By 《/^\》 ( 8 Years Ago )
Forum Post @《/^\》 ..... I understand. You're right; - this thread's about the... By sonic7 ( 8 Years Ago )
Forum Post Fellow dreamers and 'would-be owners' of a budget Mocap system -... By sonic7 ( 8 Years Ago )
Forum Post ■■■ Kinect Hardware versions ■■■ ● I knocked up this... By sonic7 ( 8 Years Ago )
Forum Post Hi sonic7, I went with the xBox One sensor because it seemed to be... By Snarp Farkle ( 8 Years Ago )
Forum Post Hi ..... Yes - your comment ...." I can not afford the Perception... By sonic7 ( 8 Years Ago )
Forum Post OK ... In the interests of nailing an answer here. (I've never owned... By sonic7 ( 8 Years Ago )
Forum Post Hi sonic7, Kelleytoons has a wealth of information regarding many... By Snarp Farkle ( 8 Years Ago )
Forum Post kinnect mocap seems kind of limited. It doesn't track wrist. Which... By asecretofthe ( 8 Years Ago )
Forum Post Hello. Why not try ipisoft. This is a very good program. I am very... By nikofilm ( 8 Years Ago )
Forum Post Snarp Farkle...what a great name! I'm old enough to remember Frank &... By bruceberg ( 8 Years Ago )
Forum Post I think Snarp might be busy setting up his office / heating etc. (Hope... By sonic7 ( 8 Years Ago )
Forum Post Sonic7...I'm curious now if you will get better results using V2 of... By bruceberg ( 8 Years Ago )
Forum Post Bruce .... I'm only aware of 'field of view' and 'resolution'... By sonic7 ( 8 Years Ago )
Forum Post Hi Sonic7...Just a couple of random thoughts...I'm certainly no... By bruceberg ( 8 Years Ago )
Forum Post Bruce ..... I take it that this is the Kinect you're using (version... By sonic7 ( 8 Years Ago )
Forum Post Hey Sonic7...I had to laugh reading your last post. We have a smaller... By bruceberg ( 8 Years Ago )
Forum Post Bruce .... I should have all the hardware this coming week. Then I'll... By sonic7 ( 8 Years Ago )
Forum Post Well I've had other problems arise that had delayed my continuation of... By Snarp Farkle ( 8 Years Ago )
Forum Post Great to hear from you ! (BTW, - I've now got my V2 mocap as well as... By sonic7 ( 8 Years Ago )
Forum Post Local is what you want. Your Kinect will be directly attached to the... By Rampa ( 8 Years Ago )
Forum Post Thanks for that clarification Rampa :) ..... By sonic7 ( 8 Years Ago )
Forum Post Hey sonic7 and Rampa, Thanks for pointing out that an internet... By Snarp Farkle ( 8 Years Ago )
Forum Post :w00t: SUCCESS! I was successful in getting the Kinect for Xbox... By Snarp Farkle ( 8 Years Ago )
Forum Post That's great to hear! Can't wait to (also) try the V2 - this coming... By sonic7 ( 8 Years Ago )
Forum Post O.K. - I've spent the day clearing a workspace, taking photos of the... By sonic7 ( 8 Years Ago )
Forum Post Hi Sonic, I thought the same thing when I started my testing also,... By Snarp Farkle ( 8 Years Ago )
Forum Post Hi Snarpe, - thanks for your help ... Your Comment: "....... By sonic7 ( 8 Years Ago )
Forum Post Snarpe - I googled info about your 'Lenovo G505' Laptop - but... By sonic7 ( 8 Years Ago )
Forum Post you can make your own kinect adapter from for under $10 if you know... By webfame ( 8 Years Ago )
Forum Post Further 'findings' (for those wanting to dig deeper) ............ By sonic7 ( 8 Years Ago )
Forum Post [quote][b]sonic7 (4/21/2018)[/b][hr] ..... I was surprised to notice... By Snarp Farkle ( 8 Years Ago )
Forum Post Here's a quick video I put together to show the raw mocap data from my... By Snarp Farkle ( 8 Years Ago )
Forum Post Snarpe ....... I'm going to catch up on your video tomorrow... By sonic7 ( 8 Years Ago )
Forum Post :( That's a real bummer Steve, we've had our share storms with high... By Snarp Farkle ( 8 Years Ago )
Forum Post OK. after 9 days without NBN , they (finally) actually showed up and... By sonic7 ( 8 Years Ago )
Forum Post [quote][b]sonic7 (5/1/2018)[/b][hr] OK. after 9 days without NBN ,... By Snarp Farkle ( 8 Years Ago )
Forum Post Well, while Mike Kelley's eagerly awaiting delivery of a '... By sonic7 ( 8 Years Ago )
Forum Post Brekel has a free trial, and I think iPisoft does as well (iPisoft is... By Kelleytoons ( 8 Years Ago )
Forum Post Thanks Mike ... I'll give the Brekel trial a go I guess .... (I've... By sonic7 ( 8 Years Ago )
Forum Post But DO try the iPisoft, if you haven't already worn out your trial... By Kelleytoons ( 8 Years Ago )
Forum Post I had the same experience with Brekel. I tried with the new Kinect and... By kungphu ( 8 Years Ago )
Forum Post kungphu >>>> ".... Oh and converting a bunch of... By sonic7 ( 8 Years Ago )
Forum Post Hey there, I didn't convert any of the brekel motions because honestly... By kungphu ( 8 Years Ago )
Forum Post OK - here's the *latest* with this 'pursuit' of mocap capturing here... By sonic7 ( 8 Years Ago )
Forum Post Good to hear you're still at it Steve! I'm still out of the game... By Snarp Farkle ( 8 Years Ago )
Forum Post Also, you can cut the kinect v2's cable and just splice a USB 3.0... By webfame ( 8 Years Ago )
Forum Post Hi webfame .... Yes - there's quite a few YT videos and other... By sonic7 ( 8 Years Ago )
Forum Post Hi guys. I was following the discussion and wonder if you have tried... By mr brush ( 8 Years Ago )
Forum Post There is a free trial for 30 days or the full lifetime plugin is 195... By mr brush ( 8 Years Ago )
Forum Post G'day mrbrush .... I haven't tried the 'others' as yet (been... By sonic7 ( 8 Years Ago )
Forum Post Hey .... mrbrush - I'm actually pleased you posted just now. It made... By sonic7 ( 8 Years Ago )
Forum Post No problem. Its worth doing some investigation on this as the youtube... By mr brush ( 8 Years Ago )
Forum Post Hello guys, I was reading your posts about the other tools for... By Kalex ( 8 Years Ago )
Forum Post Mike Kelley (KelleyToons) has done a lot with IPI and has reported... By animagic ( 8 Years Ago )
Forum Post I'm pretty sure Sonic7 isn't interested in the two Kinect thing, but... By Kelleytoons ( 8 Years Ago )
Forum Post Just be *aware* - this 'iPiSoft' offer's not as attractive as it... By sonic7 ( 8 Years Ago )
Forum Post If iPisoft ends up being what anyone wants, they always have a... By Kelleytoons ( 8 Years Ago )
Forum Post Yeah Mike ..... "The jury's still out on this" - for me - I'm afraid.... By sonic7 ( 8 Years Ago )
Forum Post What you are discovering is that single Kinect capture just has too... By Kelleytoons ( 8 Years Ago )
Forum Post I've seen some impressive results with 'webanimate' - examples from... By sonic7 ( 8 Years Ago )
Forum Post I tried WA (actually even bought it) and haven't been successful with... By Kelleytoons ( 8 Years Ago )
Forum Post Hey Mike - They say in their 'trial request' page: "You must also... By sonic7 ( 8 Years Ago )
Forum Post You don't have to choose that -- you might be looking at the wrong... By Kelleytoons ( 8 Years Ago )
Forum Post I just bought the ipi express perpetual for 137 British pounds. You... By mr brush ( 8 Years Ago )
Forum Post @mrbrush .... I'm happy for you about your mocap decision - and... By sonic7 ( 8 Years Ago )
Forum Post Well - there's only 'minutes' left on that iPi "special" .... and... By sonic7 ( 8 Years Ago )
Forum Post Steve, My biggest issue with Kinect captures that were NOT in iPisoft... By Kelleytoons ( 8 Years Ago )
Forum Post I did have the brekel about 2 years ago and for me it was useless. A... By mr brush ( 8 Years Ago )
Forum Post KT - awhile back it sounded like you were going to do a write-up... By gordryd ( 8 Years Ago )
Forum Post Yeah, I was intending to compare what I consider to be "the big three"... By Kelleytoons ( 8 Years Ago )
Forum Post @KT - Seemed like you were heavily leaning towards Vive and then... By gordryd ( 8 Years Ago )
Forum Post It's in my thread about the VIVE, and probably best to look at it... By Kelleytoons ( 8 Years Ago )
Forum Post iPisoft: - Three versions *Express *Basic and *Pro - but the... By sonic7 ( 8 Years Ago )
Forum Post I took a quick look at Brekel's V2 (the last time I checked it was V1)... By Kelleytoons ( 8 Years Ago )
Forum Post Yeah Mike - there's absolutely no question about the 'occlusion'... By sonic7 ( 8 Years Ago )
Forum Post If you already have the RL kinect mocap, then your best investment is... By illusionLAB ( 8 Years Ago )
Forum Post Hi Mark .... Yes, I'd wondered about cleaning up RL Mocap via... By sonic7 ( 8 Years Ago )
Forum Post Sorry, forgot that 3DX "Pro" is not professional at all... no way to... By illusionLAB ( 8 Years Ago )
Forum Post Although I eventually will want to get Perception Neuron, I decided to... By animagic ( 8 Years Ago )
Forum Post Dont forget theres one major deciding factor, and that is the ability... By Jesus Martina ( 8 Years Ago )
Forum Post Yep - I can confirm that I've seen the iPi 360° demo .... here:... By sonic7 ( 8 Years Ago )
Forum Post Since that last link you posted was removed for some reason, Ive... By Jesus Martina ( 8 Years Ago )
